Question about Troy Garden
I have a troy built Rear tine Tiller It runs greAt but when it gets under a lload it bogs down and goes dead I have rebuilt the carb and it didn't help
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
George might be onto something but what brand of engine do you have ???
A mis adjusted/malfunctioning governor can be culprit for your condition.
A plugged/damaged main jet or emulsion tube can also be a culprit even though you state you "cleaned" the carb
Have you checked your running engine speed ? Is it too low to begin with and your engine is stalling because it drops to low ???
Depending on the engine, 3400 rpm's is a safe speed without knowing what you have...
Posted on Apr 28, 2015
    Sergeant:
  • 406 Answers
Sounds like your governor is hanging up or disconnected.it is what supplies the extra power when needed under load..try this when it is under power reach down and manualy operate the governor linkage and see it the bogging stops if it does then most likely it is the linkage..make sure it is conected then try spraying card lingage cleaner all around your carb and governor linkage while manualy operating it..there are internal and external governors if external and still hanging up take off the top cover and locate the govenor fan located along side the cooling fin area on top of the motor and make sure it is not dirty and sticking..it operates on air supplied by the cooling fins to move the governor linkage..sounds like a lot but is not..just a lot of explanation..good luck
Posted on Apr 09, 2015
  • 97 Answers
SOURCE: How to remove rear tines to replace seals ?
The tines sometimes get frozen to the shaft. You might try penatrating oil and use a heat gun or hair dryer to heat to loosen.
Also tap wiht a hammer around shaft.
Posted on Mar 21, 2009
  • 69 Answers
SOURCE: Troy Bilt tiller dies when I engage the tines.
Bogging down may indicate debris or old gas in the carb. Try doing a carb cleaning, and add a small amount of Seafoam gas additive to your gas.
Posted on May 06, 2009
  • 69 Answers
SOURCE: What type oil goes in the tranmission?
80W90 Gear oil goes in the tranny. 30W is for the engine only,
SOURCE: Changing Drive belt On Troy Built Tiller
You have to remove the engine (4 bolts, no big problem), then remove the bolt in the center of the pulleys, then remove the pulleys. Slip the belt(s) (2 if you have the Super Bronco model) onto the pulleys, re-attach the pulleys with the bolt, re-mount the engine, and you're home free.
Posted on Mar 31, 2010
SOURCE: mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Posted on May 27, 2010
Troy bilt troubleshooting tiller
sounds like not enough vacum to draw fuel .faulty diaphram pump. gas cap should have a breather assembly to allow air to enter gas tank and prevent a vacum lock as well
Jun 29, 2014 | Mtd Bronco Rear Tine Tiller
Tiller moves to fast on a troy built rear tine
what do you mean - are you sure this is a husqvarna or a troy built tiller?
May 07, 2012 | Husqvarna PRRT850X 960920015 CA 17" Rear...
Tines turning, mantis 2 cycle tiller
sounds like a piston seizure. are you using correct oil and ratio. carb could be going lean and causing the cylinder to over heat, adjust high speed mixing screw and hope no damage has resulted.
Jun 30, 2010 | Mantis 2-Cycle Tiller
I have a troy bilt tiller with a 2hp motor.lately i have had to run it with the choke on and then when i engage the tines it will go dead.have any ideas thanks the engine is a tecumseh
You can check the linkage that links the governor to the carb. If that is fine then you can check the fuel line for a blockage, the carburetor for debris, and if that is fine then you may want to try sanding the rust off the magnet (on the fly-wheel).
May 10, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Carb needs rebuilt and I do not know the part # for this engine, Tecumseh HM100 159370P-B
Should be a metal tag somewhere on the tiller that gives all the information, Will give Model #. type and serial #. Your parts dealer can I dentify the carburetor from those nos.
Feb 20, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt Tiller and Pressure Washer
The carbs are plugged. Take the bowl off the carburetor by loosening the nut on the bottom. You'll want to clamp the fuel line before you do this. That nut has a small hole that goes through the nut from side to side, and one that connects them in the center. Use a wire brush to knock all the deposits loose, making sure that the holes are clean and free of obstruction. Put it all back together, and it should run fine.
Jun 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy bilt tiller
either the carb needs cleaned or theres a vacuum leak
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Does rear tine tiller run 2 belts
Check the Troybuilt website for specific info on your tiller.
www.troybuilt.com
Mar 22, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Mar 21, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy bilt tuffy with 3.0 tecumseh engine.
Contact Information:
http://www.tecumsehpower.com
900 North Street
Grafton, Wisconsin
53024 USA
Phone: 262-377-2700
Jan 25, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
261 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
