Question about Nordic Track Elite 9700 Pro Treadmill
We started hearing a clicking or ticking noise from the motor
The noise is constant. Does the motor need to be replaced? Can we continue to use it until it is replaced?
Did you ever get an answer back for your question? I just received my 9700 Pro in late March 2015. After only 4 times using it I also have the clicking coming from the drive motor. It sounds like the motor bearings.
Posted on Apr 21, 2015
Why my 2010 Venza drive on sometimes while driving it sound like the transmission is in neutral
Common Car Noises and Their Likely Causes Noise More Details Likely Cause Fixing It Clicking noise while turning Starts faint, gradually becomes more noticeable until very loud Failed outer CV joint (constant velocity joint) due to torn boot (most likely) or old age Replace either the whole axle assembly (recommended) or the outer CV joint Water pump noises Difficult to diagnose because of water pump's location Noise usually caused by damage to the bearings in failed water pump Only cure is replacing it. If possible do it at the same time as a timing belt replacement to cut down on labor costs Squeak or squeal from an engine belt Loud, high-pitched squeak or squeal Belts either need adjustment or replacing If belts only squeak when damp, they probably just need adjustment. If they squeak constantly, they probably need to be replaced Exhaust heat shield noises Rattle that you hear when car is idling Damaged heat shield Replace heat sh
Sep 28, 2016 | Cars & Trucks
GE side by side freezer, rhythmic whirring noise coming from freezer, at the top near ice maker.
Typically the freezer fan motor should be replaced, the issue usually lies with the tachometer within the fan motor, the main control board is not sensing the proper speed of the fan motor and therefore can't operate it correctly. In many cases the main board gets replaced too to ensure the most up to date software, as GE has had NUMEROUS software revisions on those main boards over the last 11 years. You would need to capture the complete model number from the appliance it's self in order to see if your main board has had preceding part numbers. Pleazer Appliance...
Apr 19, 2014 | GE Profile PSW26P Stainless Steel Side by...
ADL348 is constantly beeping and does not complete cycle
If it beeps continuous and starts on the rinse cycle,then this is indicating the control board is bad and needs to be replaced. NOT THE TOUCH PAD, but the control board.
Dec 17, 2013 | Dishwashers
Motor making loud buzzing noise
The grinding noise could be asking for lube. If that is possible, do it.
Dec 13, 2013 | Precor C956i Treadmills with HR /...
My fridge upper unit isnt working, there is no air circulating, i could hear the compressor working and it seems the lower unit is fine. it started by making a constant ticking sound and then a day later,...
You will need to look into the possible chance that your evaporator Fan motor has stopped, been damaged or the freezer is not defrosting properly. To allow it to continue running can damage the compressor. Click Here=> MFD2560HES Evaporator Components then 12002744 Evaporator Fan Motor and again the 67002493 Defrost Heater I have all the instructions and hands on if you would like my assistance I will be here to assist and repair you Maytag That ticking noise could have been your fan blade finally reaching the frost until the fan stopped. Let me know Here or or here on Fixya, Thanks, Sea Breeze
Sep 14, 2011 | Maytag MFD2560HES Bottom Freezer French...
Pool pump motor noise/hum would come and go, noise was not constant nor continuous, every few seconds would go from high to low sound but volume would seemed constant. was not an extraordinary noise and...
The problem is the starter capacitor on the back or top of motor depending on make. The capacitor is round and black and about 3 inches long and the diameter of a half dollar. it will have 4 wires with quick disconnects on them, unplug and replace capacitor and put wires back on the same way they came off old one. as far as the noise, the bearings are starting to wear and can be replaced when you get tired of the noise. you will have to take it in to have the bearings replaced.
Aug 31, 2011 | Emerson Pool & Spa
My Intermatic T103 Indoor 120-Volt 40-amp timer emits a constant peeping sound
Intermatic T103 is mechanical timer with moving gears.
Timer makes audible sound when tripper clicks on-off, but it should not make constant noise unless gears are causing noise.
Turn off power and spray WD-40 on gears and see if problem continues.
WD-40 vapor is extremely flammable hydrocarbon when sprayed, and should not be sprayed on live electric circuits.
If problem continues, turn off power, pull mechanism out and spray WD-40 on plastic gears of clock motor.
Open following links for illustrations of clock motor and removing mechanism.
http://waterheatertimer.org/images/WH40-005-gears-350.jpg
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Aug 12, 2011 | Intermatic T103 Indoor 120-Volt 40-amp...
Fridge fan motor is making a wining noise constantly when fridge is shut, seems continually cooling
if fan motor making noise its not turning fast enuff to get frige cold enuff to shut off replace it
Dec 27, 2009 | Fisher Refrigerators
Noisy air flow problem, I think
the GE refrig has a variable speed fan motor controlled by the mother board located on teh rear of you refrig. the noise your hearing is the fan speed ramping up and down. if this noise is constant its possible the contoller on the mother board is bad and the board needs to be replaced. hope this helps...
Dec 07, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Nordic Track Elite 9700 Pro Treadmill Logo
346 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
