Question about Casio MTP Watches
My watch has stopped running. New battery, checked at watch stop, no help. Asked for manual, did not have with me. What should I do.
escapement
  • 2334 Answers
SOURCE: Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Do not forget to rate, please.
Posted on Feb 10, 2009
  • 151 Answers
SOURCE: Purchased a new pulsar chrono as a gift, the
I would return it sounds not like a batt. problem but internal mechanical. If you have a reciept dont deal with a potential problem get a replacement.
Posted on Dec 26, 2009
  • 2501 Answers
SOURCE: The watch is not running after replacing the
It could be that the battery has a poor contact. Try cleaning the battery with surgical spirit and avoid handling its faces.(hold the edges).
Clean also the watch contacts.
Posted on Feb 04, 2010
  • 2501 Answers
SOURCE: The watch has stopped working reset to 1.1 date new battery?
It sounds like it. Take it to a local dealer who will change it for you.
Posted on Feb 18, 2010
Testimonial: "Thank you! I will take it in today!"
  • 8404 Answers
SOURCE: watch has new battery but suddenly stopped.
Might need cleaning, oiling or other servicing ...
What do you think?
Thanks for your interest in FixYa.com
Posted on Feb 19, 2010
My son gave me a Anne Kline watch a year ago but it has stopped running. I changed the battery twice but it still runs some and than stop. What do I need to do?
Watch might need a superior or best quality battery that hasn't been in stock for long...
Few modern watches need a new battery every year and most in my experience will last at least a couple of years so the watch is probably faulty and it is a shame you didn't return it while it was under warranty.
A decent jeweller/horologist should be able to check this and advise you.
Jan 23, 2017 | The Watches
Why does my Gucci watch quit running every few days?
You can start by fitting a new battery & monitor it &see what happens good luck
Aug 20, 2014 | Watches
Fossil twist
If you do not wind the watch, and if it is electronic it obviously has a battery. Very possible even with a new watch the battery has run out. This is especially if the watch was sitting for about a year in their inventory before you bought it.
I am not sure if your watch has a kinetic type movement where it charges the watch, or it is purely an electro-mechanical type movement. I did read it has a quartz referenced movement for the mechanical balance wheel. This would certainly involved a battery. If changing the battery is not the fix you would have to send the watch for service.
Feb 11, 2018 | Fossil Twist Series ME1013 Watch for Men
Elini New Yorker stopped running. could it need a battery? Where can I take it?
Yes, normally if a watch stopped running it needs a new battery. Well, you can bring it to the nearest watch shop in your area.
Sep 17, 2011 | Elini New Yorker Grand Chronograph Red...
I bought it new and then a few weeks later the battery seemed to stop. I did not wear it often. I heard some watches do not use battery and function with the movement of one's arm. Is this the case for...
If the watch is a self winding type, then it generally says "automatic" on the face. These will run for about 2-3 days if they are not worn, as the self winding action only works when the user is moving).
Battery driven watches should run for at least a year before needing a replacement, so if it has stopped already, it could be self winding or manually wound type. Some self winding watches can be manually wound so you could try this to see if it starts.
Aug 14, 2010 | Watches
I just bought my wife a michele csx-36 watch. Its brand new. The watch runs for about one day then stops . What do you think it is. We did replace the battery already. Thanks
that happened to me too...the watch repair man told me that I had the stop watch on. The stop watch should serve as a stop watch, not the second hand. The second time on your watch is the small dial at the bottom middle of the face. Once I turned off the stop watch feature, my battery life is fine...I have not had to change my battery in over 2 years now. HOpe this helps.
Dec 14, 2009 | Michele CSX Diamond watch
Looks like battery problem...
Take it to a local Jeweler or closes retail store and asked them to test your battery.  If its not that there could be a glitch in the watch itself.
May 26, 2009 | Watches
Do as folloes:
Feb 09, 2009 | Relic 0504648FA
Buttons stopped working
Probably you changed battery youself. If that's right, then open watch again, take battery out and check it with tester if it is fully charged. If yes- put battery back in place and secure the contact. Now carefully check for AC sign on movement. When found- take fine tweezers and connectAC with battery+ for 3 seconds.
Watch should work now, but resetting is needed. Use your watch manual to reset all watch functions.
NOTE: Some movements require connect AC and+ twice. This should be written inside caseback or on battery cover.
Good luck.
Arthur
Dec 15, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Watches Logo
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
