Question about Kitchen Appliances - Others
Sometimes when i insert bag for vacume & seal the lights wont come on and unit wont work what causes this
Unit wont work sometimes.. I will insert bag drop the door to clamp and nothing happens as if it off/ or not pluged in
5 Suggested Answers
  • 86 Answers
SOURCE: I have an older model Foodsaver. The machine will
This is likely happening because the unit cannot detect that a vacuum has formed, and the gaskets around the vacuum channel are the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
  • 1739 Answers
SOURCE: my new foodsaver v3460 will
Suggest you review these FAQs on the operation of your vacuum sealer; they offer a number of tips to check the operation of your unit. For example:
Nothing happens when I try to vacuum package
Check power cord to see if it is firmly plugged into electrical outlet.
Examine power cord for any damages.
See if electrical outlet is operative by plugging in another appliance.
If your appliance has a mode switch, make sure it is set to the correct mode. Refer to your QuickStart card for instructions.
Make sure bag is placed correctly inside Vacuum Channel.
Wait 20 minutes to allow appliance to cool off, and then try using it again.
Note: The appliance will shut off automatically if it becomes too hot.
To keep your appliance from overheating:
Wait at least 20 seconds for appliance to cool down before you begin vacuum packaging another item.
Keep lid open before vacuum packaging.
See here fro more FAQs: http://www.foodsavercanada.com/CustomerService/FAQs.aspx?cid=0#35
Your Quick Start Guide can be found here:
http://www.foodsavercanada.com/Manuals/BrandsINTL/Manuals/100956%20VS3460%20QSG%20Final.pdf
For some reason your complete manual is not ccurrently available; I belive this manual is perhaps the closest to your V3460 unit:
http://www.foodsaver.com/Manuals/MANUALS/T000-03430_44_58339730.PDF
Make sure you review all the Tips for sealing bags.
Posted on Jun 25, 2011
  • 475 Answers
SOURCE: it wont vacume any more how do do i fix?
Make sure you have a clean bag in there, and make sure that the belt on it is working.
Posted on Jan 04, 2013
  • 2509 Answers
SOURCE: foodsaver v3420
It's broken, it should heat up and seal.
Contact the manufacturer here: Sites food saver Site
Posted on May 13, 2014
When ready to seal red light stays on
Seal 200 lights - Photo.net B&W Photo - Printing & Finishing Forum
photo.net > ... > Prints & Print Presentation
Jul 29, 2004 - 4 posts - ‎3 authors
I'm sure one is a ready light but would really like to know the details. ... I have the Seal110S unit and the red (really orange) light stays on when ...
SmartSeal™ V3800 Series at FoodSaver.com.
www.foodsaver.com/...sealers/smartseal.../vacuum-sealers-help-and-...
TiliaHow does the new FoodSaver® with SmartSeal™ Technology sense the ... My unit isstuck, it will not open, and unit is not allowing me to feed bag into unit to ...
Quickstart Guide for Hospital Staff - Creche Innovations
crecheinnovations.com/new/wp-content/.../Quickstart_Guide_2012.pdf
Seal the blue zipper tightly. Place feeding into inner bag. Seal the ... Ready. When red light is on. • Warming is occurring. When green light is ... light stays on.
What Causes the Brake Warning Light to Come On ...
Jan 05, 2016 | Cars & Trucks
It wont vacume any more how do do i fix?
Dec 15, 2012 | Tilia Foodsaver V835 Vacuum Sealer
Foodsaver wont vacuum v3230
Make sure you put the bag in as it's designed to go in, I s**t you not I tried to use a wider foodsaver bag and cut it down but I inserted it the opposite way than it was intended to go in and it would NOT vacuum the air out. So I cut another bag to test if inserting it the correct way would matter....and it TOTALLY worked fine! Crazy how I couldn't get it to work the other way.
Jun 30, 2012 | Kitchen Appliances - Others
V3460: no response when pressing seal and inserting bag. What should I do? Thanks
  • Assuming that the unit is plugged in and the plastic bag is in the proper position.........
  • Press firmly and equally on both sides of the cover (where the three raised ridges are on each side). The 2 micro switches that start the vacuum motor are located there and require firm pressure to operate properly.
Jan 20, 2010 | Tilia Foodsaver V835 Vacuum Sealer
How to operate a Salton vacuum bag sealer?
HOW TO MAKE A BAG
1. Place the BAG SEALER on a firm level surface adjacent to a power supply socket. We suggest the bag sealer be positioned away from the edge of the work surface allowing plenty of clear space for making the bags.
2. Take the polythene roll and insert it in the trough in the sealer, positioning it so that the film is pulled of the roll from the underneath.
3.Polythene roll supplied by Salton (Cat No. 1121) is a high grade film suitablefor use in a microwave oven, boil-in-the-bag cooking and for storing in the freezer. Replacement rolls are obtainable from stockists, or in the case of difficulty, from Pifco Servive Department.
4. Plug in to mains supply socket and switch on.
5. To make the first seal on a new roll of polythene, lift up the cover and pull out enough film to project an inch (2.5 - 3 cm) or so outside the casing.
6.Now press the lid down firmly so that both the red and green indicator lights come on. In a short time - approximately 6 seconds - the green seal light will go out. AS soon as this happens lift the lid and peel of the film.DO NOT ATTEMPT TO PEEL THE FILM AWAY BEFORE THE GREEN SEAL LIGHT GOES OUT.
7.NOTE - when closing the lid and applying pressure two distinct clicks will be heard.
theses are the switches which operate the two functions of the BAG SEALER.
First click - Operates the air extraction motor. Vacuum light (RED) ON.
Second click - The sealing wire is energised. Seal (GREEN) and vacuum light (RED) both on.
8. We suggest that you famillarise yourself with the pressure mechanism before you begin using your BAG SEALER. It is perfectly safe to operate either the seal or vacuum functions with out using any polythene roll.
9. After several uses deposits of polythene on the sealing wire can reduce the effectiveness of the seal. Theses deposits of polythene can be removed by operating the seal mechanism without any polythene across the wire.
10. Having sealed one side of the bag, pull out the film to the desired bag width (MAXIMUM WIDTH is 2.9 cm / 11 1/4 inches) and seal again by closing the lid and pressing down hard.
11. As soon as the Green seal light goes out, lift the lid and peel the bag away. Ensure no film adheres to the sealing wire.
12. This seal creates your first bag and at the same time the first seal for the next bag.
SEALING A FILLED BAG (WITHOUT AIR EXTRACTION)
1.Make sure that no food or liquid remains in the top portion of the bag close to where the seal will be made as this may effect the effectiveness of the seal.
2. Place the open end of the of the bag over the sealing wire making sure that the film is flat WITH NO FOLDS OR CREASES ALONG THE LINE OF THE SEAL.
3.Close the lid and press down firmly to make the seal.
EXTRACTING AIR FROM A FILLED BAG.
REMEMBER: Do not extract air from bags containing liquid !!!
1. After filling the bag and making sure that the sealing area is free from food particles, place the open end of the bag over the sealing wire and place the black air extraction nozzle well inside the bag. It is important to ensure the the two edges of the bag under and over the nozzle are straight and not creased in any way to ensure an air tight seal !
2.Depress the lid gently until the red light comes on and hold this position to operate the air extractor. (DO NOT press so hard as to activate the the green light and therefore the sealing wire).
3. As the air is being extracted it is sometimes of help to hold the bag with your hand and gently move the contents around to help channels of air to form, so aiding extraction. Depending on the the nature of the porosity of the food some unavoidable air pockets may form but moving the contents around these can be minimised.
4.Once all the air has been extracted increase the pressure on the lid until the green light comes on. This must be done in one continuous movement, otherwise the air might seep back into the bag. Once again the bag should not be pulled away from the bag sealer until the green light goes out. Pressure on the lid should be released, the lid lifted and the bag peeled away.
LAMSBREAD :)
Sep 27, 2009 | Kitchen Appliances - Others
V2240 doesn't seal bags with liquid in it
You can not vacum liquid. If you do soups or stews freeze first in plastic container and pop out and freeze frozen food in bag. Also when doing fresh meats freeze just enough to solidify the jucies about 1-2 hours them vacum. I have had mine for five years and through trial and error have found this works excellent. Hope it helps, good luck.
Dec 11, 2008 | Tilia FoodSaver V2240
Chest freezer lid
Vacuum is caused by contraction of air. If your temperatures are being maintained the difference in how easily the lid opens and closes is not a point to worry about. If the lid wont shut after it is opened you do have a problem. If the lid is staying open at one corner try, with the lid open give it a slight twist pulling on the corner that is not closing fully. This action should spring the lid back to its original sealing position.
Jun 12, 2008 | Freezers
I own 2 of the vs220 seal-a-meal units one of which worked ok with the bags that came in it and the second is a hit and miss unit. Both were purchased at walmart. I have tried to use the last one that i...
I too bought my seal a meal at Walmart. I have gotten it to work twice. The main problem is it won't seal. I really think it has to do with the black seals....If I pull them up it sometimes will work. It is really frustrating. I would take it back but have mislaid my recept:(
Apr 12, 2008 | Refrigerators
My vacum power head wont work
fan belt might have snapped.  take off top by snapping out plastic over light.  good luck!
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Vacums
check belt not broken - could have happened when you caught tassle in head
Kitchen Appliances - Others Logo
333 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
