Question about Neptune EL70T Elysee Whirlpool 69-1/2" x 39
The timer shuts off randomly - sometimes it starts up on its own.
My Frigidaire model FFPT10F3MW stops running for hours at a time, every several days ,causing temps to rise. after 2-7 Hrs it begins cycling normally again, Sometimes for days till the next shutdown
The random shutdowns are being caused by a faulty defrost timer. The defrost timer is located at the bottom of the back of the refrigerator on the left side. It is a white box. You can attempt to reset the timer with a small slotted screw driver by placing the screw driver in the opening on the back of the box and twisting counter-clockwise until you hear or feel a click. If the reset doesn't work, you will need to replace the timer.
see
https://www.bing.com/videos/search?q=frigidaire+refrigerator+randomly+shuts+off&view=detail&mid=2D6EC6FAA19A62851F4B2D6EC6FAA19A62851F4B&FORM=VIRE
Apr 09, 2018 | Frigidaire Refrigerators
My Onkyo AV receiver keeps shutting off randomly
you should have a sleep timer mode on your remote maybe you are accidently pushing the sleep timer by accident happens to me once in a blue moon Good luck
Jan 21, 2016 | Onkyo Audio Players & Recorders
Why does the auto shut off operate erraticaly?
Defective electronic components. No reset. No adaptive learn.
Apr 29, 2014 | Krups XP604050 Coffee Maker and Espresso...
My car shuts down randomly, and sometimes will start, shake voilently and then die again, sometimes starts right back up, other times takes over an hour to run again.
1) you must pass the Scanner +computer you will have a exactly diagnostic.
2) However you must reset the ignition timing to the manufacturer specification, Does not matter if your Electronic Ignition(EI)
3) TEST the coil ignition for defective.
4) cables spark plug for open or faulty
5) spark plug for defective.
6) EI module for defective.
God bless you
Oct 05, 2012 | 1994 Mazda Navajo
Need instructions for setting Globe outdoor timer photocell model one button on/off #16UL/PC-24222
Use the on/off button to cycle through in the following order:
F = off
0 = on
1-9 = Number of hours unit stays on after detecting 15 seconds of low light
R = Random. After detecting low lux for 15 seconds, unit will select random number of hours to stay on. Will repeat randomization cycle in 24 hrs
d = On from dusk til dawn
1.-9. = (number followed by period) On now and will shut off after the indicated number of hours elapses.
Neat little timer. Have fun with it.
Nov 13, 2010 | Globe Electric Globe Indoor/Outdoor Lights...
My daughter has a Koodo samsung slide phone - it is about 8 months old. Recently it has started randomly shutting off. Sometimes when she opens it, and sometimes just randomly. IS there a setting to fix...
Hi, when a phone randomly shuts off, it means that the phones memory is faulty or when an application you downloaded has virus.
What to do is this,
You can try this code first, *2767*2878#, If this not work,
You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Aug 22, 2010 | Cell Phones
Shutdown
plz check the power supply
Jul 01, 2008 | E-Machines T6420 PC Desktop
Shutting off
i have the same problem...laptop randomly shuts down, but its even done it within a minute of turning it on so i don't think its a heat issue. Sometimes it'll run for over an hour with no problem and never shut down, but other times it randomly shuts down sometimes within a minute, sometimes maybe 10 mins, sometimes 30 mins or more ...its maddening! i'd love to find a solution if anyone's found one. Thanks.
Apr 22, 2008 | HP Pavilion dv1000 Notebook
Dryer shuts off
could be a bad timer. contacts are messed up. bacause it wont trigger the alam and turn off. or maybe, the pointer is out of calibration. i mean the pointer is not set to the correct position. you set it at 30 and you did not know is that you just set it 1 minute before off. that could happen.
Feb 21, 2008 | Dryers
Neptune EL70T Elysee Whirlpool 69-1/2" x 39 Logo
114 people viewed this question
Top Neptune Home Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
JonSnell Electronic
JonSnell Electronic
Are you a Neptune Home Expert? Answer questions, earn points and help others
