Question about Dacor Cooktops
How do I replace the LED light kit for a burner knob- PGM365-1
2 Suggested Answers
SOURCE: Kitchenaid KECC502 Electric Cooktop: LED light
I wish I had the exact answer, because I have the same exact problem!!! You posted this about a month ago, which is when my unit started having LED "on" problems. Just in the past week, the top left power on LED will not go off, and nothing I can do gets the dual large burner to come on. Any thoughts??? Reply to: mchunko@csonka.com
Posted on May 02, 2010
I need to replace two blue indicator lights and I need directions
I have replaced several of the indicator lights in the control knobs.
Turns out that Dacor doesn't sell exact replacement lights (actually LED modules).
What I did was to go to a local electronics supply store and purchase Blue replacement LEDs and a current limiting resistor to connect in series. Replacement LEDs can vary in brightness depending on your taste ... I chose a super bright LED which makes the control knobs noticeably brighter. The value of resistor will vary depending on the LED you choose (brighter LEDs need slightly more current and as such the resistor value will be slightly less).
Once you've opened the range from the top (remove knobs, grates and burners) then remove a few screws and the entire unit opens with a hinge in the back.
Look over the LED light modules which shine just below each knob and fashion a replacement LED assembly.
Total material cost per LED unit was ~ $2-3 (LED, resistor, wire and heat-shrink tubing)
Jan 04, 2011 | Dacor 36 in.PGM365 Gas Cooktop
R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
Kitchenaid KECC502 Electric Cooktop: LED light at the left rear knob is always on but the left rear burner single or dual does not work. I tried to turn knob on and off but nothing enable burner.
Mar 25, 2010 | KitchenAid 32 in. KECC502 Electric Cooktop
Ignitor does not spark on first turn as stated in manual. I have to turn the knob past "lite" before flame comes on.
Is it just one burner knob that does that are all of them? If it is just one then the igniter switch built into the burner knob might be out of alignment or loose. This happens most of the time due to a cracked switch housing(made of plastic). This can also happen if the actual burner knob is cracked and/or loose. If all the burners do this then it is just the way the cooktop works. The best way to get the burners to light is by slowly turning them on until they light and not pay attention to the "light" mark. You might need to turn it just past the "light" mark for the burner to come on.
Jan 18, 2010 | GE 30 in. JGP326 Gas Cooktop
Why is the light burning on my Corning glass cooktop?
well there is some problem with ur knob u should replace it.
Jul 21, 2009 | Verona 34 in. CTG536S Gas Cooktop
Intermittant/interrupted ignition device
The problem here is that the port holes in the burners are probably clogged. Clean ALL burners by taking a toothpick and unclogging the port holes. As for the position problem, if you have independant igniters, as some models do, you may need to replace the igniter. Remove knob and remove igniter,(white rectangular item with two wires) remove wires and replace.
Sep 08, 2008 | Thermador Cooktops
Burner light does not go off on Amana AKT3040
Sounds like a short in that particular burner circuit. Usually when the light stays on even after cool down the heat sensor is bad. This is inside the burner. If your getting white smoke the burner switch could also be shorted out.
Apr 05, 2008 | Amana AKT3040 Electric Cooktop
On light flashes
i would replace the custom control kit. elemnt usually fine that contorol kit is a new circuit board that only controls that one burner
Mar 09, 2008 | Jenn-Air 35 in. JEC9536 Electric Cooktop
Burner always on high
I have had this same problem on the JP350.
I have replaced the switch several times, and am now tempted to replace the heating element and the switch the next time it becomes constant (currently, it is intermittent... which has led to some burnt food).
Nov 10, 2007 | GE 30 in. JP340 Electric Cooktop
Disassembly to replace LED burner indicator
I'm not an expert, but I just had mine apart. You should take the panel off from beneath the control panel. This is a matter of removing about 6-8 screws and slipping the small piece of sheet metal out. You may then be able to find your "missing" LED, which is probably dangling inside the control panel assembly area. I believe there is simply a tab or other simply fastening clip that you slip the LED back onto; this holds the LED against the control panel. Assuming the LED is still working and still wired to the knob, it should work fine.
May 31, 2007 | Dacor Epicure ESG366 Gas Cooktop
Cooktops Logo
106 people viewed this question
Top Dacor Cooktops Experts
jdthefixer
Mike
Mike
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
