Question about Pool & Spa
The timer on the pump doesn't appear to function. The pump keeps running, or shuts off intermittently and starts up again without being prompted.
  • 1,631 Answers
Pumps usually do not have timers, they are installed separately, where the pump comes into that time or just like a switch, to operate it. so what we need to know here on this forum, so we can assist you better, is what are we working with? Make and model of your equipment and what is it?
Posted on Mar 30, 2015
Runs and drives, but intermittently turns off while driving.
How about the fuel delivery system, like the fuel pump. I had one where the pump would just quit and I would have to crawl under the car and give it a good whack to resume operation.
Sep 07, 2015 | Cars & Trucks
The wiperblades keep coming on in the intermittent cycle
PULL WIPER FUSE......WAIT...RE-INSERT. IF THIS DOESN'T DO IT THEN YOU HAVE A SWITCH OR WIPER MOTOR PROBLEM. I AM ASSUMING YOU KNOW THIS VEHICLE AND FUNCTIONS WELL!
Aug 20, 2012 | 2002 Dodge Grand Caravan
Pool Pump Runs Intermittently (~10 seconds on, ~1 minute off)
Need more info. What is the voltage at the pump? What voltage is the pump wired for? Sounds like your pump is shutting down from heat thru a safety. If the voltage is wrong the pump will heat up very quickly and a thermal switch will cut out, it will then cool off and try again. Get the readings at the motor connections NOT the breaker.
Apr 02, 2017 | AO Smith A O Smith Motors Century 1hp 115v...
Intermittently, my home network and internet access ceases to function. Troubleshooting indicates the "Local Area Connection" doesn't have a valid IP connection. Resetting the router (12...
Going inot the router configuration page and reserving your computer with a specific IP address would resolve this issue, If you have never gone into the router config page, it would be reccomended that you not do this, and have a computer savvy person with networking experiance do this for you.
another solution would be releasing and renewing your IP address in the command prompt on your computer
in command prompt, type : ipconfig /release ENTER then ipconfig /renew to renew your ip address, this can be done rather than resetting the router everytime
Jul 02, 2011 | D-Link DIR-615 Wireless Router
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Honeywell HZ-705.....HELP!!!!
Should have oil in it. I don't think you can refill it. If it has leaked out, it's probably no good. Anyway, here are the instructions.
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Aug 17, 2008 | Heating & Cooling
Honeywell oil radiator
Set temperature:
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Honeywell Fan
to rule out an overheat condition, if you immediately try again, does the exact sequence repeat, and again repeat...how many times without change in "only run momentarily" time? if the time "only run momentarily" never changes, then overheat is not the problem. so look for a faulty timer function that repeatedly times out. try changing timer settings.
May 30, 2007 | Honeywell HS400 Stand (Pedestal) Fan
Drainout procedure incomplete
please clarify "The lower drawer does not have a similar problem." did the "but we lowered it by about 30mm as he required." make any difference? run this test: disconnect power to the unit. then find and disconnect the drain pump's wires (or connector). then apply power to the pump (I am assuming you have a 115VAC house supply) by a separate wire cord. run the pump on this cord until you see all the water pump out. if it does, then your timer is shutting down the pump too early. the water level sensor is mostly used for the other case during water fill only.
May 25, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Pool & Spa Logo
56 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
