Question about GPS
My golf buddy pt4 keeps saying 'unfortunately golf buddyg6 has stopped' does anyone know how to get it going again, i have tried all the obvious stuff, cheers Pete
It is a new gps, it worked fine for several rounds then it stopped and told me to plug it into the usb which i did and it said it was updating, then this!!
  • 4 Answers
SOURCE: GPS 60 unit shows "Searching the Sky" status message all the time
The "New Location" fix above brought my GPS 60 back to full operation. I did reload the GPS software from Garmin but the recovery depended on well charged batteries and as above: turn the unit on
press MENU button
scroll to "New Location"
wait 10 minutes for the GPS to recover.
Posted on Apr 02, 2008
  • 3 Answers
SOURCE: Magellan Maestro 3100 stuck on
If you followed the procedure closely, you now have an SD card with your backup on it. The backup consists of two folders: BACKUP, and USBTRANS. Insert the backup SD card in your PC's reader slot and open a "file explorer" aka "Windows Explorer", not to be confused with "Internet Explorer". You will use Windows Explorer to click and drag the USBRANS folder to the Maestro.
With the Maestro 3100 connected to the PC, a couple of Explorer folders will open and you can see the file structure for the GPS in 1, and in the other one a separate file structure for the blank SD card needed for the update. Look at the file structure for the GPS and you should see a handful of folders including "SYS".
  • Start the upgrade program, following the procedures.
  • Click the NEXT button at the bottom of the procedures screen.
  • Immediately copy the backed up USBTRANS folder (and all contents) to the SYS folder on the GPS.
  • The update should now find the Maestro 3100 and proceed with the update.
SUMMARY: copy USBTRANS (it should contain 1 file: UNIT.DAT)
  • from your BACKUP SD card (not the one in the Maestro)
  • to your Maestro 3100's SYS folder.
Posted on Oct 29, 2008
SOURCE: Garmin zumo 550 map update problem
  1. Make a backup of your Zumo by copying all the file to your computer.
  2. Using your PC and MapSource select all the maps then send them to a SD memory card need 2Gig or bigger card.
  3. Try to rename this file to gmapprom.img and replace the same named file in your zumo. (I haven't tried this personally, so if it fails, just replace this with your backup and all will be as it was.)
  4. If this fails, you can use the SD memory card in your zumo and it will use this map instead, but it will take longer to boot your zumo.
Posted on Apr 11, 2009
SOURCE: I'm still waiting for valid GPS signal... 0 satellites...
Same here from like 12 to 3 every day
Posted on Jul 02, 2009
SOURCE: Magellan Maestro 4040 GPS - File Error / Inaccessible Maps
Before you update, make sure to insert the SD card in GPS. that will fix this.
Posted on May 18, 2010
My Golf Buddy GPS PT4 got wet. Removed battery; have in bag of rice. Still water under screen. Should I order replacement battery? How long should GPS stay in rice? Is there another solution? Help.
That is your bet. The rice trick. Id keep it in there for 36 hours. It will either work or not work after that period. If there is still water in there then might have to order a new unit. As for the battery I would have put that in rice too. Ya never can be too safe when it comes to water damage. If the battery did get damaged during the water incident then a new battery would likely need to be ordered.
But you are doing the right thing with the rice. Goodluck.
May 15, 2017 | bag Cell Phones
Golf buddy tour I had to take out the battery to stop my golf buddy. When I put back in the battery it would not start
It seems that the switch/relay that would not allow you to shut down the cart is now stuck in the off position and not allowing the batteries to feed the motor.
Check it out.
Apr 30, 2017 | Buddy GPS
Pt4 hand held golf buddy. It is telling me to connect USB CABLE for updates
read , understand , follow the instructions . you'll have your updates. thanks.
Mar 03, 2016 | GPS
I tried the little buddy heater in my golf cart and as soon as I move the cart the heater goes out what can I do to stop this
This is not going to work in your golf cart. This is propane based heater with a pilot light. It will go out if you drive because of the wind blowing on it. I also believe all Mr. Heaters have a tip hazard turn off. I know the two I have do. If you really want heat in your cart I would recommend an extra battery, an inverter and a porcelain electric heater. Could be made to work very nicely in your cart.
Dec 25, 2014 | Mr Heater Base Camp BaseCamp Little Buddy...
Golf buddy world does not connect to SD and turns off after thirty seconds
no car stated
nor year.
nor what the heck is a golf buddy, Huh?
does this stop car from driving?
Jun 15, 2014 | Cars & Trucks
How do I bypass the tip over safety switch on my mr heater propane heater . I only use it for golfing in a golf acrt and no inside use.But it keep s going off when it s moved or bumped
I had the same peoblem you 1.remove the 6 screws 3 on eacb side 2.remove back panel 3.remove the tip over switch attached to bottem right looks like a black plugin4.hook the 2 wires that was connecting saftey swith togetber and tape them together with electrical tape (making sure they are touching obviously)5. Reassamble and your good to go no more constant relighting
Jan 07, 2012 | Mr. Heater Mr Heater Portable Buddy...
My car cuts out!!!
try having the throttle body cleaned also check the coolant temp sender
Sep 23, 2009 | 2000 Volkswagen Golf
My google mail will not sync to my g1
Same problem here, anyone know anything?
Apr 16, 2009 | HTC G1
When i logg on my buddies wont show!
you just go to-> ichat->buddies->new instant message-> friends mail id-> then its done
Feb 24, 2009 | Apple MacBook Pro Laptop Computer with...
GPS Logo
467 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
