Temp.gauge not working and the fan runs constant with poor fuel economy.
The most likely cause is due to the radiator fan constantly running and the engine not getting to operating temperature, thats why your temp gauge isnt going up, check all related wiring to the cooling fan and make sure there no bare wires that could be causing a short to ground causing the fan to constantly run, secondly check the fan relay, if all of that checks out check the coolant temperature sensor because the information from that sensor tells the computer when to turn the fan on and off, if the sensor is bad it could be telling the computer the engine is hot when in fact its not.
