Question about Optoma Pk-301 Pico Pocket Projector Wvga
Hi I am using my projector for 2 years on optishot golf without any problem. I change my computor for a new one with Windows 8 . Windows do not reconize my projector. I sent a note to optoma Canada , and i did not have any answer from them. A f...company whit no service .....
  • talalmash Jun 25, 2015
    Hi elmer breau, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    -Connection type. Projector PC etc.
    -A screen shot of Device Manager with all sub selections expanded.
SOURCE: toshiba laptop won't work with new optoma projector
-toggle the laptop display using the FN keys and F5 I believe. -lower laptop resolution to 800 x 600 -look in laptop display properties for lcd or external display settings, see if it (external crt) has to be enabled on the laptop first.
Posted on Aug 26, 2007
Marrie
  • 563 Answers
SOURCE: Optoma DV10 MovieTime Color Wheel replacement
Hi guys
Your best bet on getting your hands on a Service Manual would be to contact Optoma themself.
As for changing the colour wheel , it is pretty straight forward if you were able to open up the unit and get to it.
The colourwheel is mounted with three tiny scrws to a bracket in which it sits. And the bracket in it's turn is fastenend to the body of the Projector with two tiny screws.
First unscrew the bracket from the casing of the Projector and then take off the three screws that holds the Colour wheel to the bracket. Replace and do the whole proses again - but obviously just the other way round.
This is really easy to do yourself.
Give me a shout if you need any further assistance.
Thanks for using Fixya and good luck.
Posted on May 07, 2008
Marrie
  • 563 Answers
SOURCE: Optoma EP732H Projector - Image is Whitewashed
Hi tourblack
I wouldn't think that this is a lamp issue , as the lamp will make the picture fade away in brightness and wouldn't look white washed.
Check if the brightness is set to 50% and the contrast on 50% as well.
This could be a colourwheel that is in need of replacement.
Posted on May 13, 2008
  • 286 Answers
SOURCE: Optoma H30 Projector: color banding
Most DLP projectors have a colour wheel. It's usually hard to get at, and you may have to actually remove everything including the optical block from the projector to access it. This wheel turns on a motor just like a fan, and if it gets dirty it can act up just like a fan.
They are expensive to replace, so you might want to try taking it apart and cleaning it out. Add a small amount of 3 in 1 oil to the motor if you can.
Posted on Nov 04, 2008
  • 3 Answers
SOURCE: color problems
i don't know if this will work but..... I have an Optoma h27 and we were having problems with the color and ours is mounted on the ceiling in inverted also; and after two years we started having color problems, come to find out that on the menu there is a option for high altitude and that had been turned to the "off" position (probably by our kids resetting all the options and not turning this one back on)..... after taking it to a tech that cleaned it for $97.00 and said there was no problems he could find, we played around with the remote/menu and came across this high altitude option and when we saw it was on the "off" position, we put it to the "on" position and another fan inside the projector came on and that helps to keep the inside of the projector cool at all time and helps from the color becoming weird..... Try this on yours and hopefully that will solve your problem.
Posted on Dec 22, 2008
Projector driver
the projector is flaw
something wrong with the mother board of the projector
something wrong with the interface board (video board)
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD, motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 10, 2014 | Vivitek Office Equipment & Supplies
Projector keeps switching itself OFF
The projector is probably overheating you need to check fans and lamp inside
May 28, 2008 | Audio Players & Recorders
My computor crashed and tec removed all from computor I dont have a code for windows 7 to activate h.p. windows intel cenrrino purchesed at Hi-Fi corp approx 3 years ago
You could use System Recovery to get your PC to factory settings, and with this you'll get the OEM Windows license again, this function is available when computer boots, but if you've formatted, changed partitions or installed a different operating system, maybe System Recovery couldn't be available.
Feb 18, 2011 | HP Computers & Internet
Replacement or buying a new one?.
Hi, this seems to be lamp only, go the menu setup and press service info : then you get the lamp hours used if it is more then 1500 hrs you must change the lamp if less, try cleaning filter then reset the lamp again. if problem persist. lamp has to be changed.
Jan 27, 2009 | InFocus IN72 Multimedia Projector
Halo lights for vw golf 1996
I ran into the same problem with my 1997 golf with a pair of halo projector lamps, i ended up going to the local hard ware store, getting about 8 screws 2 inches by 1/8 inch threaded with bolts to secure and washers (about the size of an u.s. quarter) to put in place for adjustments. you will need to bend one or two of your head light mounts (the metal where the light mounts to the car) out, so you can mount the light to the car. once u just bend the car mount from facing down to facing the front of the car, you will be able to secure at least 3 out of the 4 mounts, in my case i had to use a zip tie for the bottom-outside mount, but you might get lucky with yours.
Jun 27, 2008 | 1996 Volkswagen Golf
Epson s1
hi-
before you send it to a repair shop pls try to remove all the devices that you attach to it and check if you are still going to get those light whites after awhile, or try using a different device in which it uses a different cable, did you attach a receiver as well from the tv to projector? try changing the cables as well. update me after you performed this steps, if it resolve it pls rate as fixya if not pls reply back. Thanks!!
May 10, 2008 | Epson EMP S1 Multimedia Projector
Dell 1200mp
Hi jezzwhizz
You'll see that at the back of your Projector there is 2 VGA ports 1 in (normally blue) and 1 out ( normally grey ).
You are most probably using the grey one , switch it to blue.
May 06, 2008 | Dell 1200MP DLP Projector
Projector Lamp
Hi there
Does your Projector go in for regular services ?
Have a technician check out the fans of this unit as well.
I would suggest you hook up a UPS to this Projector , because eventhough you might not have power dips or failures - the power supplied to appliances is not spike free and Projectors struggle to handle this well.
Apr 01, 2008 | Toshiba TDP-TW90U Multimedia Projector
Projector randomly shuts off
hi CLEAN IT!! all these things leads to 1 conclusion: the device is packed with tons of dust it has a safty powerdown on heatup http://www.fixya.com/user-guide/p196016,m4858,gm38/Sanyo-PLC-XP41-Multimedia-Projector.aspx good luck
Apr 06, 2006 | Sanyo PLC XP41 Multimedia Projector
Optoma Pk-301 Pico Pocket Projector Wvga Logo
Top Optoma Computers & Internet Experts
rostit
richie46
Scott Samson
Scott Samson
Level 1 Expert
Are you an Optoma Computer and Internet Expert? Answer questions, earn points and help others
