Question about Scotts EvenGreen Drop Spreader
I need a new spring is it replaceable - Scotts EvenGreen Drop Spreader
  • 84 Answers
Yes, you will need to remove spring and take to hardware store or automotive parts store to match it up. Or you can look online at the parts list for your spreader and order it from Scotts directly.
Posted on Mar 28, 2015
How to remove door bushings
The only door bushings I am aware of are the ones on the hinge pins. Correct? If not, please clarify what you mean.
New pins come with new bushings, and the hinges are welded on so the pins are pretty much the only items replaceable. Not a fun job - because of the door stop springs you will need a spring compressor, and you will also need a special tool to drive out the old pins. However, both are available from a parts store or Amazon.
Just open the door and support it from the bottom, and then go for it, one pin at a time - for the upper pin, compress and remove the small spring, drive out the old pin, drive in the new pin and put the spring back. No spring on the bottom hinge - just replace the pin.
Apr 02, 2014 | 2000 GMC Jimmy
Replace main spring in RWS
hello friends you broke my rifle spring my rifle crosman optimus ea .177 cal. and the dealer put a new one, but it has presicion not know if I should wait for 500 shots or more like new or will be another problem, thanks for your help
Oct 08, 2012 | RWS Diana 34P air rifle - 0.177 Caliber
Need to know how to re tension pull cord spring on my baumr sx 38 chainsaw?
you need to purchace a new spring box, usually they come with a new cord attached. remove the old spring box and replace with the new one. It is not advised to try and tighten the spring on the old box.
Mar 21, 2011 | Garden
Need to replace broken front spring. would like to do it without having to compress spring. can this be done?
YOU NEED SPRING COMPRESSOR.OR REPLACE THE WHOLE NEW FRONT STRUT WITH A NEW COIL SPRING ALREADY IN STRUT DONT NEED TOOLS IF WHOLE UNIT NEW.
Oct 30, 2010 | 2001 Pontiac Aztek
How difficult it is to replace front struts on a 2003 subaru legacy wagon? I have done shocks and many other car repairs, but this would be the first experience with struts. Anything to look out for...
  • 1 Raise and support the vehicle with safety stands. While the vehicle is raised, remove the wheel and tire. This will give you access to remove the two lower bolts and nuts from the strut. Remove the upper flange retaining bolts.
  • 2
    Slide the strut spring assembly out from the vehicle. Using a strut spring tool, collapse the spring. Remove the center nut, upper bearing flange assembly and collapsed spring. Discard the old strut and replace with new strut. Discard the upper nut and replace with new nut. Do not release the spring tool from the spring.
  • 3
    Install collapsed spring with tool in place onto the new strut. The spring does not need to be replaced unless it is broken. Be sure to note the position of the spring ends on the strut. Install upper bearing flange, making note of the position of the spring end on the flange. Install center nut and tighten to specs. Then remove the spring tool.
  • 4
    Put the completed strut and spring assembly back onto the vehicle. Tighten nuts and bolts to manufacturer specifications. Install the wheel and tire. Lower vehicle.
  • good luck
    yz-maniac......
    Oct 29, 2010 | 2003 Subaru Legacy
    Front and strut replacement, how?
    Yes, you need a spring compressor. The sturt and coil spring come off as one. Then you need to compress spring to remove strut. The old one off and the new one on and then un-compress the spring and remount in car.
    Sounds simple, but it can take a while.
    Dec 23, 2009 | 1995 Oldsmobile Cutlass Ciera
    Rear springs replacement
    You will need a spring compressor first of all. You have to remove strut, compress sring to get cartridge and spring apart and then replace new spring on strut and replace into vehicle. This is a nasty job without a hoist
    Sep 24, 2009 | 1996 Pontiac Grand Am
    Struts need to be replaced, I have purchased used ones.
    Are the ones you bought complete with springs assembled? If so you can replace them as a unit. If springs are separate, you need a spring compressor to assemble them.
    Mar 21, 2009 | 2001 Mercury Sable
    I need to replace the Door Springs
    if you just need to install springs pull the bottom kickplate can do it there only two screws
    Dec 29, 2007 | Frigidaire 24 in. FDB126RB Built-in...
    Scotts EvenGreen Drop Spreader Logo
    1,006 people viewed this question
    Top Scotts Garden Experts
    Zippy
    Zippy
    Level 1 Expert
    Scott Campbell
    Scott Campbell
    Rod Doney
    Rod Doney
    Are you a Scotts Garden Expert? Answer questions, earn points and help others
