Question about Morphy Richards Vacuums
Hello. I have the 73411 model. It seems to back fire bits and the suction isn't working like it use to
Brush stopped spinning
probably 99% of the time its the belt that turns the brushes and/or the bearings on the roller brush itself have tightened up either due to being clogged or plain just worn out...pretty sure its the rubber belt though...
Apr 21, 2014 | Morphy Richards Never Loses Suction 73411...
Loss of suction
Hi there, it's Jack at Dyson.
I'm sorry to hear you've had difficulty with your DC44 Animal. It's normal for air to blow out of the back of the machine - this is where the exhaust air is returned to the room after passing through the cyclone pack.
However, if your machine doesn't seem to be picking up as well as usual and you've recently washed the filter, this may be due to a blockage. To check the motorised carbon fibre floor tool, wand and bin inlet for any obstructions, please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc44/dc44-animal/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual-dc44/no-resolved-redirect-to-check-the-wand/check-wand
The motorised carbon fibre floor tool is driven by it's own motor, rather than the machine's airflow. If it isn't rotating, the video attached should help you locate anything which could be jamming the brush bar. Make sure you remove any threads or hair from around the brush bar carefully using scissors, taking care to avoid causing any damage to the bristles.
I'm confident this will resolve the issue, but if you would like some further help you can reach the Dyson customer Helpline directly by calling us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack - Dyson Online Customer Support
http://www.dyson.com
Jun 09, 2013 | Dyson DC44 Animal Cordless Vacuum Handheld...
Beater bar not working - no variable suction
Take it to your local vac shop for repair. Depending on what model you have, it may have a bad switch or you brushroll ends could have failed. Both are common issues.
Aug 08, 2017 | Dyson Vacuums
Miele Silver Moon Losing Suction
if there's no blockages and filters all OK it's probably the suction fan that as worn down and not creating as much suction..
May 02, 2013 | Miele s558 Silver Moon Vacuum
Sebo automatic x1.1 loss of suction
Check that the dust channel from the sole plate/brush head isn't clogged. Open the trapdoor (usually orange in colour on the base) and inspect the dust channel - sometimes dog hair can get trapped between the main dust channel and the feeder. Other than that take off the main hose and see if there's a clog down there as well as the main part where the wand locks in at the back. Its reasonably easy to get a clog out from a Sebo X range model.
Jan 16, 2009 | Vacuums
Dysan DC01 No suction
Hi.
Check that the black rubber flaps at the bottom back close the holes in the chasis when you switch on.
Let me know how you get on.
http://dysonmanuals.inc.io/
Chris.
Dec 01, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Attachment hose has no suction
Sometimes when you take them apart and
reassemble the vac (the plastic slide doesn't
make full contact with the lever,or it isn;t on
the lever at all) that switches
from the floor to the attachment. IF Tthere
are no clogs in the duct then that the
most likely problem
Nov 18, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Vacuums Logo
76 people viewed this question
Top Morphy Richards Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Morphy Richards Vacuum Expert? Answer questions, earn points and help others
