Question about Wella Color Charm Liquid Permanent Hair Color #BP
What color will I get with Wella 633+ 892
Will I get a bright red? Can I get a picture?
I have natural lt brown hair w/ blonde highlights. I wanted a more uniform color and to get rid of the grey. I bought wella color charm 811/8n light blonde and used 30 volume developer. Left it on the...
Gray hair is resistant to accept color.....You might try to find one of 2 products: " Zotos Porosity Equalizer" from Sally's or any beauty supply store. Also, Clairol has a new formulation called "Gray Solution", where there is a cream added to gray hair prior to adding color. This is for next time you plan to color.
In the meantime, you may want to purchase Roux Fanci-Full Color Styling Mousse in either #19 or #18 to tone down the red tones from your local beauty supply or online.Good Luck
Jul 18, 2011 | Wella Color Charm Liquid Creme Haircolor...
My hair is yellow on top and orange on bottom from bleaching it. would wella regal beige T27 tone it to a light blonde?
no I don't think it would. A beige is a red violet base. if you are orange you need to use a blue or ash based toner and a violet toner for the yellow, this will counter act the un wanted pigment. Not sur what to recommend in wella. I use redken at work.
Jun 03, 2011 | Wella Color Charm Toner #T27
Hi im a hairdresser, i used revlon 666 and a bit of 6n in with it on blonde hair as low lights but a week later red has washed out? what can i use in with the red to make red last longer on blonde hair?
Well i will suggest you to try Wella Viva Color Pure Red , it is an amazing color and its isbeing rated 3 out of 5 by common womens, they tried and found it awsom, TRY it once
Apr 14, 2011 | Revlon Colorsilk Hair Color 4N Medium...
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picture is pale, yet reds are bright. checked color, brightness, and conversion settings. TV seems unresponsive to the color, tint, and brightness adjustments.
open the back and look into the projectors red blue and green should be clear picture if its blurry need to change the coolant if its not on need to replace the projectors
Aug 22, 2009 | Philips 50P8341 50" Rear Projection...
Will not show red color in picture, magic focus shows red though
You have a projection light element out. I had the green element go on mine. I had a service agreement so a repair tech changed it.
Feb 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Aadjusting screen colors
They should be adjusted to set voltages. however it is best to shut the color level to the lowest setting then try t balance the screens to achieve the best black and white picture. then turn up your color level. Your brightness level should also be set to 50 % then when you adjust for the best B&W picture. You will have better color and brightness when you reset your color and brightness levels. Hope this helps.
Feb 01, 2008 | Hitachi 57F500 57" Rear Projection...
Brightness of picture
If you feel good about opening your set then you can try this: Look for the flyback (high voltage) transformer, with the thick red wire which goes to the top of the picture tube. There are 2 controls on the flyback transformer, focus (top) and screen (bottom)Turn the brightness and contrast all the way down and then increase the screen control until you see retrace lines, and then back it down until those lines just vanish. Return the brightness and contrast to normal and adjust the focus control, if necessary, for a nice sharp picture. Let me know if that brings your brightness back.
Aug 21, 2007 | JVC AV-27D104 27" TV
Running out of Brightness
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 23, 2006 | Hitachi 53SBX59B 53" Rear Projection...
Wella Color Charm Liquid Permanent Hair Color #BP Logo
21 people viewed this question
Top Wella Health & Beauty Experts
Steve Macqueen
Steve Macqueen
Stan Ford
ray gallant
Are you a Wella Health and Beauty Expert? Answer questions, earn points and help others
