Question about Danze D455158SS Single Handle Pre-Rinse Kitchen Faucet
How to replace ceramic cartridge in a danze D455158 D457158
I have a replacement get the ht cartridge need to figure out how to stall. How do you handle off ?
  • 50 Answers
SOURCE: Danz cartridge removal
Loosening the set screw behind the small plastic hot/cold plug will allow you to lift the handle straight up. You may need to jiggle it a little bit or twist it, just pull straight up with the faucet handle down and centered. Once the handle comes off, Then the collar should thread off exposing the inner workings of the faucet. You should then be able to unthread a bunch more components and washers until the cartridge top is exposed (depends somewhat on whether it is a pullout hose or seperate sprayer...not sure exactly what model you have but this is the standard for a single handle kitchen faucet...)
Here is a link to a page that shows how your (hopefully your) faucet goes together... also includes the re-order info for cartridge (#8)...
http://www.ajmadison.com/ajmadison/itemdocs/D403412-chrome_parts[1].pdf
I would also check the supply stops to make sure they are not clogged, because it is definetly a sediment problem.
Posted on Feb 09, 2009
bearsfan7538
  • 119 Answers
SOURCE: How do I remove the handle to check the Cartridge
You need to hold handle lever and unscrew the bottom escuteon plate you may need a small strap wrench it will turn counter clockwise. On some older models there was a set screw on the handle which you would use an allen wrench
Posted on Nov 15, 2009
  • 760 Answers
SOURCE: Bought a home, main kitchen faucet is a Danze NSF
I'm not familiar with a NSF 61/9, but I've used several other models. I believe these are all ceramic disc valve. They almost never wear out. If you remove the handle and the trim cap or bonnet, there should be a nut or adjusting ring you can tighten. Don't over do it. The handle give you quite a bit more leverage than the small tap when it is removed. Here is Danze web site and you can look up your exact model number and see a exploded parts list: www.danze.com
Posted on Jul 12, 2010
  • 679 Answers
SOURCE: I have a single handle Danze faucet. I can remove
Hi Sir you can check out this link from Danze FAQ for troubleshooting. http://www.danze.com/faq.asp?page=1&id=27&seltopic=0&selsearch=
Posted on Jan 23, 2011
  • 12 Answers
SOURCE: I have a Danze Opulence
below the cartridge should be some rubber washers if its the model im thinking of, try those. if not sounds like the whole valve needs to come out....
Posted on Jan 27, 2011
Danze shower on off valve leaking. How do i repair it?
This a common problem with most shower valves.After time the internal parts of the valve wear and need to be replaced. You can purchase a new shower cartridge for about $50.00 at your local hardware or on line. Be sure to turn off the water before removing the old cartridge. Install instructions should be included or go to Danze.com
Dec 02, 2016 | Danze Home
New danze cartridge no water
Possible issue with pressure balancing cartidge, When you remove parts, turn off water, remove parts, slowly turn on water and see if brass valves lets water out. If yes pressure balancing cartridge or cartridge itself is defevtive.
May 18, 2014 | Danze Home
I have danze single handle shower head leaks when turned off
you need new seats and springs that are in cartridge...replace them or buy the whole cartridge and replace that....turn off water and install new one you can buy at lowes or your nearest plumbing supply...good luck
May 09, 2012 | Danze Home
Danze UPC tub/shower valve leaks constantly at tub spout
shut off water and pull cartridge...go to lowes or plumbing supply and match up cartridge and replace...you may also just replace seats and springs if cartridge is ok....cheaper...but if not sure just replace whole cartridge...make sure hot is on left...
Aug 15, 2011 | Danze Home
Need an instruction sheet for cartridge replacement for Danze Sheridan tub and shower faucet
This link will get you to the Danze illustrated parts list for the Sheridan single control tub and shower valve.
http://www.danze.com/products/pdfs/D510055_ip.pdf
Aug 08, 2010 | Danze Sheridan Tub & Shower Faucet
Selecting phono preamp for Onkyo HT-R510
The magnetic cartridge preamp should work with the turntable, as presumably it will have a magnetic cartridge in it. The only reason that the amp states "magnetic" is that some very old turntables have ceramic cartridges which should not be connected to that terminal. Even if the turntable had a "ceramic" it could be replaced with a magnetic one!
Mar 21, 2010 | Onkyo HT510 Receiver
My faucet drips and i believe there is no way to change the washer out. What can I do?
danze has a cartridge, if you have two handles you can turn the water off under the sink and isolate which one is leaking if you cant figure it out you can just take both of them out and have them both replaced. if it's a single handle there will just be one cartridge in there. you will have to remove the handle and a few other things and it should just pull right out of there. if you call danze they might send you some free cartridges if you ask nicely!
Aug 05, 2009 | Danze Plumbing
Danze D455158SS Single Handle Pre-Rinse Kitchen Faucet Logo
146 people viewed this question
Top Danze Plumbing Experts
David Wiebe
Level 1 Expert
Donni Steen
john h
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
