Question about Lexmark Office Equipment & Supplies
Lexmark copier 5650 - says cartridge error - consult user's guide - can't find user's guide -what to do?
Ajkill
  • 2035 Answers
SOURCE: my Lexmark is X6100 Series - Cartridge Error 50C consult user guide
Cartridge Error 50C
Your print cartridge has shorted.
1. Power off your All-in-One and unplug it.
2. Plug in your All-in-One again and turn it on.
3. Uninstall and then reinstall your cartridges.
4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
1. Power off your All-in-One.
2. Use both hands to lift up the scanner unit until the scanner support holds it open.
3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
4. Remove the color print cartridge.
5. Lower the scanner unit until it is completely closed.
6. If the error message reappears, replace the black print cartridge with a new print cartridge.
If it does not repeat steps 1-3 and then go to step 7.
7. Reinstall the color cartridge and remove the black print cartridge.
8. Lower the scanner unit until it is completely closed.
9. If the error message occurs again, replace the color cartridge.
10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
11. Lower the scanner unit until it is completely closed.
12. If you receive the error message again, replace both cartridges.
Posted on Mar 15, 2008
vegakitten20
  • 685 Answers
SOURCE: cartridge error 1203 consult see user guide on display panel
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would request you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
Posted on Jan 19, 2009
d2704
  • 101 Answers
SOURCE: Lexmark P6250 Printer error 1203 - Consult User Guide
It is a hardware printing problem . Try to clean contacts in printers in cartridge holder by alcogol and elastic rubber. it may become dirty an poor contact. after this you can try this:
Put some layers of the sticky tape on cartridge to improove force of contact.
Posted on Mar 07, 2009
  • 684 Answers
SOURCE: paper jam in lexmark all in one x7170
It insists there is a Cartridge problem on the Printer............ In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Move the Catridge Carrier which holds the Catridge Back and Forth for abt 20 Times as fast as u can.............
Turn On the Printer........
Good Luck...........
Posted on Apr 05, 2009
e-ware
  • 776 Answers
SOURCE: Cartridge error
Error 1203 is a very interesting error which normally means that your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges.
Check to see if ink are smeared on the holder where the contact panel with the catridge.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
To reset the error code, disconnect the power cord from the wall. Also remove the power brick from the back of the printer for 60 seconds. Then connect everything again.
Please let me if this information helped.
Please rate me if you are haapy with the solution.
Posted on Sep 15, 2009
Lexmark X5650 cartridge error consult user's guide
Don't know for sure, but I found some user manuals on amazon, which can be helpful... take a look here: Amazon com lexmark manual I hope this helped you. Have a nice day
Mar 23, 2012 | Lexmark X5650 AllInOne InkJet Printer
It keeps saying cartridge error/ consult user guide 1203 Have replaced the cartridge
Did you replace with Generic Ink or Lexmark Ink Cartridges? See your Printer's Documentation and check to see if your printer will only use Lexmark ink.
Aug 10, 2010 | Lexmark X7170 All-In-One InkJet Printer
Ive a lexmark x4270 tried to copy says consult user guide for error #1203 and i dont have a users guide. anyone know what i need?
The error #1203 on the Lexmark X4270 indicates a problem with one of the ink cartridges. You can try to check this link - http://bit.ly/ckmSbC - for the steps that will help you resolve the problem. If it still the small I would suggest contacting Lexmark Technical Support. Thanks.
Aug 08, 2010 | Lexmark X4270 All-In-One InkJet Printer
Cartridge Error # 1203 when replacing black ink cartridge
It sounds like the printer thinks it is not a genuine ink cartridge. Fit a Lexmark cartridge to cure it.
Jul 16, 2010 | Lexmark X8350 InkJet Printer
We have a lexmark p4350. we cant get it to print
The error indicates an error in communication either between cartridges or the cartridges and the printer. Here's an article in the Lexmark website on 1203 Error Message on the Lexmark P4350 / P4330 Photo All-In-One. Just click on this link: http://bit.ly/9sK9hE. This should guide you on what to do.
Jul 05, 2010 | Lexmark P4350 All-In-One InkJet Printer
Mar 06, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Cartridge error 1203 consult see user guide on display panel
Jan 19, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Cartridge error
i have a lexmark p4350 and just recently got a eror message 1102, says consult user guide, cannot find that error message in the guide, what is it, thanks
Sep 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Cartridge error error 50C consult user guide
Hello, error 50c is a cartridge issue. Try taking out, cleaning heads, returning and reprint. Cheers lilacgerry xxx
Dec 02, 2007 | Lexmark X6170 All-In-One InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
