Question about Music
I have a Kawai CN-2 digital piano that has worked fine for years. Recently, there is a constant white noise in both speakers that gets louder and softer when I turn the volume up and down. I've taken it apart and don't see any problems with wire connections, and can't find any mechanical thing that causes the noise to change for the better or worse. I've also tried different plugs, made sure there was no interference from other electronics, etc. Nothing seems to change the white noise situation. Does anyone know what might cause this type of white noise problem? Thanks, Tony
    Top Expert:
  • Music Master
  • 3,141 Answers
Sounds like a filtering cap is going bad. I'd suggest a repair shop.
Posted on Mar 28, 2015
How to reset kawai z 1000 piano
RESET / Hold these buttons or keys and power on Insert System disk. Hold POPS and power on. Display shows FIND SYSTEM and starts the loading process. Which version do I have? / Hold these buttons or keys and power on Input the following number code: 00009584 or look at Start Screen Which version is the latest? 2.46 How can I get the factory sounds back? RESET
Mar 24, 2016 | Kawai Music
Kawai mr-370 digital piano. Why is it stuck on the loudest volume and does not respond to the volume control slide?
The solder contacts on the fader may not be connected to the board. It may also be a software glitch. If you reboot / initalize the instrument it may fix it.
Dec 28, 2015 | Music
Some buzzing in left speaker when low notes played
A couple of possibilities
One the speaker broke loose, typically there is lock tight on the threads that hold the speaker in place, lower frequencies can also cause buzzing noise,
I have fixed this problem in the past with a hot glue gun, running a small bead carefully around the edges of the speaker, bonding it to the unit,
Another possibility is the speaker is blown or worn out, over time speakers can weaken from constant use and coil movement, in this case the speaker should be replaced...
Hope this helps?
Mar 13, 2015 | Yamaha P-105 Digital Piano, Black
What is the piano age by serial number 1872
Hello, you will need to look inside the Factory's site. Generally, they put a link to this purpose. If not possible, try a search section in Google, using words like: "serial number" age piano Kawai, changing the Kawai word for the name of the maker of your instrument.
Aug 24, 2014 | Music
I Have a Technics PR-305 Digital piano that I have for a little over 12 years ago that I enjoy playing on very much, I have a distortion problem in my speakers it`s not very bad I was told in Fixya th
The Speakers can be replaced with any brand. The thing you need to know is the OHM rating for the speaker. OHM is also called impedance. Unless the sticker has fallen off the back of the speaker that information will be on that sticker. OHM rating MUST match the old speaker. For instance 4 OHM, 8 OHM, 16 OHM are common ratings. All different ratings but VERY important to get this correct otherwise you could damage the electronics of your instrument.
Aug 13, 2017 | Music
Hi, I just got a new williams allegro digital piano, and the right speaker sounds noise with low keys.
If this is a brand new unit, exercise your warranty!
BUT FIRST see if packing material worked through the speaker grill... you know littel pieces of the packing peanuts or otherr contamination that sits in the speaker cone and rattles.
Feb 12, 2011 | Williams Allegro 88-Key Digital Piano
I have a Roland HP 101 digital piano however certain dont sound
White spirit is NOT what you should use. Mineral spirit leaves a residue film.
Use 99% isoprophyl alcohol.
ALSO inspect the contactboard for cracks by candeling with bright light behind it.
Oct 31, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Music Logo
53 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
