Question about Ab Lounger Sport Exercise Equipment
Where can i get a new cloth cover. ours split so if i can't find one it is no good anymore
The actual cloth cover that you sit in split. I need to know where to get a new one or if I can.
Does uncovered firewood stored outside go bad?
Sounds like someone cut down some trees and stacked them in your yard. Most likely, it is good firewood. Actually, covered wood rots faster than air exposed wood because of lack of venting or direct exposure to the sun which dries up exposed wood. Covered wood stays wet longer which accelerates rotting. Thick round logs are hard to burn because they are not split. If you feel up to it, you can split them and burn them in your fireplace. Good healthy exercise!. If not, then Crags list would be my choice also.
Briketter
Dec 15, 2012 | Woodland International Chainsawbuddy...
Fan in the Simpson Sirrocco 500 clothes dryer doesn't work.
It is both easy and cheap! I do believe there is a cover on the back of this model hiding the drive belt for the fan. It has iether broken or come off. If it has come off and lint or something of the like was not the cause it is quite possible that it has stretched and will require replacing =)
Feb 25, 2010 | Dryers
I have an old Goodman(1985) unit and the cover the cracked
tough to tell by the age they probably dont manufacturer parts for that model anymore try calling a goodman wholesaller otherwiseupgrading to a new 13seer unit will cut your operating cost in half
Jul 08, 2009 | Goodman CKL24AR24 Air Conditioner
Mini Split Condensation Problems!
Maybe you need to invest in a good De-Humidifier.
Jul 08, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Lint from washing machine
Fill the tub to the bottom of the agitator with hot water and add 1/2 to 1 gal of white vinager and let it sit for a few hours. Spin out the water and run thru a light load without clothes. When you are running a load lift the lid and observe the clothes movement, The items should be circulating from top to bottom. If they are just wiggling around it is overloaded and the clothes do not have room to move. This wears on the fabric creating lint. The agitator is for the water not the clothes contrary to popular belief. The clothes are actually washed with the water movement not beaten by the agitator.
Eric
Jul 02, 2009 | Washing Machines
Owned our Nespress for 1 yr and now it will turn on
The company will tell you to turn upside down for 24 hours to reset. I did and this did not work, you may have gotten base wet, which can break machine. Try turning upside for aeroccino upside down for 24 hr. you do not need to do this to the base. They told me if this does not work, I need to buy a new one. I hope you have better luck. I am on my third one. you may be covered under warranty- call Nepresso soon..they cover them for about 1 year. Good luck
May 15, 2009 | Nespresso Aeroccino Automatic Milk Frother
Weider home gym maintenance
about every month, i spray the pulleys with WD-40 and then spary it into a cloth that I use to wipe the cable covering...my gym is 4 yrs old, sits out on my covered back porch and the cables and pulleys are like new
Mar 16, 2009 | Weider Nutrition Weider WEBE8077 Home Gym...
Dryer not drying
look at the vent outside and see if it closing or even has a cover this allows cold air inside the dryer and cause it to take longer to dry
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sit 'n Stroll Stroller
The manufacturer should be able to help you with any replacement parts that you may need.
http://www.tripleplayproducts.com/napsac.asp (800) 829-1625
Good Luck! from Moms Just Know
Oct 21, 2008 | Safeline Sit 'n Stroll - Shoreline...
Ab Lounger Sport Exercise Equipment Logo
639 people viewed this question
Top Ab Lounger Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Ab Lounger Exercise and Fitnes Expert? Answer questions, earn points and help others
