Factory Reset including Admin/Supervisor Passwords
Can anyone tell me how to reset all the passwords on this machine without having the password?
  • 2072 Answers
SOURCE: reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Posted on Apr 03, 2008
spinal
  • 287 Answers
SOURCE: Canon ir C3100 Admin Password
Hello skunkel,
Yes, I believe I can help you. Hopefully these previous admin person did not go nuts with the security thing. But I can help you either way. The least painful method. Approach the copier and view the operator control panel as we are going to go into service mode and delete the admin password. I am about to describe a "fluid 3 step keystroke " function which will put you into service mode. Before we start , locate the "ADDITIONAL FUNCTIONS" button located between the LCD screen and the 9 key pad. Now, press additional functions, then the numbers 2 and 8 simultaneously, then back to additional functions in a smooth three step flow. The screen will change as you have entered service mode. Depending on the configuration of the device you will have several tabs in your display and copier will be at the top. Press copier. A new display appears with several tabs across the top. Press the function tab. New display again, and now press "clear". New display again. Look for "PWD-CLR". Once found, press it. It will be highlited,and then press the "OK" button in the lower right corner. The ok button will indicate you have touched it by beeping or highlighting or both (depends on the model). Then turn the main power off (the actual switch not the button on the op panel. If you are in doubt unplug the machine. After a few seconds re-energize the copier. If the previous administrator merely used a password then it is now deleted and you are home free. If not, then you will need to enter service mode again.......copier........function.......clear..... and then find MMI . Clearing this field will delete ALL customer inputs(IP address, favorites etc). If it is necessary press MMI and then ok. Usually you wont have to do this. But if you do you can have the fun of re-entering all your old settings as it will go back to factory settings.
Posted on Jul 31, 2008
SOURCE: how to reset admin password?
Feature 985 press 9 pwd:  73738767793
Posted on Jan 27, 2009
SOURCE: cect i9 passwords
pass: 1122
Posted on Feb 21, 2009
  • 18 Answers
SOURCE: reset group passwords on omnivx570
try 23378463
Posted on Mar 26, 2009
Forget administrative password
It's common that an Acer computer user often happens to forget his or her admin password. Here I find a professional tool to reset windows passwords. It's called "Windows Password Key". It can reset any windows login passwords including user or admin passwords without any data loss. More information you can visit http://www.lostwindowspassword.com/
Jul 29, 2014 | Acer " 21.5"" Touch-Screen All-In-One...
Tip
Forgot my password.
If you ever forget your password to your router you can look up the default password online.
Most default passwords for linksys is: login=blank password=admin
Default passwords for belkin is: blank
Default passwords for netgear: login=admin password=password
Default passwords for d-link: login=admin password=1234 or password.
if none of the passwords work then you can reset the router to factory defaults by holding the reset button in with a paperclip for 30 seconds while powered on. This will erase any customized settings and apply the factory default settings. If the password doesn't work please check with your device manual.
on Feb 23, 2012 | Linksys Computers & Internet
Tip
Four Most Common Password Reset Solutions for Lenovo ThinkPad
<span> <p><img src="lenovo-thinkpad.jpg" />Lenovo ThinkPad Laptop password reset or recovery solution varies depending on which password you have forgotten. The hassle of<span> </span><a href="http://www.passwordunlocker.com/knowledge/reset-lenovo-thinkpad-password.html">Windows password reset</a><span> </span>process will range from simple inconvenience to total valuable data loss. For this, we have collected the most used Lenovo Computer password lost troubles and satisfactory solutions for you.<br /><b>Types of passwords for Lenovo ThinkPad Laptop</b><br />There are four kinds of passwords we will talk about Lenovo ThinkPad computer and the password reset solutions:<br /> <ul> <li>1&gt; Windows logon Password (Administrator, Domain and User account)</li> <li>2&gt; Supervisor Password</li> <li>3&gt; Hard Disk Password (Master and User)</li> <li>4&gt; Power-On Password</li></ul><br /> 1&gt;Windows logon Password for Lenovo ThinkPadWindows logon password for Lenovo ThinkPad is used to keep personal information private and we are always create some administrator or user accounts on Windows 7/Vista/XP PC and also domain admin or AD accounts on Windows Server 2000/2003(R2)/2008(R2). It will be a big besetment when you lost or misplaced the passwords of those accounts. However, with some easily password recovery ways, it is possible to re-access your Windows system with no damage of the data.<br /><b>Reset Lenovo ThinkPad Password with Password Reset Disk</b><br />If you are a cautious user, then you should have created a password reset disk for your Lenovo ThinkPad. So you just need to insert the password reset disk to<span> </span><a href="http://www.passwordunlocker.com/knowledge/reset-windows-7-password.html">reset Lenovo ThinkPad password</a><span> </span>directly.<br /><b>Reset Lenovo ThinkPad Password with Available Windows Administrator Account</b><br />If you can log on as an administrator for your Lenovo ThinkPad with a right password, then you can reset any other passwords of your lost or forgotten Windows logon accounts directly.<br /><b>Reset Lenovo ThinkPad Password with Windows Password Recovery Program</b><br />If you have not created a password reset disk previously, or cannot log on as an administrator with a right password, and for this situation, like me, you still have option to reset lost password for Lenovo ThinkPad PC with third-party software.<span> </span><b>Windows Password Unlocker</b><span> </span>is such a powerful Windows password recovery tool which enables resetting windows 7, Vista, XP, 2000, 2003 and 2008 password as blank with 4 easy steps:<br />1. Download and install<span> </span><b><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows Password Unlocker</a></b><span> </span>from its official site with an available PC<br />2. Burn a bootable CD/DV or USB flash drive<br />3. Reboot your locked Windows computer from CD/DV or USB flash drive<br />4. Reset lost or forgotten Windows password for Lenovo ThinkPad with easy<br /><b>Reinstall Windows OS</b><br />Reinstall Windows operating system for your Lenovo ThinkPad will be the last choose if you can reset Lenovo ThinkPad password successfully with those workable solutions that have mentioned above.<br /> 2&gt; Supervisor Password for Lenovo ThinkPadA Supervisor password protects the system infor stored in the BIOS. The user must input the Supervisor password in order to get access to the ThinkPad BIOS Setup Utility in order to alter the system configuration. If the Supervisor password is lost there is no way to recover it to enter the BIOS configuration.<br /><b>Reset Forgotten Supervisor Password</b><br />A forgotten Supervisor password will prevent access to the ThinkPad BIOS setup utility. To get access, you need reset the BIOS password with some solutions like locate the jumpers or solder beads, or just contact the computer manufacturer or motherboard manufacturer for resetting forgotten Supervisor password.<br /> 3&gt; Hard Disk Password for ThinkPad ThinkPadThere are two Hard drive passwords: a user Hard drive password for the user and a master Hard drive password for the system administrator. The administrator can use the master password to get access to the hard drive even if a user has changed the user Hard drive password.<br /><b>Reset Forgotten Hard Drive Password</b><br />If the user's Hard drive password has been forgotten, check whether a master Hard drive password has been set. If it has, it can be used for access to the hard drive. If no master Hard drive password is available, or if the administrator forgets the master Hard drive password, then the hard drive must be replaced. For this instance you just need ask help from your computer manufacturer to reset forgotten HDD password.<br /> 4&gt; Power-On Password for Lenovo ThinkPadAn Lenovo ThinkPad Power-on password protects the system from being powered on by an unauthorized person. When it has been set, a prompt will appear during the system start up, and the Power-on password must be entered before an operating system can be booted.<br /><b>Reset Forgotten Power-on Password</b><br />If the Power-on password is forgotten and the Supervisor password is known, simply go into the ThinkPad BIOS setup utility and reset the Power-on password, otherwise try the following:<br />1.Power off the Lenovo ThinkPad computer<br />2.Remove the battery pack<br />3.Remove the backup battery<br />4. Please power on the computer and wait till the POST ends. If the password prompt does not appear then the Power-on password has been reset.<br />5.Reinstall the backup battery and the battery pack.<br /><b>Note:</b><span> </span>Some ThinkPad systems have the ability to reset the Power-on passwords in the ThinkPad BIOS setup utility if a Supervisor password has been set.<br /></span>
on Apr 19, 2011 | Computers & Internet
Forgot admin password how do i get reset
what OS ? Frankly this question has been answered so many times, you SHOULD be able to find it by searching for :
lost password (whatever OS you have)
Tallon41
Sep 17, 2012 | E-Machines eMachines T3830 PC Desktop
Ibm thinpad t40 is locked unable to open
HI............
Reset IBM ThinkPad Password
An IBM ThinkPad laptop can have three hardware password sets:
  • Power-On Password
  • Hard Disk Password
  • Supervisor Password
Power-On Password RT/CMOS RAM has 8 bytes reserved for the power-on password and the check character. The 8 bytes are initialized to hex 00. The microprocessor can access these bytes only during POST. After POST is completed, if a power-on password is installed, the password bytes are locked and no program can access them.
During power-on password installation, the password (1 to 7 characters) is stored in the security space.
Installing the password is a function of the built-in system program Easy-Setup. The power-on password does not appear on the screen when it is installed, changed, or removed. After the power-on password has been installed, it can be changed or removed only during POST.
Hard Disk Password The hard-disk password (HDP) prevents unauthorized persons from accessing the data on the removable hard disk drive.
Supervisor Password The supervisor password prevents unauthorized persons from changing the system information in Easy-Setup.
thinkpad.png How to Reset an IBM ThinkPad Power On Password using Software If the user can boot the IBM ThinkPad, KeyMaker will recover the BIOS password.
How to Reset an IBM ThinkPad Power On Password Using Hardware If the ThinkPad cannot be booted, reset the IBM ThinkPad password via hardware.
If only the power-on password is set, do the following to remove the power-on password.
  1. Power off the computer
  2. Remove the DIMM cover on the bottom side of the computer.
  3. Short circuit the two password pads or put a jumper on the contacts to short the circuit.
  4. Under the short circuit condition, power on the computer and wait until the POST ends. After the POST ends, the password prompt does not appear. The power-on password is removed.
  5. Reinstall the DIMM cover.
If both the power-on password and the supervisor password are set, do the following to remove the passwords:
  1. Press and hold F1 to power on the computer.
  2. Enter the supervisor password. The Easy-Setup menu appears.
  3. Click the Password icon.
  4. Click the Power on icon.
  5. Enter the supervisor password and press the Space bar.
  6. Press Enter twice.
  7. Click Exit then click Restart.
GOOD LUCK......
Sep 26, 2011 | Computers & Internet
I have a IMB Note book and I forgot the power on password I put on it. I want to unlock it. Please tell me how.
If it's a "Power up" password this can be removed by briefly dosconnecting the cmos battery from the system board. If it is the "Supervisor" password either send to Lenovo for replacement system board and hard drive (not covered under warranty) or send to me and I will return unlocked :-) fixmythinkpad@btinternet.com Regards Paul.
Feb 05, 2011 | IBM ThinkPad T21 Notebook
User password lockout
Hard disk password is set from the BIOS. It is usually set in conjunction with the Power On Password. This password is stored on the EEPROM chip and is very difficult to crack - no backdoor passwords. It is used to prevent unauthorized access to the laptop and the data on the hard disk. Removing the hard disk and inserting it into another computer will not allow access to data without the HDD password.
Apr 22, 2009 | Dell Studio 1537 Laptop
Admin password!!??
Emergency Boot CD is a download you can find many places. Burn to CD and then boot off of CD, it has an option to change user passwords, including Administrator.
Here is a link to download
http://www.brothersoft.com/emergency-boot-cd-62611.html
It is FREEWARE meaning you can use all you want and never have to pay.
I actually used the Admin reset functionality. I fix computers for my church, and whoever used the computer last put a admin password on it and then left the church. I was able to reset and get back to a working computer without any problems. Works great.
Dec 14, 2008 | E-Machines C3060 PC Desktop
Password for belkin router
If you have the router, the default username and password is usually printed on the bottom if not try these.
Username | Password
Admin (none)
Administrator (none)
Admin password
Administrator password
Admin admin
Administrator admin
try these in any order and switch round passwords to usernames these are the default passwords, if these dont work, then a simple push button reset will sort you out.
Ben.
Feb 07, 2008 | Belkin (F5D7230-4) Router (587009)
27 people viewed this question
k24674
