Question about Engel 43 Qt.Portable Freezer.
Noisy when compressor starts
Tried remove cover clean motor area including fan blades seemed quieter but now become noisy again
  • Engel Master
  • 5,323 Answers
MAY BE LOW ON FREON OR;
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Read more:http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
Posted on Apr 04, 2015
Started to be noisy when compressor starts up. Tried cleaning dusting motor area including fan. Seemed quieter but becoming noisy again
Mar 28, 2015 | Refrigerators
I have a noisy fan, it gets quieter when the frost setting is turned down
your fan motor touching the ice formation when occur..adjust your fan motor blade,or your fan motor .to avoid making noisy all the time.
Jul 11, 2011 | Refrigerators
Refrigerator is making a very loud humming noise...yes, it is old, did turn off and restart, it was quieter for awhile but noise came back. Any suggestions?
A noisy chest freezer can be more than aggravating, it can also be a sign that something may be wrong with the appliance. With a little investigation, you will be able to find the cause for the noise so that you can determine how to rectify it.
Self-defrosting
If you chest freezer is a self-defrosting variety, you will find that it has a fan on one of the inside walls that enables this process to take place. Open the door and check whether this makes the sound worse; if this is the case, the problem is likely to lie with the fan. Ensure that it is not blocked by any food items or ice and is running properly. Clear away any items that are blocking it and tighten any loose fasteners. The motor that runs the fan can also cause a noise if it is old or defective and is struggling to continue running, if this is the case, the motor will need to be replaced.
Door Seal
Examine the door seal of the chest freezer to ensure that it is intact and has no defects. If there is a problem with the seal, it can prevent the door from closing properly which will force the freezer to work harder as it will also be cooling the air around the freezer. Replace the door seal and ensure that the door is able to close properly to see if this reduces the noise.
Element
The wire element that is either located on the rear or the base of your chest freezer. The element can often become noisy after getting covered in dust and debris. Rectify this by switching off the power supply before vacuuming the element. Carefully use a cloth to clean any other surrounding components that are affected by stubborn grime.
Ice Build Up
Where your chest freezer is unable to regulate itself, you may find that it can suffer a buildup of ice. When the ice become sufficiently thick, it will stop the freezer from being effective and will force the motor to work harder in order for it to keep working. Prevent this problem by defrosting your freezer on a regular basis or whenever it is required.
Condenser Fan
The condenser fan is likely to be located at the rear of the freezer and can become noisy if it is defective or covered in dirt. After switching off the power supply, use a cloth to clean the blades of the condenser fan if you find that the noise is coming from this component.
Compressor
The compressor is the black box that you will find on the base or rear of your freezer and is where the normal noise of the running the freezer comes from. The pipes and wires necessary for the freezer to work stem from this box and can become noisy if there is a problem, which is more likely with an older appliance. A defective compressor cannot be repaired so it will need to be replaced.
Take care in solving the problem.....
May 12, 2011 | Refrigerators
I have a noisy cooling fan. I have cleaned and removed all the dust from the vents in the compressor compartment, but the fan still make a squeeking sound. Can the fan be oiled or greased or should it...
Is the area between your fridge and freezer smoking hot? Can you smell the rubber seals melting? Does your fridge squeak like crazy? You have an issue with your condenser fan. You can save about $50 by fixing the fan motor yourself. I'm no engineer but this was an easy fix. 1) Unplug the fridge. 2) Take off the lower back panel covering the condenser and fan. 3) Unplug the fan (on the top left from the fan. 4) Slide the fan out of the bracket 5) Take the fan blade off. (This will take the most time and TLC, it is glued on) 6) Take the two screws out of the back of the housing. **The fan motor should be free of the housing and blade** 7) Remove the two screws from the fan motor housing. 8) Pull the shaft out of the motor and clean all parts with some oil and a rag. 9) Make sure all moving parts are well oiled then put the shaft back in the motor housing. 10) Replace the motor housing screws 11) Replace the motor into the fan housing and replace the screws. 12) Slide the fan blade back onto the shaft (I used some super glue to help hold it in place) 13) Slide the fan housing back into place 14) Plug the fan into the socket 15) Plug in the fridge to make sure your fix worked (it may take a minute to kick on) 16) Replace the lower cover
Aug 03, 2010 | Samsung RS2630SH Side by Side Refrigerator
New model ET1CHEXYQ02 VERY NOISY, LIKE TO MAKE
Hello there
Please follow these steps first ok
It's noisy Noise can come from these areas: The inside of the freezer The outside back of the refrigerator The bottom of the refrigerator The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it. The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator it may make noise
Apr 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
It's making a loud running noise
The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Mar 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I am getting a loud rattling noise. could this be my compressor
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
Jan 29, 2010 | Frigidaire Refrigerators
My sub zero 561/F has what I think is a noisy compressor. I would like to know how to get to the compressor and clean/lubricate. I believe the noise is coming from the top grill area. Don't know how to...
the grill has two and maybe three screws onthe under edge of it remove and lift up and tilt out / there is a spring holding it in place / remove and lif off .. do clean the condenser coil ( unplug or turn off power befre doing this ) vacuum the compressor area. you cannot lube the compressor as they are sealed .. the fan motor is generally the noisey . replace if so ./ clean both sides of cond and fan blades .. mm
Dec 03, 2009 | Sub-Zero 561 / F
Noisy Braun 7680
I followed the instructions from Nick123456 for taking the shaver apart, cleaned all areas and oiled everywhere I could see moving parts around the motor. Then I put it back together making sure that the side screws were very tight. It is now much quieter and the shave seems OK but not brilliant. (Sorry about the typos in the original posting).
Aug 03, 2009 | Braun Syncro 7680 Electric Shaver
I have model # RS2630WW Samsung regrigerator making a lot of noise that seems to be coming from the back panel area. When I remove the 8 screws, it's seems to be coming from the fan. (I disconnected the...
fan can not be lubricated and they can get noisy.
however, a common reason is the fan blades hitting ice that has built up. check for this
Sep 06, 2008 | Refrigerators
Engel 43 Qt.Portable Freezer. Logo
Top Engel Refrigerators Experts
Jaime Hernandez
christian nielsen
cwradio73
Are you an Engel Refrigerator Expert? Answer questions, earn points and help others
