Question about Car Audio & Video
Can you hook up two bass amps to one woofer - Car Audio & Video
    Problem Solver:
  • 25 Answers
Yes you can but probably won't work unless they are strappable
Posted on Apr 28, 2015
3 Suggested Answers
  • 19 Answers
SOURCE: alpine sub woofer
your speakers are hooked up wrong. hook both positives together and both negatives together and bridge it to the amp. if it is one channel hook it up as one together. if it is 2 channel hook positive to one side and negative to the other side.
Posted on May 19, 2009
  • 9 Answers
SOURCE: Bass in Car Gone, i don't know why!!!
Does the amplifier power up? If so, then check the voltage at the outputs...sounds like the outputs fried. Also, check the RCA cable to make sure it is getting a signal to the amplifier.
Posted on Oct 21, 2009
How do you hook up 3 12 inch woofers to an 1800watt audiobahn 2 channel amp to receive more depth in the bass?
Hi, im a retired installer so let me see if i can help you out. First, you need to get the impedance of your woofers. Next, you need to find out if your amp is bridgeable. That means you can make both channels tie together. Now here is your issue to consider. Running an odd number of woofers may not be the way to go because of your impedance. That being said, if you can get me the info above i can tell you the best way to set you up.
May 03, 2015 | AudioBahn Car Audio & Video
My amp is on but when the bass hits it pulls the sub back and it goes into protect mod what can i do to fix this?
You may have a woofer with an impedance that is not correct for your amplifier, or possibly a damaged woofer. Try hooking up a different sub in your car without moving your amp, see if it does the same thing. If it does your amp has an internal issue. If it doesn't you know it's the sub.
Oct 17, 2012 | Rockford Fosgate Punch P400-2 Punch Series...
Hook up powered bass speaker to amp
On the rear panel, the one with all the connections, you have one labeled PRE OUT SUB WOOFER with a purple connector it's located in the lower central region of the panel. That is where you connect your POWERED bass speaker (aka subwoofer) as it only has signal output and no power.
Oct 19, 2011 | Onkyo TX-SR606 Receiver
How should i run my Jensen A600HLX Amplifier if i am using it to power 2 10inch Rockford P1 Subwoofers?
U need to check the impedance of your woofers .If they are 4 ohm i would reccomend hooking them in series, which is the positive output of your amp will go to the positive of one woofer, the negative of that woofer goes to the positive of your other woofer and the negative goes to the negative output of the amp.If that amp is bridgeable this will give u a good bass and the impedance will be 8 ohm so your amp will run cool and stable
Jul 30, 2010 | Jensen A600HLX Car Audio Amplifier
Passive radiator speaker wiring
Passive Radiators are not driven by the amp. They have no voice coil and no power goes to them. They are used to enhance the bass or lower frequencies in a speaker system. They work by utilizing the back pressure that a driver (woofer) produces. When a woofer produces sound, it moves forward and backwards inside the speaker cabinet. This backward motion is what drives the passive radiator. So in order for the passive radiator to work, it would have to be placed in speaker cabinet along with a woofer that is hooked up to an audio amp.
Jul 23, 2009 | Audio Players & Recorders
Alpine sub woofer
May 18, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Djust
alot of times its not just the amp that gives you better sounding bass.. A lot has a to do with a few other factors as well.. first off your subwoofer.. the bigger the subwoofer the deeper the bass. Some woofers exturde, or flex differently depending on the quality and structure of the woofer.. 2nd is gonna be the sub box. different size boxes will give your sub diff. depths of bass. ... general idea is the bigger the box deeper the bass. But if your woofer is not supplied enough power a big box is useless.   With that size amp your best bet is too run a single woofer. Probably a 10inch woofer would sound the best.. but it in.75cub inch. sealed box.. should sound great.
Nov 11, 2008 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Jul 08, 2008 | Pioneer TS-W301R Car Subwoofer
One or two
IMO 2 would be best. A good 10" woofer will give you good all round bass but wont rock your block off. The bigger your woofers the more low end base you will be able to produce so a 10" is a good balance between low end and thumpy bass for a full sounding system. The type of box you decide on encosing the woofers in will also affect your sounds. Consult your local car audio experts for more info. Good Luck
Apr 24, 2007 | Pioneer TS-W251R Car Subwoofer
Amp and sub bass playing through all speakers
You need to go into the setup menu and find out if the radio has a sub low-pass filter that redirects the bass to the pre-out for the subs, and away from the main speakers. Fiddle in the audio menu.
Apr 15, 2007 | Xtreme Sound WMS336 CD Player
Car Audio & Video Logo
206 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
