This is fairly easy to diagnose. Down by the brake pedal there is a switch. You may have to remove some trim panels to access it. There should be one wire with power all the time. There should be another wire that has power only when the brake pedal is depressed. If there is no power on any of the other wires with the brake pedal depressed than the switch is bad.
If there is power than the more common problem is the turn signal switch. I know it doesn't sound like it could be the problem but let me explain how it works. the turn signal and the brake use the same bulb. In order for the correct power source, brake lights or turn signals, to get to the correct bulb the turn signal switch is used. If you are not turning the power from the brake switch is routed through the turn signal switch and then sent to the two brake brake bulbs. If you are turning to the right power from the brake switch is cancelled to the right bulb and replaced by power from the turn signal flasher.
One quick way is to see if the third brake light is working. If it is you know the brake switch is working since power to the third brake light bypasses the turn signal switch.
Good Luck and let me know how it goes!
I’m happy to assist further over the phone at
https://www.6ya.com/expert/jeremy_d728a59f986299fa
