How do I balance my clothes dryer
It is making a wobbling noise while operating,I think someone overloaded it
  • Washing Mach... Master
  • 2,374 Answers
May be a broken wheel that drum rides on.
Posted on Mar 28, 2015
Why does my dryer make a load bang mid cycle?
You are overloading your machine, and in mid-cycle, the clothes are becoming out of balance. Try running the dryer with smaller loads. You will find that the clothes will come out of the dryer with fewer wrinkles, and that your items will be less likely to be damp after a drying cycle. If you continue to overload your machine, you risk breaking of belts or otherwise damaging your machine. You also may decrease the life of the clothes you dry since overloading is also hard on seams and fabrics.
May 11, 2014 | Audio Players & Recorders
Kenmore 970C45042 10 washer makes tremendous noise.
Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
Feb 11, 2013 | Washing Machines
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Not spinning and making loud noise
Usually when the washer goes into spin cycle, it takes a little time to do so because it is trying to start a heavy load of wet clothes from standstill. As it speeds up, if the load is out of balance, it will start to wobble and then the off-balance switch is activated, shutting down the power to the motor and turning on an alarm momentarily. If this is close to what you are experiencing, try to realign the load so that the clothes are not bunched on one side of the drum - that is, distribute the load around the drum. You should be able to close the lid and press start to get it to try again. If this doesn't work, try removing most of the clothes, especially the heavy items, like jeans or sheets. You might be overloading the washer. Try it again.
Jun 01, 2011 | Washing Machines
Whirlpool washer periodically will stop mid wash cycle. And won't restart until hours later. Seems to only happen when I need to do lots of laundry what is going on
THIS IS A BALANCE PROBLEM, IF YOU ARE PUTTING A LOT OF CLOTHES IN AT ONE TIME, YOU WILL HAVE TO BALANCE THE CLOTHES WHEN IT STOPS, DONT OVERLOAD IT, AND MAKE SURE YOU ARE EVENING THE CLOTHES OUT IN WASHER ESPECIALLY BLUEJEANS AND HEAVY THINGS, I KNOW MY WIFE DOES THIS HA, TRY THIS AND LET ME KNOW THKS LARRY
Apr 26, 2010 | Whirlpool Kenmore 5.9 cu. ft. Extra-Large...
My dryer started making a bumping noise when it
Your slides are worn and when you put clothes in the metal tub is now getting tracktion/ making metal to metal contact when it shouldn't and overloading the electric/belt drive. There is a kit to fix the problem but the dryer will need disassebled to put it in. At this time it would also be adviseable to replace the belt and tub bearing as well.
Sep 22, 2009 | Kenmore 65924 Electric Dryer
Machine makes a thumping noise when spinning
If its thumping you have the maching overloaded and the clothes (very easy to do with heavy jeans or sweaters) are all on one side causing an out of balance situation. Try relocating some of the clothes to the other side of the unit and if that doesn't seem to help remove some of the clothes to eas the load on the machine otherwise it will never reach maximum spin speeds needed to rinse your clothes.
Aug 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer Making Lound Wobbling Noise
I'll bet the drum is cracked.
Jan 11, 2009 | Dryers
Dryer off balance.
motor is to weak to turn drum(bad motor)sorry-mike
Dec 10, 2008 | Dryers
Washing Machines Logo
Top Washing Machines Experts
