Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Having a problem with the cd tray counter. The K light blinks each rotation, but the Z light doesn't. Sometimes it does work properly, but not always. When it does work, selection, etc works great.
    Filmmaker:
    Uploaded 5 video answers.
  • 26 Answers
Sounds like the counting signal from the carousel opto is being lost intermittently. Check to make sure he lamp (located under the black cover) is lit. It must be lit steady all the times (no flicker or flash) If it is lit then you may have a dirty receptor ( the eye that sees the light) There are two of these optical receivers under that black cover. Make sure there is no fuzz or dirt on them. Check all wires that go to them. OR the opto may be failing intermittently, though it is more likely just dirty. If this doesn't solve your problem, then you may have a poor connection at a plug that carries the communication from the opto's the the computer. Power down the juke and pull the plugs off and put them right back on. This is usually improves their connection.
Further troubleshooting can be found here,
https://www.flippers.com/wurlitzr.html
Posted on Apr 02, 2015
Singer sewing machine bobbin case keeps moving causing the needle to break.
Is this a front loading bobbin or top? If it is a vertical front loader with the little metal bobbin case, the metal case has to be lined up and snapped firmly into place. You should hear it snap and lock into place.
If it\'s a horizontal or top loading bobbin, and the plastic bobbin "tray" is rotating, then it may not have been nested in properly, before replacing the plate, or may be "jagged" somewhere... If there is a burr on the casing, or as in the case of one machine I worked on, still have a piece of needle stuck in it, the thread will snag on it before it finishes rotating and the rotating motion catches half way and will jerk the case right around and the next stitch will break the new needle.. Those plastic bobbin "trays" are usually easy to find and replace if they have become too burred to use. I have also sanded them smooth again as well though.
To test it, unplug the machine, thread your machine on top, but leave off your bobbin lid and leave out your bobbin, hold the top thread (like when you are about to crank to pull up a bobbin loop) and hand crank toward you, or counter-clockwise one complete rotation. Watch to see if the top thread is caught by the rotation hook and slips all the way around and back over the top of the bobbin tray, or if it snags on it somewhere.... Good luck!
Jan 15, 2014 | Singer Sewing Machines
Sharp AR-205 misfeeds at transport area from both paper trays and bypass tray both. Tested using different paper in all trays and still won't feed in at the transport area. The paper just pleats up...
it means the drum is not moving check it, insert it properly. or therre is a broken gear somewhere or the motor that makes the drum to rotate is not working properly. The registration sensor not working or not postioned properly.
Aug 01, 2011 | Sharp Office Equipment & Supplies
CD player will not work
Try a different CD. iIf the computer doesn't recognize it at all, listen for the drive to spin and look for a blinking light on the CD tray. These signs do not necessarily mean the CD drive isn't broken. I would find the model number of your laptop and do a search on eBay for a replacement CD drive. These are very easy to switch out. If the new one works, then you're set. If it doesn't work, there may be an issue with your motherboard.
May 07, 2011 | Toshiba Satellite Pro L300 Notebook
ITS cd tray is revolving when we press insert button . tray moves inward and it do't select any cd .and tray comes out again. main problem is it do't select any cd
You have a slack loading belt under the tray.The loading action is not being completed because of it.
The Cd lifting mechanism requires more torque than the tray rotating action. If you put your ears close to the tray you will hear a belt slipping sound after the loading tray goes in . If you push the disc motor assembly with your hand from underneath the action sometimes get completed and the cd will start playing. Any way you cannot be doing this all the time, the belt needs changing. Its a set of two belts, one very small for the tray rotation and a thicker/bigger one for loading mechanism.
Mar 11, 2011 | Aiwa Audio Players & Recorders
My CD Tray wont open
can you see the light of the cd drive blinking??.........if not then you have a loose connection between your drive and your motherboard. if the light is blinking then you then think that your eject switch is not working properly.In this case if you want to open the tray......then you have to follow this... there is a little junction hole just right on the light...you see it??yeah you need a needle like metal wire that can be inserted into this hole.If you push the the wire into this hole,you'll se that the tray is coming out.then you can play your disc easily. GOOD LUCK!
Dec 05, 2010 | Dell Dimension E521 AMD Athlon 64 X2...
I cannot open the cd tray! it's got a cd in there and the software would not work properly and now it's blinking and I cannot open the tray! what's wrong??
Its normal that sometimes the CD drive tray will stuck with the CD inside. At this point, there is an option where you can open the drive tray manually using a paperclip. For more info, please refer to below URL:
http://www.fonerbooks.com/laptop12.htm
May 25, 2010 | Toshiba Satellite P205-S6237 Notebook
Cd brokes in cd rom
IS IT ON?...DOES CDROM HAVE POWER GETTING TO IT FROM PC? Next to open/close switch there is a small pin-hole. Push a paperclip into this hole and gently pull out tray...try gently pushing tray back in and watch for a blinking green light;if none either the cdrom is not getting power, or it has quit working
Mar 20, 2010 | E-Machines emachines (emachinees) CD-ROM...
Onkyo C-707chx cd tray jammed won't open won't play
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Jun 07, 2009 | Onkyo DX-C390 6-Disc CD Changer
Blinking green light on 1 tray
You could have a faulty drive.
To open the tray, you need a paper clip, straighten it and place it in the small hole below the disc tray, push it in and the tray wull pop out slightly, remove paper clip and pull the tray fully out with your fingers.
Then try to close and open the tray with the push button, if it does not work you need to replace this drive with a new one.
Sep 24, 2008 | Acard Technology (CD1TO7T) CD-RW Burner
CD Player tray will not rotate or open or close - no power
my cd player will open and rotates but will NOT play, can anyone help me?
Oct 09, 2007 | Audio Players & Recorders
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
131 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
phil
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
