Question about Sharp Video Cameras
How do I get my cassette tape out Sharp Viewcam. When I open, it slides up but can't get it to release tape h
SOURCE: Sharp Viewcam VL-E66U
I let it sit overnight and when I opened the door I nudged the part that holds the tape up. I got the tape out but I think it is still frozen. I will try a different tape and hope it still works. I'll post results.
Thanks
Kate
Posted on Sep 08, 2008
SOURCE: Sharp Viewcam VL-AH151 Hi-8
Make sure the little red tab on top of the tape is set to record and not save. The camcorder will not let you record it its set to save
Posted on Sep 21, 2008
SOURCE: Cassate tape will not eject from my Canon ZR85 Mini DV Digital Camcorder
I found a temporary solution for this problem. When the tray with the cassette tape comes out remove the battery so that the tray will not go inside again. Now on top of the tray it will be written as "PRESS" just adjucent to it you can see a spring connected to the tray just press the string down wards and the tray opens and you can replace the battery. Hope this can help.
Posted on Nov 13, 2008
SOURCE: SHARP Viewcam z vl-Z500H-S Camcorder
To transfer video you need to use firewire, not usb. If you use firewire to connect, set the camera to the 'play' icon and then open up a capture program (ie, movie maker) you should be able to just record/capture from there. Good luck!
Posted on Nov 19, 2008
cpt100
  • 154 Answers
SOURCE: when opening camera to insert tape,tape tray slides out,does not
This is new for a sony camcorder technician. Here is what you should do. There may be a sticky substance holding the side tape door to open then the whole tray will go back down. Using battery, press the eject button when the tray is all the way up, disengage the battery to turn the power off. This way you will have the tape tray at posititon just before the opening of side door. With you finger nudge the door outward to see if it is just got stuck by substance. Using Q-Tip with some "windex" go around the edges of the tray. You can also take the door off by removing two screws. -James. For additional assistance by email, go to www.camerarepairjapan.com
Posted on Apr 02, 2009
What type of cassette do i need for a sharp VL-A10 viewcam 8
You need to use a tape that says 8mm or Video8 only. I have provided a link to the type of tape that we would use.
http://www.amazon.com/Sony-MP-Video8-tape-120min/dp/B0009WUCG6/ref=sr_1_7?s=electronics&ie=UTF8&qid=1284056100&sr=1-7
There are tapes that say Hi8 and Dig8 on them. These tapes will not work properly in your camcorder because they are the wrong format. Your camcorder would probably chew the tape at some point if you tried to use this kind.
Hope this has helped.
www.austintelstarservices.com
Sep 09, 2010 | Sharp Viewcam VL-A10U Camcorder
Sharp video camera VL-AH50
Did you try cleaning the tape head?
Feb 22, 2008 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Cassett does not get inserted
Put a head cleaner tape in camera and run it for 20 seconds ever few months.
May 29, 2010 | Sharp Viewcam VL-Z1U Mini DV Digital...
My sharp veiw cam Z will not take a cassette tape.do you know why.
if it says dew on the screen leave the cassete out and leave it open for a few hours
Oct 19, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp VL-Z1 will not load the cassette...
Modification is available to fix this problem, contact sharp repair facility.
Oct 18, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Cancorder not wrking-e007 error message
moisture in the cassette holder. Take out the cassette, leave the holder door open for a couple of hours in a dry, warm location, and it should work again.
Sep 12, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp Viewcam VL-AH151U keeps saying "eject cassette" why is that? How or where can i send this to get fixed?
Assuming the record tab is in the correct position, download the manual for the VL-AH150U, very close to the 151U.
Page 10 of the manual shows the normal reasons for the "eject cassette" message. If not, I would call Sharp support at
1-800-BE-SHARP (237-4277) for referral to a local repair center.
Let me know if this helps.
Jan 18, 2009 | Sharp Viewcam VL-AH151U Camcorder
Mini Cassette to DVD?
you need a firewire cable to go from cam to computer or use a dvd recorder and put tv connections from cam to dvd recorder
Jul 27, 2008 | Sharp Viewcam VL-NZ100U Mini DV Digital...
Jan 20, 2008 | Sharp Viewcam VL-AH151U Camcorder
The "DEW" indicator is illuminated on my Viewcam, what do I do to turn it off?
This means there is moisture inside the Viewcam. Try taking the tape out, leaving the cassette compartment open for 2 hours to allow any condensation to evaporate. If the DEW indicator is still illuminated call a Sharp authorized servicer.
Sep 07, 2005 | Sharp Viewcam VL-A10U Camcorder
Video Cameras Logo
108 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
