Installed new cartridge but its telling me that it cannot detect my yellow cartridge. Have tried 2 new cartridges and still get the same issue. Printer is only 1 year old, and not used frequently.
    Problem Solver:
  • 13 Answers
Try to shake the cartridges well before use and see if cartridges fit perfectly. If problem presets restart the printer.
Posted on Mar 28, 2015
MFC 9440CN does not detect yellow cartridge!!! it
THERE ARE A COUPLE OF SOLUTIONS HERE.
1) With a clean cloth or compressed air clear the sensor are on both cartridge and area around where cartridge plugs in.
2 Check for blockage in cartridge
3) Try a new Yellow cartridge
Oct 10, 2013 | Brother MFC-9440CN Multifunction Printer
I have an HP 820Cse printer. It has fresh catridges, & for some reason it wont print. I tried to print something from Wordpad, & the wheels began to take the paper in, but immediately stopped. ...
Hello and Welcome to FixYa!
The yellow Resume blinking light refers to one of these issues;
  • The top cover of the printer is open or the printer is not responding.
  • The printer detects a faulty, incompatible, or improperly installed print cartridge.
  • The print cartridge contacts are dirty and the printer cannot detect a print cartridge.
I guess yours will be third case, do check for the first two at your own. For the third one, follow the instructions;
Note: Please Do Not wipe the nozzle end of the cartridge or touch the silver-colored nozzle plate on the bottom of the cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
  • Open the top cover of the printer.
  • Remove the print cartridges.
  • Clean the copper-colored contact points on the cartridges with a dry, lint-free cloth.
  • Use a dry, lint-free cloth to remove moisture from the contacts.
  • Insert the cartridges back into the printer.
  • Close the top cover.
  • Try printing again.
If you are having issues, do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Jan 22, 2011 | HP DeskJet 820Cse Printer
Where do the ink cartriges on a brother mfc 5460cn fo
Your machine is equipped with an ink dot
counter. The ink dot counter automatically
monitors the level of ink in each of the 4
cartridges. When the machine detects an ink
cartridge is running out of ink, the machine
will tell you with a message on the LCD.
The LCD will tell you which ink cartridge is low
or needs replacing. Be sure to follow the LCD
prompts to replace the ink cartridges in the
correct order.
Even though the machine tells you that an ink
cartridge is empty, there will be a small
amount of ink left in the ink cartridge. It is
necessary to keep some ink in the ink
cartridge to prevent air from drying out and
damaging the print head assembly.
a Open the ink cartridge cover.
If one or more ink cartridges are empty,
for example Black, the LCD shows
Ink Empty Black and
Replace Ink.
b Pull the lock release lever down and
take out the ink cartridge for the color
shown on the LCD.
c Open the new ink cartridge bag for the
color shown on the LCD, and then take
out the ink cartridge.
d Remove the protective yellow cap (1).
Note
If the protective yellow caps come off
when you open the bag, the cartridge will
not be damaged.
e Each color has its own correct position.
Insert the ink cartridge in the direction of
the arrow on the label.
f Lift each lock release lever and push it
until it clicks, and then close the ink
cartridge cover.
g If you replaced an ink cartridge, the LCD
may ask you to verify that it was a brand
new one. (For example,
Did You Change Blck?) For each
new cartridge you installed, press 1
(Yes) to automatically reset the ink dot
counter for that color. If the ink cartridge
you installed is not a brand new one, be
sure to press 2 (No).
If you wait until the LCD shows
Near Empty and Ink Empty, the
machine will automatically.
Find this on page 113 of the manual:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002135/cv_mfc5460_usaeng_usr_a.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Dec 04, 2010 | Brother MFC-5460CN All-In-One InkJet...
Keeps saying install c
When the printer says "install C" it is referring to the Cyan (blue) ink cartridge. If this is not a new cartridge, you might have to replace it. If this is a new cartridge, try following these steps.
1. Unplug the power cable.
2. Remove all 4 ink cartridges.
3. Close the ink cover
4. Plug the power back in.
5. Wait for the machine to warm up and tell you that the ink is empty.
6. Reinsert all 4 ink cartridges.
If you keep getting the same message you should try another cartridge. You can put the yellow cartridge in the blue spot to see if you get the same message. If you get the same message then the machine is broken. If you get a new message then the cyan cartridge needs to be changed.
Thanks,
Pat
Nov 09, 2010 | Brother DCP 130C All-In-One InkJet Printer
Installed new cartriges and now it says they are missing or not detected
There can be several reasons to get this error on the printer screen. They are
1. One or more Cartridge install by date has expired or the printer has detected that either one of the cartridge expiry date has passed by ( current date ).
2. This can also be result of defective cartridge
( though cartridge is new ) or in few occasions the printer hardware failure too.
These are the steps you can try to fix this issue :
1. Open the front access door where you find all the cartridges installed
2. Remove all the cartridges and clean the electrical contacts/golden contacts you find on the cartridge and also inside the printer cartridge slot
3. Check for Date on the cartridge, If any cartridge has date less than current date, you can try replacing the cartridge.
4. After cleaning the cartridge contacts, install the cartridges back into the printer and close the door and wait for the printer to go through initialization process.
Please let us know the printer model if the above steps did not resolve the issue.
Sep 07, 2010 | Office Equipment & Supplies
Replacing the ink cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
PREM
May 26, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Ink Cartridge Error
on your cartridges there is a chip that detects if the ink is low. The chip on your yellow cartridge is bad. You should return the cartridge for a new one(if you still have your receipt) or visit a Cartridge World in your area and they can put a new chip on for you
Aug 12, 2008 | HP Photosmart C6180 All-In-One InkJet...
Cartridge error
remove the cartridge & install the new one cartridge other wise
May 10, 2008 | HP Photosmart C5180 All-In-One InkJet...
k24674
