Question about KitchenAid Architect Series KEMC308KSS Electric Double Oven
How do I replace the outer door glass on a KitchenAid Superba microwave?
  • 883 Answers
SOURCE: Kitchenaid Oven
I believe the entire door must be removed first. then remove every screw that you can find and draw a picture where they came from. then split the door open like opening a clam. then you may find additional screws to remove the glass
Posted on Jun 02, 2007
  • 3422 Answers
SOURCE: replacing inner door glass kitchenaid kebc208ss
Click HERE for the service manual and refer page no. 21-22
This will solve your problem.
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 16, 2008
ginko
  • 19396 Answers
SOURCE: replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Posted on Apr 08, 2009
SOURCE: Kitchenaid Superba 27 KEMS376WHO
Go to manualsonline.com. They will ask for make and model of your appliance. Most manuals are free. Give it a try.
Posted on Jul 11, 2009
SOURCE: Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Posted on Aug 25, 2009
Replece glass oven door kitchenaid kebs278dss8
Oven doors have at least two panes of glass (air gap between so little ones touching outer glass do not get burned). You remove the screws around edges of door (top, sides, & bottom) and lift frame up and forward to get outer face off. The glass in ovens is tempered to take heat so you can not just use regular glass. You will find outer piece is sometimes the entire size of door but is painted black with the "dot" pattern that lines up with inner piece. Once you get face / frame off you will usually find the handle screws and mounts for inner glass. Sometimes inner glass sealed with high temp sealant. But make sure you use correct glass or someone could get hurt.
Jan 21, 2015 | KitchenAid Ovens
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
Feb 09, 2009 | Ovens
KitchenAid Superba Microwave/Oven, Microway Door message
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Dec 20, 2008 | Ovens
Kitchenaid Microwave torsion spring replacement
I just replaced torsion spring 4452396 on my microwave. We heard a "pop" and then the door got heavy. here are a couple things I learned...THE HARD WAY!
We had the stainless steel front to the door and needed spring 4452396, not 4451008. The stainless steel door is heavier so therefore a stiffer spring. I'm not sure i could justify the 4x cost in the part...but that's just the way it is. It's a bit of a pain to repair the thing..so it's worth it to get the correct spring. You don't wan to be doing this every couple of of months!
You have to remove the front panel of the door to access the springs. there are 2 of them...they cross each other in an "x" pattern on the lower part of the door. We had to pull the unit out a bit to get the spring in the hole for correct position. No need to remove the door etc. If you need help with this...email me.
My mistake was when I was trying to figure out how to gain access to the springs I assumed you did from the inside of the door. I removed the two black things you see on the lower right/left of the door (screw on the bottom of them) then proceeded to remove the two recessed screws on the inside top corners of the door. Well next thing i know.....CRASH! the whole front of the door fell off and shattered! Come to find out those screws and brackets on the bottom hold the face of the door on. The glass is intergrated into the color panel of the door..so it's one piece! 150.00 later and a new piece of glass/panel i learned a hard lesson.
Let me know if you need help...it's fairly easy to do now that I look back on it. dave dlacki@gmail.com
May 14, 2008 | KitchenAid Architect Series KEMC308KSS...
Stain inside double glass microwave door
most microwaves have screws on the top and bottom outer lip edges. or under the rubber grommet if it has this .
but this unit should have a 10 year warranty and they may cover this issue call them
http://products.construction.com/portal/server.pt/gateway/PTARGS_0_2_493_204_249_43/http%3B/205.142.52.224/swts_content_files/15315/211253.pdf
Feb 29, 2008 | KitchenAid KEHC379 Electric Double Oven
Kitchenaid Oven
Jun 02, 2007 | KitchenAid Architect Series KEMC308KSS...
Outer Glass Microwave window shattered after baking popcorn
doubt anything to do with popcorn. glass like that does sometimes shatter probably a stress fracture. quite often happens with oven doors as well
Apr 19, 2007 | KitchenAid KEHC379JSS Electric Double Oven
KitchenAid Architect Series KEMC308KSS Electric Double Oven Logo
89 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
