Question about Moen Home
How do I disassemble a Moen shower head nozzle?
  • 3,368 Answers
Cont Moen for help they are great!
Posted on Apr 02, 2015
How do I take apart a moen shower head?
You can remove the head from the shower arm by taking a crescent wrench. Put it on the flat sides of the nut on the showerhead and unscrew it counterclockwise. There is no way to take apart the Moen showerhead. If the reason you want to disassemble the showerhead is to clean it because it is clogged, disassembly is not needed. Just fill a Ziploc bag with a 50-50 solution of vinegar and warm water. Place the bag onto your shower head so it is fully immersed in the solution. Use a rubber band to hold it in place. Let it soak overnight and then take a toothbrush to any of the white scaly matter that might remain.
Aug 10, 2015 | Moen Home
How to disassemble of moen shower head,where i can start the dismantling?
U don't remove the plastic u stick them hole shower head down in vinegar and let it sit for a while, that will clean it out
Feb 24, 2015 | Moen 6302 flo Deluxe Shower Head Shower...
I have a posi temp faucet that has been installed for 6 years but never used. Now i have the project completed and have no water pressure thru the shower head. The sink has lots of pressure and is on the...
Have you disassembled the shower head to see if it has a flow restrictor in it. If it does you can remove it and any aerator type screens. Hope this helps. Thanks
Dec 22, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Shower head 112.18.1M flow is uneven. How do I disassemble it to clean obstructions.
Unscrew the base of the shower head where it meets the pipe. Lefty-loosy. You can dunk the head in a container of CLR to clean off the calcium. Also you can ***** them off using a small pin. If your head has rubber nozzles, you can just rub the head while the shower is on to clean them.
Nov 25, 2010 | Moen & One Handle Tub & Shower Faucet
Removing flow restrictor from Moen Brantford posi-temp shower he
How I remove them is take a drywall screw and screw in to the flow restrictor. Then grab it with a pair of pliers and pull out.
May 16, 2010 | Moen T2153BN Brushed Nickel Brantford...
Moen Hand Shower repair
  2. start unthreading centre of head. I used a paint scraper to leverage at first. The threads get loose soon to hand loosen.0588438c-31ce-4428-9378-28140fa37adb.jpg
  3. loosen the spray ring using a lever to get threads started. Hand loosen after that.It's got right hand thread so the outer ring will be turning counter clockwise.3e2cc1ab-35f5-4521-a05f-e1167596fb04.jpg
  4. Take flat rubber gasket out of centre of head and take screw out, then pry white nylon part out with tool. I used tweezer.a1f4f121-e0e1-450a-a9b8-8777342a3262.jpg
  5. Clean scraped parts in hot CLR solution or any vinegar will work as well. Reassemble with lubricant so it works like new. Most likely need for disassembly is clogging or a broken "o"-ring.6fff7106-1b7b-4330-a3c6-089ea42233cf.jpg
Apr 13, 2010 | Moen 3867 Four Function Hand Shower With...
How to dissassemble shower head
The shower head is removable with a crescent wrench and a pair of pliers, or two pair of pliers. Put electric tape where pliers will grasp to avoid scratching. The shower head is attached to the extension pipe like a regular screw on fitting, so to loosen turn counter clockwise. As far as disassembling the head itself, some are meant to come apart, others not. Use white tefllon plumbing tape to re-install.
Please rate this answer for me. Thank you.
Mar 25, 2010 | Moen & One Handle Tub & Shower Faucet
Leaking shower head
Check the spout pull knob . Debris can be keeping it from closing completely.
Jul 05, 2009 | Moen & One Handle Tub & Shower Faucet
Hot water dribbles thru shower head when turned to hot
Replacing the cartridge should solve the problem, the balancing spool is stuck, replacing it will solve the problem. The valve should look like this http://www.moen.ca/shared/pdf/3170pt.pdf . I have unstuck the spools in the past, soaking it in white vinegar will help to remove build up.
Nov 17, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Home Logo
261 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
