Question about 2005 C5500
Where can I get wiring diagrams for the ABS, body control module, and airbag module?
Trying to do ABS auto bleed but scanner wont communicate so im guessing its a bad module on the low voltage network
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
Scanner not communicating is a different problem. Check if you can talk to any of the other modules (engine, body, etc.) Check all of your fuses with a voltmeter. Also, if there are ANY ABS or traction codes, the sequence cannot be initiated. Diagrams can be obtained from any shop with access to info and they could print it out for you (maybe a small charge)
Posted on Apr 02, 2015
How do I fix error code U0418 for 2011 Ford F-450 super-duty?
Well you better study up on vehicle communication networks . C.A.N - controller area network . How to Diagnose Controller Area Network CAN . Then your going to need factory service repair information . U0418 Ford Invalid Data Received From Brake System Control Module
Dec 11, 2016 | 2011 Ford F-450 Super Duty
Looking for the wiring diagram for the air bag system
Ross-Tech: VAG-COM: VW Issues
www.ross-tech.com/vag-com/vw_issues.html
2009+ Golf/GTI/Jetta and similar no communication with 46-Cent. ... 2000-2001 Golf/GTI/Jetta/Beetle Airbag System (important!) ... We have had a number of reports of Air Bag Warning Lights staying on permanently after scanning with ... the Airbagcontroller, you need to click on Airbags in the Select Control Module screen.
Airbag control module -- "no communication" - E46Fanatics
forum.e46fanatics.com > E46 BMW > General E46 Forum
Nov 30, 2010 - 19 posts - ‎8 authors
The recommendation is to get a new one & have it reprogrammed. ... Is the airbag control module a normal wear item or should I expect that it would last the .... easily shipped, and you have the scanner that can reset any faults it may come with. ... Can'tyou simply reset and see what comes back, then fix it?
jsw airbag module not communicating through VAG-COM - TDIClub Forums
https://forums.tdiclub.com/showthread.php?t=330306
Jan 23, 2016 | Cars & Trucks
2006 Chrysler 300C - lights dont turn on regularly with auto set or manual. Is the light sensor swith on the dash here & that would be only relevant in auto mode, correct. The lamps DO NOT work every time...
Without testing we'd only be guessing . complex electronics involved , control module's , serial data communication network's etc...The switch is a input to the instrument cluster microprocessor which is hooked to the C.A.N - controller area network serial data communication network for the computers on the vehicle . This problem would take research , factory service repair information. Hooking up a professional type scanner or the factory tool ,checking for DTC'S - diagnostic trouble code's in all the modules on the vehicle ( 20) or so. Viewing data parameters on the scanner. With the complex electrical an electronics on your vehicle it could be a lot of different thing's .
Looking at wiring diagrams show's the complexity . free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter your vehicle info. Year , make , model an engine size. Under system click on lighting ,then under subsystem click on exterior lighting .Click the search button then the first blue link . View the diagrams an see if you can make heads or tail's of them.
A Controller Area Network (CAN Bus) is a vehicle bus standard designed to allow microcontrollers and devices to communicate with each other in applications without a host computer. It is a message-based protocol, designed originally for multiplex electrical wiring within automobiles, but is also used in many other contexts.
Wikipedia · Text under CC-BY-SA license
Nov 23, 2017 | 2001 Mercury Sable
Im getting a U1040 code- (loss of communication with brake control module
Loss of communication with brake control module is exactly what it says. There is a problem with the wiring harness that goes to the ABS controller. You might make sure it is plugged all of the way in. You might also unplug it and make sure there is no corrosion or damages pins in the connector.
Apr 22, 2013 | Chevrolet Cars & Trucks
The code reader will connect with my passat but will not connect to the abs part of the of the system, any ideas, its just failed on abs light, its got 2 new sensors there both push right home, ive cleaned...
did you just the rings on the axles?look at them close sometimes the rings on the axle crack and this causes the abs light,,,,the generic scanner do not communicate with any module but the ecm/pcm they do not read abs only dealer and high $$$ snap on ones do read abs..thats why you can read it,,im sure there is a code but you need then right scanner
Oct 14, 2009 | 1999 Volkswagen Passat
Odometer has warning code what is it no bus5
The bus is the communication interface between the many modules or computers on your vehicle. The engine and transmission modules need to be able to communicate with the cluster as well as the airbag, antilock brakes, and body control module to turn certain lights on and make gauges function. "No bus" means the communication line is either open or shorted and the cluster can't determine the inputs from the other modules. Any given module on the vehicle can pull the bus down as well as wiring. It is most likely a module causing the problem. One way to find the culprit is to disconnect each module with the key on until the odometer comes back to life. If it starts and runs, drives and shifts normal, I would do the engine and transmission last. I would start with the ABS and overhead console (if it has one). I hope this helps.
Oct 04, 2009 | 2004 Chrysler Sebring
Airbag light wont go off for hynadai acemt
The communication with SRS CM (Supplemental Restraint System Control Module) is proprietary - Hyundai Dealership Scanner equipment. Best solution: Take the vehicle into a Hyundai Service Center (dealership), pay the diagnostic fee. They will tell you EXACTLY what the problem is and what's needed to fix it (parts, labor, tax, time-frame, etc.).
Jun 27, 2009 | Hyundai Motor 2004 Sonata
1991 corvette brake syatem
You need to bleed this system with the special tool that holds the ABS solenoids open, it plugs into the ABS brake controller, if you don't do this there is no way to get the air out of the system, that is why your pedal is low.
Oct 29, 2008 | 1991 Chevrolet Corvette
2005 C5500 Logo
112 people viewed this question
Top GMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
alibaba69
Are you a GMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
