Question about Electrolux Dishwashers
How can I repair or replace the spring on the door?
  • Electrolux Master
  • 2,205 Answers
Generally you open door all the way, then brace it in an open position with a couple of 2x4s on each corner or something like those to hold the door open all the way on their own. then replace each spring by lifting it out of the top metal brackets. need some lifting power to accomplish this. good luck. make sure you replace with exactly the same spring=take broken with you for new.
Posted on Mar 30, 2015
How do I replace a broken door spring?
You can call a local garage door repair shop to get replacements. They should have springs that will work with your garage door depending on if the door is for a single-car or double-car garage, or if the door is made out of wood versus steel. Usually both of your springs will have to be replaced for safety reasons. You should not replace the spring yourself unless you are a trained professional with the proper equipment because the springs are very dangerous and cause serious injury.
Mar 28, 2015 | Building Materials
Broken door spring on kitchenaid dishwasher
Please read our safety information before attempting any testing or repairs. Before repairing the door springs, unplug the dishwasher or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
The door opens and closes with the aid of springs. If the springs (or the cables that connect them on some dishwashers) break, the door will drop open hard. The door will also be heavier when closing. If the door drops open, it may also bend the door hinges out of shape resulting in a door that does not close properly and possibly leaks.
When replacing the springs or cables, all of them should be replaced at the same time.
To access the door springs and cables remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to get to the screws over the panel, then close the door to remove the panel.
There are two common types of spring assemblies. One type connects the springs from a hook on the dishwasher cabinet of to a tang on the door hinge .
May 07, 2008 | Dishwashers
My garage door will not open but approx. 8" , no cable broken , chain on track. Today I found that one spring is broken. how hard is it to replace.
I have built many garage doors and installed many door openers. The typical garage door spring is not that hard to replace. I have to have 2 steel rods 1/2 inch in diameter to slowly tighten the spring.
Oct 17, 2013 | Stanley Hardware 730610 110 Lb Garage Door...
How can I replace torsion spring of my garage door?
A garage door's operating system is not a simple one. I think you should go for expert's help. take a look at Garage Door Repair Houston TX
Feb 04, 2013 | Cars & Trucks
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Lift spring broke, what is the estimated cost of repair
Be prepared to get a pro to repair it, working with springs under tension is dangerous. It's worth it.
Mar 02, 2010 | liftmaster Chamberlain Garage Door Opener...
Door is broken
Hello Hickin! It would appear that one, or both of the door springs which act as a counter-balance for the weight of the door, have broke.
To confirm this and get at the spring(s), close and lock the wash compartment door and use a screwdriver (might be a 1/4" or 5/16" nut driver instead) to remove the lower panel.
Once you have the lower panel off, you should be able to see the door springs on each side. You'll probably also see part of the broken spring lying in there too. If the door spring broke near the end by the hook, it is possible to TEMPORARYILY bend the spring with a set of channel locks and pliers to form a new hook end, that you can attach to the door clip. If the spring is broke near the middle, you'll need to get a new one.
Regardless, you'll need to locate the model number for your dishwasher and obtain a replacement spring ASAP, as the temporary repair will only work for a short while before the spring breaks again.
You might want to try Fagor at their site to see what the part number for the replacement spring is. http://www.fagoramerica.com/
The other option with your model number is to try the Sears part web site, which shows a line drawing and parts list for most applianances.
http://www.searspartsdirect.com/partsdirect/index.action
This repair is relatively easy for anyone to undertake and you can save yourself the cost for a service tech's labor charges, plus the trip/house charge they normally tack on.
I hope you find this Very Helpful and best regards!
Oct 12, 2009 | Fagor Dishwashers
Replacement for the spring loaded door on my tower
No solution for this. All cd players are non repairable or at least not cost effective to repair. My advice is to just purchase another one. Cost for these is now in the $40.00 range - cheaper then getting this one fixed
Dec 30, 2008 | Compaq Presario SR1050NX (DW257A) PC...
Dishwashers Logo
71 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
