Well all of the above advice is good/great, but you have not said what type of garage door you have. if the springs are on the side of the garage door, they are not very hard to replace and not all that dangerous. if the spring or springs are over the top of the garage door, then you do know what you are d oing and people have been maimed. so what type of garage door do you have. you can always post a photo. lots of good knowledge on this site.
I also think you'd be better off hiring a professional. Spring replacement is extremely risky and if you don't know what you're doing you could end up doing more damage than good. This could include damage to your garage door or injury to yourself. It's best to hire a garage door repair service. Good luck to you, Valentine! http://www.kaufmanoverheaddoor.com/services.html
Dangerous and not easy. And when job is done you replace both springs so that both are identical in characteristics.
You can call a local garage door repair shop to get replacements. They should have springs that will work with your garage door depending on if the door is for a single-car or double-car garage, or if the door is made out of wood versus steel. Usually both of your springs will have to be replaced for safety reasons. You should not replace the spring yourself unless you are a trained professional with the proper equipment because the springs are very dangerous and cause serious injury.
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
If the microwave door won't open the button might be broken internally. The button can be replaced.
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
what type of spring are you asking about. torsion spring or regular/old style side spring.
