I can only get 21 lower channels i have tried everything to get more but for some reason the setup wizard didn't finish how can i get the setup back on?
  • Lora Allen
    Lora Allen Mar 28, 2015
    I have every which way i can i need to get back to the setup wizard but don't know how i think when i pressed scan it scanned the antenna instead of cable...
    Top Expert:
  • Televison & ... Master
  • 43,059 Answers
Return to the initial set up procedure and repeat the channel scanning process.
Posted on Mar 28, 2015
  • Lora Allen
    i have every which way i can i need to get back to the setup wizard i think instead of scanning the cable i think it scanned the antenna but i can't seem to find the setup wizard again!!!
Will only scan 21 channels with cable and no box
If all else fails go into the menu and look for the setup--it sounds like you may have the set set to air/antenna instead of catv/cable as this would account for only 21 channels being picked up.
Dec 22, 2012 | Vizio L37hdtv10a L37 37" 720p Lcd Flat...
How do i reboot my laptop
Restore to factory settings
Restoring your Sony VAIO computer to its original factory settings is a great way to remove old programs and files that are buried within your computer that you no longer need, or to get rid of a virus that you just can't seem to shake.
This process will allow you to start anew with your computer, and can potentially save you from simply throwing the computer away because you don't think it can handle the workload anymore and spending money on a new machine.
Unplug any cables connected to your Sony VAIO machine with the exception of the power cord and monitor.
Click "Start" in the lower left corner of your screen.
Click "Control Panel."
Click "Performance and Maintenance."
Scroll down to the bottom of the Performance and Maintenance screen and click "VAIO" recovery wizard. The VAIO Recovery Wizard dialogue box will appear.
Click "Next."
Select "Proceed with System Recovery" and click "Next."
Select "C Drive Recovery" and click "Next."
Click "Next" to confirm that you want to proceed with the C Drive Recovery.
Click "Finish" to restart your Sony VAIO machine and initiate the recovery procedure.
Upon restarting your computer, the Sony VAIO Recovery Wizard will prepare your hard drive for recovery and then restart your computer again.
The necessary files will be copied to your computer and your hard drive will be recovered.
Click "Finish" when a screen appears telling you that your recovery process is complete.
Your computer will restart.
Click "Next" when you arrive at the Windows setup screen.
Follow the on-screen instructions to setup your version of Windows.
When you have finished setting up Windows, click "Finish."
Upon restart, the Sony VAIO Recovery Wizard will install necessary files on your computer.
Your computer will restart automatically when these files are installed and your Sony VAIO will be restored to its original factory settings.
Hope this helps
Oct 14, 2012 | Sony VIAO Laptops (Laptop NOT Included)...
Seiki tv returns to setup wizard each time turned on
Go to your settings and Lock your TV ... What this does is Locks in your TV settings and channels .... This should Work for you
Mar 31, 2012 | Televison & Video
DBX Driverack PX "Wizard" not allowing MONO
set it up as mono=common leads together and l,r,leads together,it will see left and right are in use and should load up
Jul 05, 2010 | DBX Driverack-Pa Eq/Speaker Control System...
Pc Game Error
Hi! I'm trying to install My Horse and Me the PC game, the installation goes through everything normal and but when I press Finish it gives me this error message
Unhandled Exception
Error Number:0x80040702
Description:Failed to load DLL:GameuxInstallHelper
When I press OK the installation window where you press Finish pops back up and it says
InstallShield Wizard Complete
The wizard was interrupted before MyHorseAndMe could be completely installed.
The system has not been modified.To install this program at a later time,run the installation again.
Click Finish to exit the wizard.
So I press Finish and then if I try to go and find it its not there its been uninstalled. And I have tried installing it several times with no luck .
So if you could please help me that would be wonderful because I really want to play my game.
Thank You!
Nov 14, 2009 | Atari Video Game Consoles & Games
Problem connecting Xenon to PC Suite II
And the PC in question has a bluetooth adapter? Sounds like its getting to the point where it would detect and connect after clicking finish then not finding the bluetooth adapter to connect to the phone. Another thing you can try is connecting via USB cable to the computer, that will get everything detected and install drivers as needed, then go back to trying via Bluetooth, my Motorola phone required doing that for some reason!
Jan 11, 2018 | LG Xenon GR500 Cell Phone
I can not find all the tv shows what do i do
Channel Edit makes it easy for you to save or delete channels in the list of channels in the TV?s memory. 1. Using the Number buttons, select the channel you wish to save or delete. 2. Press MENU to see the menu. 3. Press upper or lower key to scroll through the menu until SETUP is highlighted. 4. Press right key to enter the SETUP menu. 5. Press upper or lower key to scroll through the SETUP menu until CHANNEL EDIT is highlighted. 6. Press right key to choose SAVED or DELETED. Choose SAVED to add the channel to the TV?s memory. It will be available using the CH +/? buttons. Choose DELETED to remove the present channel from the TV memory. To clear the menu press STATUS/EXIT. Or, wait a few seconds after you finish your adjustment; the menu will disappear automatically. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Jun 13, 2009 | Philips Magnavox 20MT133S 20" TV
How to get the dell 4200 ed to pick up digital channels
there are 2 coaxial inputs on the back of your tv. plug the antenna into the digital coax. with your remote, do a fac reset: menu, setup, fac reset, all settings, passcode 3355. after the reset, hit input, select digital tv. perfprm a chan scan: menu, setup, channel scan, antenna. this should solve the problem.
Feb 09, 2009 | Dell W4200 42 in. HD-Ready Plasma...
Trouble installing wireless card
If you're having installing the wireless card, try first to run the setup CD and follow the wizard in installing the wireless card and if it didn;t finish the installation , restart the computer and make sure the wireless card is connected to the computer and let the computer detect it and then a Found new Hardware wizard will come up just follow it , but if still fail better call Linksys tech support and let one of their tech walk you through with the process also to check if the wireless adapter is bad, they are open 24/7 this is the number 800-3267114....
Hope that helps..........
Sep 26, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
