Question about Timex Ironman 30 Lap 53952 Wrist Watch
Removal of back of ironman watch once the screws are removed
  • Timex Master
  • 3,957 Answers
Slip something thin (i.e. fine knife blade) under back and pry up. Careful, do not cut the gasket!
Posted on Mar 28, 2015
Remove back of timex indigo watch
If it has screws, remove them. Otherwise, pry off the back.
Sep 12, 2016 | Timex Sport Ironman Indigo Watch - Blue/b...
I have the Timex IRONMAN Triathlon Chronograph 5G671 and the bands fit over the bezel and overlap and hold the back housing. To pop the back off and replace the battery, I'll need to remove the watch...
Yes, you have to take the bands and plastic casing part off. All screws are clearly visible. Just undo them and the parts will come off.
Nov 15, 2010 | Watches
How do you replace the battery in a ironman triathlon sleek digital watch
Thank you for contacting FIxYa.
Turn your Timex Ironman face down and remove the four screws holding the back cover in place.
  • Remove the back case cover by gently prying it up with your screwdriver. Be careful to avoid disrupting any electrical contacts with the tip of your screwdriver.
  • Remove the interior sticker that covers the battery by lifting it up with the tip of your screwdriver. It should come off relatively easily. At this point the small circular battery should be visible in the compartment.
  • Lift up the small metal clip (battery strap) that covers the battery using the tip of your screwdriver.
  • Remove the battery from its housing and replace it with your new battery (available at any electronics store or online). Reassemble the watch in the same way you to took it apart.
  • Sep 01, 2010 | Timex Ironman Triathlon 50 Lap Digital...
  • Turn your Timex Ironman face down and remove the four screws holding the back cover in place.
  • OR take to a professional jewelry store/watchmaker.
    Good luck.
    Aug 21, 2010 | Timex Ironman Triathlon 50 Lap Digital...
    How do I change the battery in my Timex Iron Man Triathlon? I removed the 4 screws in the back but cannot remove the cover because of the overlap of the wrist band.
    You will need to remove the wrist first before the cover will come out.Else pull the wrist out and allow it to leave a gap and then you can move the cover out.
    Dec 19, 2009 | Timex Sports Ironman Triathlon 100-Lap...
    How do you unlatch the battery of a timex ironman watch. I have the back open now
    You will need to look for any screws holding down a plate over the battery. Sometimes these only need to be loosened and sometimes they have to be removed. Sometimes the plate can be lifter slightly and the battery slide out from underneath. I hope this helps you. Best luck
    Nov 19, 2009 | Timex 50-Lap Ironman Triathlon 59221 Wrist...
    Timex data link band
    good morning ! remove the spring bar carefuly to remove the band on your timex data link ! use screw driver to open the case back ! be verry careful to do that ! thanks !god bless !....
    Aug 29, 2008 | Timex Sports Ironman Triathlon 100-Lap...
    Changed battery on ironman, watch got wet, now doesn't work
    The bad thing about most Timex watches is that once you open them it is very hard to resael them again. The thing is that , the screws are metal, and your trying to tighten them into a plastic back. If you try to tighten them too much you mess up the tap. When the back is first put into the watch there is a very small hole. When they screw them in it's like a wood screw it taps itself in to the back. Once that has been done once it is very hard to keep the same tighteness it started with. Your best bet is to get a watch with a metal screw-on back with a metal casing too. That way you can tourque really hard and make sure the back is tight. If you decide to have the battery changed, make sure they silicon the seal.That's about as much protection agaist water you have with that watch.
    Jul 07, 2008 | Timex 50-Lap Ironman Triathlon 59221 Wrist...
    Can't See Display Timex Ironman Triathlon
    I have an Ironman also and I agree it is harder to replace the battery than you think. There are electrical contact surfaces inside that have miniscule tolerances in terms of the spacing they have for clearance. You are expected to press on these things with tweezers to reset the battery (as discussed elsewhere on the web), but if they get bent down, they will short out the circuit (a permanently blank display), or the might be out of alignment (a reset every time you press one of the control buttons on the outide of the watch). If you think this has happened to you, open the case (again) you can use a small tool to carefully lift the metal contact back up off the contact plate. Also make sure the back of the case is on tight as this also plays a role the electromechanics of this watch.
    Other than that, I admit I really like the Ironman, so easy to use and set.
    Good Luck
    Sep 19, 2007 | Watches
    Timex Ironman 30 Lap 53952 Wrist Watch Logo
    51 people viewed this question
    Top Timex Watches Experts
    Ross Keen
    freddyfox
    Jerry Greenberg
    Jerry Greenberg
    Are you a Timex Watch Expert? Answer questions, earn points and help others
