Question about Kitchen Appliances - Others
Cleaning a toaster cusinart T190 - Kitchen Appliances - Others
2 Suggested Answers
SOURCE: toaster latch does not stay
for Cuisinart cpt160: If the latch will not stay down it is because the electromagnet at the base of the toaster, which is supposed to activate when you push the handle down, is burnt out. I pulled my toaster apart and did a test of that mechanism and found that the solenoid was fried (open circuit). There are no replacement parts.
Posted on Mar 03, 2012
Cleaning a cuisart T190
Unable to source your make and model. Manuals are available here if you have misplaced yours: https://www.cuisinart.com/manuals.html
Cleaning instructions will be included in the manual.
Mar 28, 2015 | Office Equipment & Supplies
How to clean T-FAL toaster
Hi Anonymous
The toaster has a removable tray that unclips at the botton for easy cleaning. If you have a stainless steel toaster and are enquiring about cleaning the surface use a soft clean cloth dampened with water and wipe it down regularly ONLY WHEN THE SURFACE IS COLD. If the surface is scratched you can try a stainless steel cleaner.
Hope this helps
Kind regards
Aug 15, 2014 | Dualit 20247 2-Slice Toaster
Bread stuck in the bottom of a cusinart rbt 380c toaster
unplug the toaster and either let the bread dry out to the point it will crumble and be released, or use thin tongs/knife/needle-nose pliers to carefully remove the bread.
Dec 31, 2012 | Kitchen Appliances - Others
How can I clean my toaster oven?
Cleaning a toaster oven is a simple task; however I will post a great video tutorial that should be helpful.
http://www.youtube.com/watch?v=q11hxub8CfA
Jul 17, 2012 | Oster Toaster 4 Slice 7 Settings Food...
My samsung t190 is flickering. i've tried updating the driver, change the cables, tried to plug it to another computer, it still turns on and off. and the language option appears everytime it turn on.
Contact an authorized Samsung dealer.
Go here for Samsung support, change the country if you are in the UK, then type in the serial number for the product. In this case T190. Here you go
Jun 13, 2011 | Samsung T190 19" Widescreen LCD Monitor
Toaster latch does not stay down on Cusinart CPT-120 compact two slice toaster
Jan 09, 2011 | Cuisinart CPT-160 Metal Classic 2-Slice...
Do you work on toasters? after cleaning toaster, heating elements not all working
wiring may have gotten wet while cleaning try using hair dryer,blow through all the vent holes for a few minutes
Oct 06, 2010 | Oster Kitchen Appliances - Others
Cuisinart Toaster Oven Broiler Not working properly
This is not a defect - it is just how the unit operates. You can set it to Broil, and the top element should not come on. Make sure the wire rack is turned upside down so that it curves inward and try one more time.
-Tha Mp3 Doctor
Jan 04, 2009 | Cuisinart TOB30BW Toaster Oven with...
Kitchen Appliances - Others Logo
150 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
