Question about Refrigerators
How to open inside light cover on sumsung fridge RL43WCIH. The bulb is not working and cannot open cover. Thx, Mpumelelo
How do I replace the light bulb on Sanyo SR-3770S?
use a flashlight and look around the inner panels of it . there is usually a plastic cover over the bulb(s)
Jun 21, 2015 | Sanyo Refrigerators
HOW TO CHANGE A LIGHT BULB INSIDE THE FRIDGE?
You usually unclip the bulb cover by squeezing it gently. Then unscrew the bulb. Take it to the store to get one that matches. Replace, then refit cover.
Aug 19, 2014 | Whirlpool Refrigerators
Fridge light does not work.
Some appliances have electrical schematics on the back of the fridge, some are hidden behind rear cover. Wire,Switch or fuse..not much else it could be.
Aug 24, 2012 | GE Refrigerators
Whirlpool side by side GD25HAXNQ00 Light is out in fridge - including lights showing temp setting - it is not the bulb - what else can it be. Cooling is still fine with both fridge and freezer
you may need a board that is located on the rear of the fridge. pull the fridge out and unplug from outlet. locate the cover on rear and remove screws and open plastic cover. replace the board and new bulb. try this site and it is a bit pricey. http://www.appliancepartspros.com/Appliance-Parts/whirlpool-electronic-control-board--item-number-ap4334000.aspx but to call a repair service it will be around 300.00
May 03, 2012 | Whirlpool Refrigerators
REPLACE LIGHT IN FRIDGE
- Unplug the refrigerator from the electrical outlet.
- Locate the bulb on the inside of the refrigerator.
- Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
- Unscrew the old light bulb.
- Screw in the new light bulb.
- Replace the light cover. Plug the refrigerator back in. Test your new light bulb.
Hope this helps, please rate if the solution was helpful, thanks!
Oct 08, 2011 | Refrigerators
How to change bulb in fridge
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb, you can buy a new bulb at any home improvement center. Insert the new light bulb and replace the cover. If the light on the refrigerator is not working after changing the bulb, unplug the refrigerator. Using a screwdriver, gently pop out the push-button collar on the inside side wall of the refrigerator. There will be two wires connected to the push button switch. Remove the two wires and replace the switch. You can purchase this part at any appliance repair center that carries parts. Make sure you write down the model and make of your refrigerator and take the information with you before attempting to purchase parts.
Jul 04, 2011 | Whirlpool Refrigerators
I have a Hotpoint HMB313I integrated fridge freezer. When I open the fridge door no light comes on. Should there be a light in the fridge? If so, could you tell me please where the light(bulb) is located...
Hi!!
The light bulb is usually located in the center top of the fridge box, you may need to get on your knees and look up to see it. They usually just screw out, in case there is a plastic cover, just squeeze it and remove it. The replacement bulb can be found at Walmart or KMar it is call Appliance Bulb.
Good Luck!! Don't forget to rate this post!!
Jul 18, 2010 | Hotpoint Refrigerators
Electric light cover missing from new Beaumark fridge
Yes, but with a 25 watt bulb its only radiating heat while the door is open and its not that much..as far a lens cover goes. i found no info on that either..
Jul 26, 2009 | Refrigerators
Fridge freezer noise problem
Yes...The same thing happens to me. It's coming from the back of the freezer and it's where ice gets clogged around the blades. The best thing to do is turn it off and defrost it. Even though there's no ice inside the freezer, being frost free, this will sort your problem i'm sure....
Sep 30, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
