Plus code? need it to recorded?
  • Televison & ... Master
  • 5,056 Answers
That would be the Video Plus system. By pressing the plus code button on the remote a screen will pop up with spaces to add numbers. These numbers used to be found in TV guides. Each programme you want to record will have it's own numbers. So if the show you want has a number say of 679 you enter that number using the channel keys on the remote. When you have the number on you press OK or the enter key depending on the remote and model number. This will then set the timer record.
Unfortunately many TV guides (in the UK) no longer carry the numbers. And if the VCR is an analogue one it won't record anything if you are in the UK. However if you live in a country which still has the service then it will work.
If you are using the video with a converter box, unless you can find a TV guide with the numbers in then you will have to use the manual record setting.
Posted on May 08, 2015
I want to record a program for later in the day. When I record on TV1 in Dual Mode, why does it record on TV2 in another room instead of TV1?
Hey there, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. It sounds like your DVR recordings may be interfering with another recording you already have set up. What you can do in order to fix this issue is change your Record Plus setting to TV1 instead of TV2. In order to do this you must first press the Menu button on your remote control then Select 8(Preferences) then 5(Record Plus). Once you have selected record plus you will need to enable the option as well as set your Record preference to TV1. Depending on the model of receiver you have the menu numbers may be different but the options (i.e. preferences and record plus) will be the same. I hope you find this information useful but if this does not work or you have any other questions or concerns feel free to email me at Cheri.Torres@Dishnetwork.com. Thanks and have a great day!
Feb 20, 2011 | DISH Network ViP722 DTV Receiver /...
Auria eq5588, cannot find code for DTV.
Auria is not even in the menu here so I had to select DirecTV DVR DTV. Someone needs to keep up with the brands. Anyway, the DTV codes for the Auria EQ5588 are: 11423, 10017,11265, 10178, 10856,11178 These are the codes. Mine worked with the first one.
Feb 16, 2011 | Directv Plus DVR DTV Receiver / 100-Hours...
What is the vcr plus code? where do I find it?
i would like to obtain codes to record programs on a vcr that needs vcr plus codes
Mar 06, 2010 | JVC DR-MV1SU DVD Recorder/VCR
Trying to make DVR work after 2-17-09
I have been able to record down converted HDTV shows on my Panasonic DMR-EH50 recorder directly to the unit's hard drive and/or directly to a blank DVD-R disc.
I do not know of any DTV converter box that can provide the proper codes to the Panasonic DMR-EH50 to allow recording and scheduling of shows using the unit's built in TV Guide menuing functions (the program recording codes are essentially VCR Plus codes in the USA and VCR Video codes in the UK, and this technology was previously owned by TV Guide/Gemstar but was purchased by Macrovision within the past couple of years.)
When the DMR-EH50 is hooked up to standard RG-59/U coaxial TV cable, the cable company provides the specific VCR Plus recording codes, as well as auto setting the time and date information required for the TV Guide recording schedule menus. The VCR Plus recording codes are sent via the cable company through the coaxial cable to the end consumer's recording device. Since Gemstar's VCR-Plus patents are now owned by Macrovision, I am not sure of how this works (or will work) for non-cable/non-satellite customers or if such codes will be made available by Macrovision to record shows when one receives HDTV signals (or down converted DTV signals) from an over-the-air antenna.
Though the DMR-EH50 recorder can only record at Standard Definition (SD) broadcast resolutions, I connect the DMR-EH50 to my High Definition TV using the three progressive scan YPBPR output cables and switch my HD-TV into the YPBPR mode when I want to watch shows from the DMR-EH50.
YPBPR are the analog video signals carried by three color coded component video cables. The green cable carries the Y signal; the blue cable carries the PB signal; and the red cable carries the PR signal. The added benefit of using the YPBPR hookup is that you can 'up convert' a standard DVD disc (non HD Blu-Ray disc) in progressive scan mode to somethin akin to 720p resolution using the DM-EH50 (or any other progressive scan DVD player) to get a better quality image on your HD-TV.
Visually speaking, the same appears to hold true for playback of programs recorded on the DMR-EH50's hard drive even though down converted via the DTV converter box, and when played back on an HD-TV using the YPBPR progressive scan cabling hookup.
I also been able to successfully record programs from the DTV converter box to the DMR-EH50 recorder in both 16:9 wide screen and 4:3 normal aspect ratios, but again only in Standard Definition quality.
For NTSC and PAL formats, the correct aspect ratios for any particular TV (the rectangular height and width of your output resolution for a TV screen) can usually be setup correctly for most any DTV converter box by going carefully through the menus on the converter box. Though the converted DTV often will yield 'better looking TV' than cable, it's certainly not high definition however, as the purpose of any DTV converter box is * not * to yield a High Definition digital TV signal but a lower quality Standard Definition signal for viewing on older SD-TVs.
We must remember that what is happening here is that (by NTSC USA standards), we are transcoding (i.e., down converting) an over the air 1920 x 1080p (progressive scan) High Definition digital broadcast signal, captured by your over the air antenna, back to a Standard Definition 720 x 480 resolution analog broadcast signal (the 720 x 480 resolution is a 4:3 aspect ratio.)
Hope this helps a little -
Greg Loveria
Conklin, NY USA
Jan 03, 2009 | Panasonic DMR-EH50 DVD Recorder
Line in recording procedure
i cant really offer a definitive solution. I just starting playing with my zen and finally figured out how to use the line in recording feature. I also realized that i needed an adapter to plug in the zen to my stereo; luckily my husband has two. I have read how to delete the recordings. I havent tried to use it as of yet; but if i have any trouble i will contact you back. thanks again, new to zen
Nov 06, 2008 | Creative Labs ZEN V Plus MP3 Player
Direct TV HD Receiver/Recorder codes
Check the Innovage manual for the automatic code search. If it works, you still may not have full control of your HR20. Try to program your Directv remote to operate your components
Jul 07, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
How do I change the voice mail recorded message? How do I get a manual for this existing system?
IF you know the password for the mailbox then log into the voicemail by dialing the Stratagy access code, after Stratagy answers dial * , then your user ID mailbox number plus #, then your security code plus #. The User Main Menu plays, press 2 to change your greeting, the Select Greeting Menu plays, press the greeting number, the Record Menu plays, press 2 to record your greeting, Record greeting, as soon as you finish press #, the Record Greeting Menu plays, press 1 to review or 2 to re-record. Press 9 to save and return to the Select Greeting Menu and 9 again to return to the User Main Menu, hang up at this point.
Jun 08, 2008 | Toshiba DKT-2010 Corded Phone
Televison & Video Logo
177 people viewed this question
Top Televison & Video Experts
Electro Med Services...
