Question about Frigidaire Stove/Oven/Range Cooktop - 318079348
How do I reprogram a Frigidaire stove/oven after replacing the eoc?
  • Official Brand Answer
  • 2,267 Answers
Thank you for your post, Roy!
Based off the information you have provided you need to reprogram your Frigidaire range because you have replaced the oven control. The best way to reset your range is to disconnect power from it for roughly ten minutes. If that does not help resolve your issue you may need to have another electrical component changed and I would recommend seeking assistance from a professional technician for proper repairs. I hope this information is helpful. -Matt
Posted on Apr 02, 2015
Oven Lock stuck open before start of self-cleaning cycle I get a code F9, a flashing lock light, a continous beep and a dr code on the panel when I try to set self-cleaning cycle again.
Thank you for your inquiry, Lucie!
From what you have described your Frigidaire oven lock is stuck open and you are receiving error codes "F9" and "DR". The "F9" error code stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Apr 30, 2015 | Frigidaire Stove/Oven/Range Black Glass...
I have a frigidaire ples389dcc as soon as i plug it in it give me a pf code
Good Morning Paul, thank you for your post!
Based off what you have described your Frigidaire range, PLES389DCC, is providing you with an error code of "PF" and "F1" as soon as you turn it on. An error code of "PF" stands for power failure this could be a possible problem with your control panel or power cord.
The error code "F1" stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. If you continue to have issues with the "F1" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. Hopefully this information has been helpful. -Matt
Apr 10, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
Frigidaire error code stove f 15
F15 Controller self check failed. Replace the EOC.
Here's the code explanation
Sep 06, 2014 | Frigidaire Gallery 30 Slide-In Electric...
Code f1
Hello Friend, this is Z. Thank you for allowing me to assist you!
If you are getting an error code F1, it usually means that your Frigidaire range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree.
Jul 16, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
I was trying to on oven all of a sudden massage appear f10
Hi khan, this is Z! Thank you for your post!
Typically error code F10 indicates that your range has detected an issue with the runaway temperature (overheating). Try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. I suggest waiting approximately ten minutes and then turn on your range. If the error code does not clear, I would recommend contacting a professional technician to assist you in the exact diagnosis and repair of your range. Most likely the EOC (electronic oven control) will need replacing. Hopes this help!
Mar 29, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
What does a F550 code on a Frigidaire Stove mean?
That means that the oven control board is having problems. Replace it.
Feb 06, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
Electric range
Good Morning Kent, thank you for allowing me to assist you!
Typically error code F1 on your Frigidaire appliance indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to your appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree.
Feb 05, 2014 | Frigidaire Stove/Oven/Range White Cooktop...
F14 Error
First please get the full model number of the range. Kenmore products are made by other manufacturers and the error codes will depend on the manufacturer.
Most likely, you have a Frigidaire range (for example a 970. model). Then the F14 code could indicate a problem with the P12 ribbon cable connector tail, a bad EOC (control unit), or touchpad. First try disconnecting and reconnecting that cable. Next the EOC should be replaced. Finally the touchpad should be replaced.
If this is a brand new range, contact Sears to get a repair person to fix the range. If you bought it used, see the above possible solutions.
I hope this helps.
Dec 24, 2013 | Kenmore 30" Electric Double Oven...
Fridgidare model number mef305pbwf eyes stopped working
Hello James - Thank you for your question! Let's try resetting the range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the unit back on. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the EOC (electronic oven control), a potential wiring failure or faulty elements. In that case, a certified technician would generally replace the faulty part after proper diagnosis.
Jul 16, 2013 | Frigidaire Stove / Oven / Range Cooktop...
I have a Frigidaire Gallery Professional Series Stove and Oven unit. The oven temperature indicator light has been fading for years and is now barely visible. Everything else on the control panel (timer,...
Hello arab125 - I understand that the timer and clock works fine, however from what you have described it sounds like the range could possibly have a wiring failure, faulty sensor, or an issue with the EOC. I would suggest contacting a professional to move forward accurately.
Oct 08, 2012 | Frigidaire FGEF3031KB Gallery 30"...
Frigidaire Stove/Oven/Range Cooktop - 318079348 Logo
260 people viewed this question
Top Frigidaire Cooktops Experts
Oloyede Monsuru
ray gallant
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
