Question about Miscellaneous
Where can I purchase this capacitor? I was told that if I can not find this exact capacitor I can combine two small capacitor to get 125 uf is this true?
  • 3,957 Answers
Is this a motor start capacitor? If so, you can get from the following:
http://www.amazon.com/HL008500AV-Campbell-Hausfeld-Capacitor-250VAC/dp/B0078PAR3U/ref=sr_1_1?ie=UTF8&qid=1427545862&sr=8-1&keywords=cbb60+120+uf+capacitor
You did not specify if this is a leaded or screw terminal, what it is used for, or any of the dimensions. If you are unsure, take the capacitor to an electronics repair store and ask them to source a replacement.
In this instance, I would not suggest trying to connect two capacitors in parallel to replace it. There should be replacements available.
Posted on Mar 28, 2015
  • 1 more comment
  • Juan Ruiz
    Juan Ruiz Mar 28, 2015
    I purchased a start capacitor and it burned like in 5 minutes of use so I guess it is a run capacitor or a start/run capacitor. As for the terminales it is a lead terminal
  • Juan Ruiz
    Juan Ruiz Mar 30, 2015
    Any input??
  • ka4iup
    ka4iup Mar 30, 2015
    http://www.mouser.com/capacitors/
Where. Is the capacitors
the capacitors are connected to the electric motors and compressor
they will be small units in the room unit and large unit on the outside unit
Oct 14, 2015 | Heating & Cooling
Akai Flatscreen T V will shut off write After U TURN IT ON
sounds to me like capacitor faults on power supply,,,check for swollen capacitors that are leaking a black substance from the top of capacitor when swollen,,,(easy enough to see),,try replacing the capacitors with the exact same value in uf or mf but use a slightly higher volatage capacitor,,ie,,if it says 16v on the side of capacitor use the same or a higher voltage (if you use a higher voltage capacitor make sure theres enough space to refit as the higher the voltage the larger the capacitor,,make sure you replace it with the same amount of uf or mf which is also written on the side of the capacitor,,,,,hope this helps,,,
regards
kenny
Jul 04, 2014 | Televison & Video
Indoor fan barely turning
the three post capacitor has c for line voltage in, the f or fan is for the outdoor motor,and com or comp goes to start winding compressor.youll have to follow wires from indoor motor to find capacitor. to find wires to outdoor motor to capacitor you have line voltage and capacitor wires .look for schematic it would help or send colors of wires from both motors and compressor common,start .run.
Jun 07, 2013 | GE Zoneline AZ55H07D Air Conditioner
Where can I purchase capacitors C8059 and C8060?
The CXXX is not important (fabricant reference only) when bying the capacitors, the importance is the (VALUE in uF, the VOLAGE and the FORMAT/SIZE) First unsolder the capacitors from the board (take notes where the capacitors goes on the circuit board and polarity as well +/- for electrolityc type) than take them to a local electronic parts reseller (radio shack/the source, etc..) and show them to the clerk, than ask for the same thing (value, voltage and size) unless you have a lot of space on the circuit board or in the enclosure, the size is less important... (VALUE in uF has to be the exact same thing and VOLTAGE has to be the same as or above)... if they are CERAMIC capacitors the voltage and value are usually coded in numbers, the clerk should be able to provide you with a replacement with a good CROSS REFERENCE TOOL (IF NOT GO TO AN OTHER STORE) they are not competent enough...
Jul 19, 2011 | Philips 50PF9631D 50 in. HD-Ready Plasma...
I just want to know what the designation 216/259 means and if it is a non-polarized electrolytic capacitor. This is to increase my general knowledge.
generally electrolytic capacitor is polarized..and if im n0t wrong 216-259 stand for tollerance microfarad- uf and 110-125 stand for tollerance volts-v pls check for the symbols on that capacitor
Apr 30, 2011 | Mallory Motor Start Capacitor 216-259 Mfd...
Light comes but fan doesnt the capacitor is swelled up where can i buy another capacitor? the numbers are E185116 C22.2NO.190
Try the link below. Without having the UF (electrical size of the capacitor) it is hard to source exactly your capacitor. This one below should work.
http://www.westfloridacomponents.com/J131APE10/14uF+220VAC+Motor+Capacitor+Sheng+Ye+C61+E185116.html
Mar 19, 2011 | Dryers
Samsung LN32A330J1D - LCD TV - only 2 years old and power button is broken
Capacitors, capacitors and capacitors. I can't stress that enough. Common issue with these samsungs. Check those capacitors before changing any board.
If there is a bad capacitor in the power supply, you will either get one of two symptons.
1 - Solid red Led and thats it. You hit the power button and nothing will respond.
2 - You just hear a click repeatedly.
Dec 11, 2009 | Samsung LN32A330 32 in. LCD TV
Unwanted horizontal lines
I had the same problem on a 2003 Toshiba 32A13 TV. I replaced C407, 100 uF 35V and it fixed the lines. I noticed that this capacitor was mounted near the heatsink for the vertical output IC. I don't know if the heat aged the capacitor faster or not. The only cost was $9.99 for a 32A13 service manual download. I had a new capacitor in my misc parts box and it has a 105 degrees C rating.
Jul 22, 2008 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Vertical hold?
replaced this capacitors in vertical circuit.100 uf/50v,1uf/50v,1000 uf/25v,2.2uf/50v,47 uf/50v.this might not as exact as what is on ur tv.but, just replace those capacitors and see the result. hope this help u....
May 09, 2007 | Sanyo DS31590 31" TV
The blue light of the monitor keep flash and no picture appears on the screen
I have exactly the same problem with my Medion 17" TFT monitor. It is not the video card (tried changing it) or the motherboard. Fitting a different monitor makes the problem go away. The monitor does not display the "No Signal" message when unplugged from the PC either. It must be a fault in the monitor, and as it seems to be a design fault. I suggest you contact Medion and nag for a replacement.
Dec 06, 2006 | Medion MD 7317 17" Flat Panel LCD Monitor
Miscellaneous Logo
80 people viewed this question
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
