Question about Home Security
Can I add a second chime for upstairs working from the existing bell push
  • 2,963 Answers
Most likely, but unless it is wireless, you will need to run bell wire from the downstairs chime to the upstairs chime unless the wire appears to be available any way. Probably just the connections are needed.
Posted on Mar 28, 2015
Why does my chime ring when next door has visitors
You're using the same channel. Change the channel the bell-push and the bell work on, by following the instructions that came with the bell and bell-push units.
Mar 21, 2015 | Cars & Trucks
Diagram for connecting a battery operated door chime to push button
IF you are going all elec,you need a door bell,bell transformer and of course the push button. This is all low voltage so phone wire will work.You are just using 1 pair of wires so pick a pair such as the blue pair.Wire from push button to transformer to door bell.It is not polarity senstive....simple to do
Mar 17, 2015 | Cars & Trucks
How do I set the chimes
Chimes are usually set from inside the bell-push, so that you can have multiple bell pushes and different chimes for each one.
Feb 13, 2015 | Home Security
Will my wireless bell push work with another manufacturers door chimes?
Doubtful they are compatible. If they are set by dip switches and you set them the same bot doesn't work-not compatible.
Jul 17, 2012 | Home Security
Evo 46400PL Ed3 wireless door chime, no connection between the bell push and the chime unit.
Maybe the batteries are emty, is that not the problem then lay down the bell push in your living room for 1 day, the companents can be a little wet, you can't see that ( they look to be dry) I had this problem too and it works.
Jun 26, 2011 | Vacuums
I have a desa DD100S wireless door chime but for some unknown reason the bell push is not working, I have tried replacing the battery but still unable to ring chime. The actual base unit is fine and...
Sandra, the contacts in bell push may need cleaning, as well as some minor readjustment of the contacts. Insects love to get into the bell push and can clogged it up. If you find that this doesn't solve the problem, Contact the Zenith Company 800-858-8501 to purchase a replacement.
Mar 09, 2011 | Desa International White Wireless Plug In...
I have a byron SX85R plug in wireless door bell, i need to change the frequency/ or code, keep false alarming, cant find the instructions , also with the alarm, is a batterie alarm no. SX81R, which came...
From User Guide: Interference from a similar unit operating nearby: a) simply remove the batteries from the push button and door chime units and rest for 10 seconds, this will erase memory b) Insert the batteries into the push button and door chime units, the door chime unit will give 2-beeps to indicate that it is ready for the new registration code. Press the Push Button once, it will generate a new operation code randomly and send a wireless ignal to the door chime unit and it will sound to indicate that new operation code is registered and memorised.
(Note with this unit SX85R the door chime is mains powered, not battery powered, but above instructions are the same)
Oct 10, 2009 | Bell Cocoon Child Carrier
Installed new reg. doorbell on first floor now wireless upstairs
when did this work last?
is the new unit on the first floor designed to work with the 2nd floor unit?transmission,
you may have to tune the 2 units to the same transmission frequency before they will work to gether,some wireless units only have a short range of transmiting distance too
have you checked the power supply to the receiver upstairs and the bell push battery on 1st floor?
they seem to be the most common solutions for this type of device
if its the age of the unit then its time to replace it
Aug 22, 2009 | Bell Sports Wireless Door Bell with...
Home Security Logo
97 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
