Question about IBM 6000VA RACK UPS 200/208V Computer Parts
Ups is on buck, how to solve - IBM 6000VA RACK UPS 200/208V Computer Parts
Zynga support
If you can, go to the support pages for Zynga's Farmville and see if you are able to go to the live chat option. I've had similar problems when I use to play Farmville. The live chat representative always solved the problem, and they even gave me more farm bucks than what I had to when trying to resolve the problem.
Jan 31, 2014 | Facebook Apps
2005 Kia Sportage. Looses acceleration going up hills. RPM's are up, but no acceleration. This has happened in the past (during hot outside temps), fuel pump was replaced and it seemed to solve the...
When going up hills is the engine bucking and missing? Also for the hard start warm problem, check the fuel pressure regulator for leaks into the vac line.
Jul 09, 2010 | 2005 Kia Sportage
The car bucks and dies after it gets warmed up and gives me code P1391 how do i fix it?
P1391=Intermittent loss of CMP or CKP,
Thats the cam sensor or crank sensor,
Jan 14, 2010 | 1999 Dodge Intrepid
Hello how yo get back bios password or to buck
yes you can reset bios settings to factory defaults so then it not ask for password.
For that you have to pull cmos cell on motherbord for 10 minutes then all settings of bios are reset.
You can find cmos cell on motherbord chip.
Open cpu cabinet and find motherbord.
Let me know if you need more assistanse.
Thanks.
Sep 15, 2009 | Computers & Internet
2003 Lincoln Navigator stumbles/bucking under mild acceleration
I have a 2003 Nav with the exact same problem. I've found it diminishes when taken out of overdrive. Also it's intermittent but more towards bucking. Sorry to post this under solutions.
Aug 14, 2009 | Lincoln Navigator Cars & Trucks
07 Chevy Impala LT blower motor wont turn off even with the key off....need help fixing this in the worst kinda way!!!
If your blower continue to run while the car is turn off it would be your relay sticking. look for the relay, pull the relay see if it stop. if it does replace it. I would first chage out your relay and before you tear up the car. Go to the junk yard and get one of those relay for couple of bucks, instead buying new one from a dealer for 30 bucks and see it that solve the problems.
Jun 14, 2009 | 2007 Chevrolet Impala LS Sedan New Cars
Mercury cougar 1989 Bucking problem
i had this problem,
the air sensor was not functioning.
cleaning it solved the problem
May 11, 2009 | 1994 Mercury Cougar
1994 FORD 5.0 BUCKS UNDER A LOAD
I had a similar problem with my 1999 E150 Van. After changing plugs and wires didn't solve the problem, my service technician said it was a problem with the automatic transmission. That was hooey! (technical term :-) In my case, the service engine light came on. I don't remember the exact codes, but they pointed me to 2 problems. 1) Misfire on #4. 2) O2 sensor error.
I researched the O2 sensor problem and found out that it was probably caused by a dirty Max Air Flow (MAF) sensor. On my van, the sensor is accessible by taking out the air filter. It's a very fine wire just beyond the filter. Spraying the MAF sensor with some electrical contact cleaner solved the bucking problem. (CRC brand electrical contact cleaner available at Wal-Mart for about 3 bucks)
Hope this helps.
-- Wes Byers (wcbyers)
Jan 03, 2009 | 1994 Ford F150 Styleside Supercab
Does not cool
I had the same problem a year ago. My solution was replacing the capacitor on the compressor motor which I could have done myself for a few bucks. Ended up paying a repairman $100+. Try replacing the cap yourself for a few bucks. If it doesn't solve the problem, you are only out the cost of a capacitor. Don't substitute values. Get the correct one!
Dec 20, 2008 | Whirlpool GD5SHAX Side by Side...
IBM 6000VA RACK UPS 200/208V Computer Parts Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
