Question about Jenn-Air Cooktops
Why Is my cooktop tripping the breaker?
Jenn Air CVE3400. A couple of months ago we returned home to find that the breaker for the unit had tripped. I removed the cook top and found the dual burner control had fried. Replaced the control, problem solved. Now it has happened again. This time there is no obvious damage to any part or wiring. I disconnected the new control and still have a problem. Neither time was the unit in use.
  • Dave May 01, 2016
    Turned out my Jenn Air blower switch shorted out. The switch was discontinued. Found a rectangular swich that fit into what was an oval hole. Then unstuck the relay.
    New Friend:
    Problem Solver:
  • 9 Answers
My blower switch shorted out. Could smell the plastic once removed. Liquids dripped into contacts during cleaning. Switch replacement obsolete. Found switch @ Ace. Made modifucation to panel to accept rectangular switch.
Posted on May 01, 2016
  • Jenn-Air Master
  • 2,992 Answers
Check wiring connections from at the electrical box and the stove's connection to, also connections between the connection cord and the cook tops connection box. Somewhere along the line you have a short to the bare copper ground wire. It could even be in the breaker box itself. You may want to call an electrician.
Posted on Mar 28, 2015
  • Robt
    Robt Mar 29, 2015
    Yeah, did all that. The problem occurs only when the unit is connected, not "on", just connected. If it were in the line side wiring, that wouldn't matter. Thanks, guess I'll pull it back out and try disconnecting 1 controller at a time and see where that leads.
Burn knobs and fan turn on, lights are on but the burners don't come on and there is no heat.
hello after looking at your wiring diagram the only thing it can be is a blown breaker in your home. half of it works off 120v of the 240v circuit and the heating elements off the other 120v line. so you are only getting half the power to your unit. turn the breakers off and on see if maybe it just tripped.but its not the cooktop. hope this helps please dont forget to rate me thanks ken
Jun 06, 2011 | Jenn-Air JED8430 Electric Cooktop
Large electric burner will not turn on
you need to check the wiring to that burner it appears that there has been a short to the burner
Apr 04, 2010 | Jenn-Air 35 in. JEC9536ADS Electric...
Jenn Air cooktop JED8430ADB not heating, fan & knob lights work?
Some times a breaker can be partially tripped and not visible . You should try turning the breaker off and on several times.
always unplug electricity before attempting to repair on any electrical appliance
Sep 09, 2017 | Jenn-Air JED8430 Electric Cooktop
Electric shock from cooktop, didn't trip breaker,
Where did you smell the smell was it from the fan switch. turn the power off and take the screw out of where the fan switch is and check the wires to the switch and the switch itself. sometimes the jennair cooktops have issues with that switch. let me know how it goes
Sep 20, 2009 | Jenn-Air JED8230 Electric Cooktop
Stove top keeps turning off
if your breakers have become week they may trip with a lesser amp draw.sooooo if they trip right when you turn on a switch on the range, then it is a short in the range.if it trips after your using it abit its your breaker.hope it helps God bless ,tom
Jan 08, 2009 | Jenn-Air JED8230 Electric Cooktop
Blown accessory fuse? jenn air cooktop jed8430adb
the unit doesnt have any internal fuses. you have a house fuse blown or circuit breaker that tripped. the fan switch can be found online or from your local parts house and make sure you get the clips to hold it to the mounting tabs.
next time you get ready to work on it, just make sure and turn off the power first as you will touch the metal terminals to the frame again.
Dec 27, 2008 | Jenn-Air JED8430 Electric Cooktop
Tripping breaker
Replace the burner and receptacle and you should be short free. You may also need to replace the surface element switch too if it doesn't come on at all or stays on high regardless off knob setting.
Dec 16, 2008 | Jenn-Air JED8430 Electric Cooktop
Tripping breaker
I had the same problem. Mine was caused by liquid seeping into the infinite switch (the switch that gets rotated by the knob to set burner temperature). This caused one of the live wires to short to ground within the switch. Bad Design IMHO. Replacing the switch fixed the problem (you can get replacement parts at Searspartsdirect.com - search using the cooktop model number). To get at the switch you need to remove the top by taking off only the top row of screws all around the unit and also in the down draft cavity.
Sep 20, 2008 | Jenn-Air JED8430 Electric Cooktop
Cooktops Logo
331 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
