Question about Garden
How to opperate gr1600 - Garden
    Top Expert:
  • Garden Master
  • 44,428 Answers
Read your owners manual
Posted on Mar 28, 2015
How to push back words when not started kubota gr1600?
sounds like a cotter pin has come out off the linkages that control reverse.you need a mechanic or if you are mechanically minded do it your self you will need a replacement pin and split pin.
Nov 08, 2016 | Cars & Trucks
Truck-1999 Z71 4WD- gets stuck in 4WD lo.
I would check the shifting mechinizuns . If its manual _ cable opperated system have someone shift it see how it moves on the transfer case and how smooth the cable opperation is . The system is bascaly a vacuum opperated system after that but if it goes into 4 wheel then the system is working . The other place you could look is at the front transaxle adjustment _switch witch is a cable opperated system that is controled by a vacuum switch on the transfer case and an acuater under the battery tray to pull the cable with the froce of the vacuum from the transfer switch engine vacuum . If you have an electronic shift control inside the cab it still works basicaly the same way except you have another electrical switch to check. It dosn't sound like you have a big problem because the system works it goes into 4 wheel but you need to find out witch part or switch is sticking mechicaly or if its an electrical switch sending or not sending the correct signial to its compontets
Jun 30, 2011 | 1999 Chevrolet Silverado 1500
The rear brake light is dim unless you put full pressure on pedal. this is only for rear pedal ,front is fine
you may need a new rear brake switch, most bikes it opperates from a spring pulling from the rear brake pedal. some contact cleaner may help.
It may only need some adjustment, there is usually a bracket that you can turn the switch in, to make it opperate sooner
You didnt say what bike, but some switches opperate off the brake fluid pressure, in which case it needs a new switch
Jun 19, 2010 | Harley Davidson FLHT - FLHTI Electra Glide...
Check instalation sequences ,opperating routines
where there is much space except in c/ plz dnt download there
Sep 16, 2009 | Logitech Cordless Internet Handset Phone
Operating system not found
yes, the sys. settings is on the bios, scence theres nothing on the harddrive its telling you that you do not have windows (or any other opperating system) on it and it cannot run without it you can buy opperating sys. at wall-mart, bestbuy and other companys such as that.or if you have a windows (or other opperating system) you can run that cd and install
Apr 02, 2009 | Samsung (SP0822N) 80 GB Hard Drive
The drivers side window can be opperated from the drivers side. The passanger side window does not opperate from either side . It appears that the window lock safety swith on the drivers side is not...
If the problem was with the lock you would still be able to raise or lower the window from the drivers seat,most likely the window motor has burned up,I would try pulling the door panel and tap the motor most times they will work for awhile,but ebay has the whole window regulator with motor for 99.00 I had to replace both driver and passenger in my 01 grand cherokee.was a1auto I think on ebay.
Mar 10, 2009 | 1998 Jeep Cherokee
1993 Mitsubishi Eclipse stopped running (as if it was out of gas, but without the sputtering) I'd like to check the fuel filter and pump before taking it to the $hop (if you $ee what I'm $aying) Is there...
are these turbo cars and have u taken off the fuel rail to see if they are opperating if they are opperating (you can tell with a node light or just a 12v test light)then most likely its ur fuel control relay under ur center console if they are not opperating and it is a turbo car u should look at ur resister pack (a silver box on the firewall right by the dsm tag) and if they are not opperating and it is turbo ur non (either way) u could be looking at a bad ecu (verry common if they get to hot or to cold
Mar 07, 2009 | 1993 Mitsubishi Eclipse
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
