Question about HP LaserJet 1020 Printer
My 12A cartridge after refilling,giving left side blank page and right side little print.
  • 60 Answers
Can you tell me that is your tonner is ok before refill? If ok than cheak your tonner drum or see the spring in left side.If not than cheak your element paper on your printer inside.
Posted on Mar 31, 2015
  • HP Master
  • 1,121 Answers
Spring might be missed at left side., see the snaps as attached..
my 12A cartridge after refilling,giving left side  - 25612648-rcn0jvc11gtkfvrtor0xj5c1-1-0.jpg
Posted on Mar 29, 2015
    Problem Solver:
  • 13 Answers
Try shaking the cartridge well before using. Check for any dark spots on the cartridge roller it might be the cause for blocking the print.
Posted on Mar 28, 2015
    Problem Solver:
  • 20 Answers
May be cartridge drum door is complaint, so, laser is not passing properly, better go for new cartridge.
My 12A cartridge after refilling,giving wet type print
If you are getting smearing then likely the drum is dragging. If you simply added more toner without emptying the waste bin that would be the reason.
Aug 17, 2015 | HP 12A Toner (Q2612A) Printer
X2250 won't print form pc
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
May 01, 2013 | Lexmark X2250 All-In-One InkJet Printer
Poor print quality - dots on side of copies
Using refilled cartridges? avoid refilled one, remove cartridge, used blower blow out toner fallen in side,take 25 pages of blank pages print outs, then go to menu>configure device>fuser modes select clean page wait to clean it self, do this process twice or thrice till fell print quality good.. if no result replace teflon sleeve(replacing the teflon sleeve only professional can do)
Feb 01, 2012 | HP LaserJet P4015N Printer
My hp deskjet 6940 inkjet printer doesn't show me level of ink in cartridge
Print a diagnostic page If the steps above have not helped, print and evaluate a diagnostic page to see if the cartridges or the printer is causing the problem.
  1. Make sure the printer is on and loaded with unused, plain, white paper.
  2. Press and hold the Power button and then press the Cancel button. Release both buttons. The diagnostic page prints. Figure 1: Power and Cancel buttonsc00584735.gif 1 - Cancel button 2 - Power button
Step 4: Note which cartridges printed which areas of the diagnostic page You must identify which cartridge printed which part of the diagnostic page, so that if you find defects on the page, you will know which cartridge is the problem. However, you can install different combinations of print cartridges in your printer, and different cartridge combinations print different diagnostic page patterns. Your diagnostic page may not look exactly like the picture below, but the right and left cartridges will print in the same areas of the page no matter which cartridges are installed. Figure 2: Diagnostic page layout (the patterns in each area may look slightly different on your page)c00584715.gif 1 - Printed by the right cartridge 2 - Printed by the left cartridge NOTE: If you are printing in reserve mode (one cartridge is missing), the missing cartridge's area of the diagnostic page will be blank. Step 5: Check ink levels NOTE: If you have installed a refilled or remanufactured ink cartridge, or a cartridge that has been used in another product, the ink level indicator is inaccurate or unavailable. Look in the middle of the diagnostic page. The bars with "E" (for "empty") and "F" (for "full") at each end show the ink levels in the cartridges. As ink is used, the solid color changes to a faded color. Figure 3: Left (tri-color) cartridge almost full - right cartridge emptyc00235259.gif Figure 4: Both left and right cartridges almost fullc00235260.gif
Feb 22, 2011 | HP Deskjet 6940 InkJet Printer
How to refill, hp laserjet 12A cartridge, manually?
You will regret it if you attempt this. Although this is a small cartridge, it is difficult to remanufacture correctly.
Mar 09, 2009 | HP LaserJet 1020 Printer
HP Officejet 6210 printing blank pages
Hi steve well I suggest that you remove the cartridges and clean the little gold contacts on the carriage and the cartridge. If this doesn't work then install brand new original cartridges as the cartridegs that you have refilled the data ribbon may have been damaged when you refilled them..
Try the above and I hope it works for you
Thanks J
Oct 23, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 1020 Printer Logo
167 people viewed this question
Seeker5211
Seeker5211
