How to change belt of igins Bella 60 front load washing machine
  • rdjagger Mar 28, 2015
    Not sure it has a belt, but if it does usually access is from bottom.
    Top Expert:
  • Washing Mach... Master
  • 44,366 Answers
Call a service repairman
Posted on Mar 28, 2015
5 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: How to change a washing machine belt
Unplug machine. Remove back panel. loosen three nuts holding motor clutch assembley from bottom side of motor mounting plate with deep well socket, allowing motor mounting plate to slide. Remove clamp holding flexible drive coupler just above belt. Remove belt. Reverse to install, but remember to give a little tension to the belt by holding motor toward the back left corner while tightening up nuts. Tighten the nut closest to the center of the machine first.
Posted on Jul 09, 2009
  • 47 Answers
SOURCE: How doyou change a belt on a top loading washing
If you cant get to it from a cover on the front, It must be laid on its back or side to fix.
Posted on Oct 21, 2009
  • 6277 Answers
SOURCE: vb belt broken ignes bella
Sorry, this FixYa Washer Forum does not supply service centre numbers, engineers, spares or prices; it is just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
You will either have to search in your local telephone directories OR stay on line and search for '(make) washer service' for instance or '(make) washer spares' and hope that you can find someone reasonably local.
Sorry again ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 10, 2011
  • 242 Answers
SOURCE: My ignis Bella 60 front load washing machine inner tub has developed sideways play . It rubs against sides during cycle with soft rubbing sound and stucks
at the back of the washing machine is an inspection plate not large
turn off the power and pull the plug from the wall and turn it from the rear and see what is happening
Why does belt keep coming off when spinning?
Sadly, this is almost certainly drum bearings worn out and the drum spins off centre, causing the belt to come adrift (I'm guessing your spin cycle has become significantly noisier recently). Worse news I'm afraid, the IWC6125 uses a sealed, non serviceable drum, so this is really an uneconomical repair that will cost around 60%-75% of the cost of the machine when new
Sep 06, 2015 | Indesit IWC6125 Front Load Washing Machine
Mar 28, 2015 | Washing Machines
How to change belt on whirlpool ultimate care plus washing machine
Top loader? Turn machine up so you can see underneath, remove access panel, belt right in front of you. Fits over motor spindle and base of agitator spider
May 19, 2012 | GE WBSR3140DW Top Load Washer
Not spining
Check belt. Will need to till machine on side. Easy to change. Should be able to go to a bearing and power transmission store and find a belt. Look under local yellow paged for v belts.
May 14, 2011 | Whirlpool Washing Machines
My dryer starts up for less than a minute and than starts beeping and all lights start flashing. For a while i was able to change settings from 60 mns to towels and it would work. Now it starts for a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2010 | Dryers
Oct 21, 2009 | Kenmore 22422 Top Load Washer
Squeaky, noisy washing machine
Belts are an easy change. You access from the back of the machine. 3 or 4 screws take off the plate whihc will expose the belt. BE SURE TO UNPLUG 1st! so you don't get scocked
Feb 09, 2008 | Maytag MAH2400A Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
