Question about Kitchen Ranges
Two of The jets on my hob seem to be blocked and won't ignite .What is the solution?
    Top Expert:
  • Kitchen Ranges Master
  • 41,482 Answers
Something got spilled on them so they need cleaned
Posted on Mar 28, 2015
Two main hobs of Frigidaire FE50T11W are not working any help please :(
probably if you are a bit mechanical minded. uner the gobs you will find a brass jet that you can unscew and replace. It has a very small hole that is probably blocked so get new jets before you do this then you will know where to look for the units.
Oct 22, 2014 | Cooktops
Oven wont light keeps making the clicking sound smell of burning and smoke appears grill working normally?
Sounds like the jets at the base where the gas ignites are blocked. Try cleaning those out with a metal skewer or similar
Sep 12, 2014 | Ovens
I have an old belling farmhouse cooker the hob works fine but the oven isn't igniting manually or by the electric ignition The timer is manual and is stuck on the red patch I can't seem to shift it ...
Take the tiny screws of there are loads down right hand side then release screws on hob once you can lift hob plates up. Undo the covers on back of timer clock control . Make sure you un plug from mains . Take the neutral of back of timer clock. This will allow your oven to auto ignite again
Jan 07, 2014 | Belling FarmHouse 931 Gas Kitchen Range
Gas hob Luce(hotpoint) gas on glass 5ring burners keeps going out on low flame when pull pan drawer beneath out
Same problem with my hob. I adjusted the small jets to their lowest setting in order to be able to simmer -impossible on the bigger jets. The problem is the vents underneath the hob. These can't be closed off so the problem appears to be in the design. The solution I have to use while I save up to by a decent German model is to open and close the cupboard doors underneath the hob very, very slowly.
Nov 19, 2013 | Ovens
Strating PROBLEM
Hi, Andrew and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Why won my SYM Jet motor scooter start
Scooter Troubleshooting Scooter won start All about Scooters
Sym Jet 50 Service Manual
SYM Sanyang Scooter Parts Racing Planet USA
Sym JET 50 series Owner Manual
May 09, 2017 | 2007 Sym Jet Euro X 50
The gas flames on the hob don't come on fully - they seem very low
Hi what gas are you using? is the appliance suited to the gas, it seems as tho the appliance is jetted for LP gas & you are trying to run it on Natural gas
Oct 21, 2013 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Generator won't start. Seems to not be getting fuel. The fuel is new. The on/off switch is on, spark plug new and generator was serviced less than 6 months ago.
have you had the generator stored with fuel in the carburettor since its last use if so the fuel goes bad and blocks up the main jet, remove the float bowl and clean out all the residue you can clean out the main jet with a suitable piece of wire
May 30, 2011 | Generac Electrical Supplies
Neff gas hob on T2124 not lightin when turning on ignition.
make sure you have gas to the hob then make sure all the rings are clean and not blocked and that the ignition electrodes are clean
Dec 09, 2010 | Neff 22 in. T2124 Gas Cooktop
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
GAS JETS BLOCKED IN OVEN
If there is only enough gas for the pilot, it is very likely the main gas ciontrol valve is either in need of replacement or the "hot wire" sensor is in the wrong place or broken.
Basically the hot wire determines if the pilot is lit before turning on the main gas supply valve. It is a safety feature to dissapoint the suicidal.
I suggest this is fitted by a gas engineer as a leak at the valve can be very dangerous.
Feb 09, 2010 | Kitchen Ranges
Kitchen Ranges Logo
66 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
