Unable to change the time have unplugged it to start again and now unable to set the time
    Top Expert:
  • Audio Player... Master
  • 45,216 Answers
Hold time button down the tap the set button
Posted on Mar 28, 2015
Cycle selector on normal mode. cannot operate water tempertures orsoil level light indicators on a infinityfaf
Ron kundrat,
So I understand that you are unable to operate the water temperatures and soil levels on your infinity washer, while on the normal cycle.
I suggest to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle.
If you are unable to change the water temperature and soil level settings, while in the normal cycle, I suggest to contact your local authorized technician. They will be be able to come out and diagnose the washer and see why you are unable to change the settings.
-Best Regards-
Jan 13, 2014 | Frigidaire Washing Machines
Unable to clean
1) Press the Menu and Mono Start keys. Next press the key four times to make the machine enter the maintenance mode. 2) Press the key several times to display 8 on the LCD and then press the Set key. Again press the key several times to display 0 and then press the Set key 3) Press the Mono Start key several times until the purge count appears on the LCD. 4) Reset the purge count to zero by using the and Set keys as follows: Press the key several times to display 2 on the LCD and then press the Set key. In the same way, enter 7, 8 and 3. 5) Exit from the maintenance mode by using the and Set keys as follows: Press the key several times to display 9 on the LCD and then press the Set key. Again press the key several times to display 9 and press the Set key.
Jul 27, 2010 | Brother DCP 115C All-In-One InkJet Printer
Change Time in Giordano digital Chronograph watch #1143
KEEP YOUR FINGER ON THE BOTTOM LEFT HAND BUTTON. WHEN IT STARTS BLINKING PRESS IT AGAIN.USE THE OTHER BUTTONS TO CHANGE TIME.
Feb 03, 2009 | Casio DW290 1V Classic Alarm Chronograph...
Unable to change application settings in my nokia 6233
DO RESTORE SETTING OF UR PHONE THEN TRY AGAIN IT SHOW SAME PROBLEM
REMOVE MMC BACK UP OF ALL UR DATA FROM PHONE MEMORY INSTALL NOKIA PC SUITE IN UR PC AND DOWNLOAD UPDATES FOR UR MOBILE FROM NOKIA.COM INSTALL IT AND UPDATE UR MOBILE ONLINE.IT WILL FORMATE UR MOBILE ,RESET UR ALL UR SETTING
Nov 05, 2008 | Nokia 6233 Cellular Phone
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Unable to clean ... Brother MFC 3240C
Machine Error 46, Purged Ink Box Full
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An initial purge, for example, advances the purge counter by 187 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unusable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: unplug the unit, hold down the Menu/Set key, re-insert the power plug while holding down the Menu/Set key. The internal Machine Error Code will be displayed. Unplug and re-plug the unit again before continuing to the steps below.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the up arrow key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
May 27, 2008 | Brother MFC-3240C All-In-One InkJet...
Unable start Brother dcp 115
try to unplug machine from power. wait 1 minute and plug in to power again. Do set date and time again!
Feb 06, 2008 | Brother MFC 210C All-In-One InkJet Printer
Unable to print, unable to int, unable to clean
unable to clean is the error 46. You have to change the waistinktank and to reset the error code: Buy/order a new waistinktank from a service partner (see brother homepage). Open the printer (use pictures to know how to): http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c The waistinktank (ALTTINTENTANK) is the plasticcover with the white felt in it (should be gray/black now) and the two tubes (gray/white). Unplug the tubes and change it to the new one. Reassemble the printer. After power up press menu then start mono (B/W) then 4 times arrow-up: maintenance should be displayed and printer beeps with flashing buttons. Press 8 and 0 (zero). Press severaltimes (about 15-20) start mono (b/w) until purge (Nummer is about 6425) is displayed. Press 2 7 8 3. Purge is 0000. press stop. press 99. machine comes up again. thats it. BTW: YOu cant clean the waistinktank. Buy/order a new one! If you reset the purgecount without changing the waistinktank ink will flow into the machine!!!
Sep 17, 2007 | Brother MFC 210C All-In-One InkJet Printer
Unable to init.
Error message Unable to Change Unable to Clean Unable to Init Unable to Print Unable to Scan Cause The MFC has a mechanical problem. ?OR? A foreign obstacle, such as a clip or ripped paper, is in the MFC. Solution Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in the memory 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. ?OR? If faxes are present, you can transfer them to another fax machine. Go to Step 3. ?OR? You can forward the faxes to your PC. Please see Transfer faxes to your PC. Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1 Transfer faxes to your PC You can move the faxes from your MFC?s memory to your PC. 1. Press Menu/Set, 2, 5, 1. 2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC. 3. To transfer all faxes to your PC, press 1. ?OR? To keep all faxes in the MFC?s memory, press 2. 4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. (For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
Sep 06, 2007 | Brother MFC-5840CN All-In-One InkJet...
52 people viewed this question
 Grubhead
Grubhead
