Question about MSR Suzuki DRZ250 2001-2005 Skid Plates
My bike has a problem with the electrics the bike will still kick start but won't electric start there is no power with just the key on can enybody help
The kick starter on my 2012 taotao 50 broke when I was trying to start it up because the electric starter won't work at all. So now I can't start it period. The metal casing around the kick...
Is this bike chinese? if so toss it the chinese have yet to discover customer parts support so new parts can only be found on a new bike. Buy american or at least japanese where they pretend to like us.
Jun 18, 2013 | Cars & Trucks
Intermittent FI (not flashing) on LED display and flashing red light.
Kevin, Check the attached links,Manuals and guides, Good luck with your Bike
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What to do When Your Motorcycle Won Start
How to Diagnose Motorcycle Electrical Problems Dennis Kirk Inc
ATV Motorcycle Repair Manuals Repair Manuals Online
Aug 14, 2012 | 2008 Suzuki Boulevard C50T
At times I turn the key, toggle the kill switch to on and nothing happens. I have EFI on my bike. Can anyone help
Kick stand is down bike won,t start. Bike has a safety engine stop on kick stand. Try to start with kick stand and the way in the up position. see owner's manual
Aug 23, 2010 | 2004 Honda VTX 1800
Peugeot, speedfighter, electric start does not start when i press the break and the yelllow button on the right hand side, and rev it does not make a sound its lie the bike dead. But when the key is turned...
peugeot, speedfighter, electric start does not start when i press the break and the yelllow button on the right hand side, and rev it does not make a sound its lie the bike dead. But when the key is turned the petrol gage still rises, the horn indicators and everything else works
Jul 18, 2010 | Cycling
Fault with electric start on my Suzuki GSF 250 Bandit
Check that the clutch is in, kick stand up, and neutral light ablaze. Then try your start button. When you had it running and hit the button, the starter engaged at a slower speed then the bike engine was turning, which led to the stall. The stall means your starter works. If the starter works when the engine is running then it is wiring. Check your kick stand wiring along with the clutch wires which plug in on the handlle bar or where the clutch cable enters the engine.
Oct 18, 2009 | 1995 Suzuki GSF 250 Bandit
No electric to start YZF R1 motor bike,
check kick stand safety switch is working proper
Jul 15, 2009 | 2000 Yamaha YZF-R1
Suzuki GS 750 Starting
that year you had both electric and kick start as standard future.
the right handle bar round thumb button is the starter and the run/kill rocker switch should be in run position to operate elec starter
check fuse block under seat
Question do you get any dash lights work key turned on?
Jun 22, 2009 | 1978 Suzuki GS 750 E
Aprilia RS125 Help
Ive just bought a 2000 model RS 125 but my knowledge of bikes is pretty limited :/ The bike was running fine for a week with no problems at all but then the electric start doesnt want to work. I went through the manual and tried a couple of things (recharged the battery checked fuses cleaned spark plug etc) After I did this I still didnt have any luck but the electric start sounded abit more promising. I gave it another couple of goes and it started but when I let the throttle off the engine died and Im back to square 1. Anyone have any ideas about what could be the problem? I was talking to a friend and he said that I need to make sure that there is power going to the motor. He mentioned using a voltmeter to see if there was power going into it. He said that if there was no power then it would need a new electric start but if there was then I would need something else but I cant think what? Does this sound right to anyone?ou'll be able to tell if the ignition system is okay if there's a spark at the plug against the head with it removed when you kick it over (is there a kickstart lever on the bike?)/spin it over with the electric start. You could try bump starting it to see whether its just the electric starter motor or the ignition system itself that's the problem. If you do have a good spark then the bike should start with a bump push start/off the kicker (does it have one?)then you'll know whether the starter is the problem. My bike's kick-start only though so I'm no expert on starting Aprilia RS125's...Good luck. Don't waste money on new parts until you're sure of the problem though.,,,
Nov 10, 2008 | 1999 Aprilia RS 125 Extrema
MSR Suzuki DRZ250 2001-2005 Skid Plates Logo
43 people viewed this question
Top MSR Sport & Outdoor - Others Experts
Are you a MSR Sport and Outdoor - Other Expert? Answer questions, earn points and help others
