Question about Baby Gear
Was workinf but now has now picture and beeping as though it has lost siginal and when you check the settings it four cameras but none are selected
Code E8 on NS30LE how to fix this
An "E8" message appears on the panel.
Description: You tried to select a different stitch while the twin needle sewing setting was selected (the key is lit).
Select an appropriate stitch, or use the single needle sewing.
Note Each time a key pressed or an incorrect operation is performed, a beep is sounded.
  • For a correct operationOne beep is sounded.
  • If an incorrect operation is performedTwo or four beeps are sounded.
  • If the machine locks up, for example, because the thread is tangledThe sewing machine continues to beep for four seconds.
    The machine automatically stops.
    Be sure to check for the cause of the error, and correct it before continuing to sew
Jan 09, 2014 | Brother Sewing Machines
I have a finepix A920. Message saying memory full when I put card in, even though I have deleted all photos. Tried another and says the same. Internal memory will only let me take four pictures and then...
insert card, format card.
goto setting-> select save picture to...-> choose card.
you should see a card symbol on the screen when you take picture.
Jun 12, 2011 | Cameras
I am trying to view the photos on my memory card on my computer, but when I try and open the file, none of the pictures show up. I can see them all fine on the camera (though when I take the memory card...
DEAR CHECK THAT WHERTHER YOU CAMERA HAVE A MAKE PICTURES HIDDEN OPTION OR NOT. SOME TIME FILES ARE HIDDEN.
TRY THIS GO TO START MENU THEN CONTROL PANEL. SELECT FOLDER OPTIONS SELECT VIEW FROM CLICK SHOW HIDDEN FILES. BEST OF LUCK
Feb 08, 2011 | SanDisk 2GB microSD Memory Card
My connon xti 10.1 mp takes many out of focus pictures even though its on auto focus how can i solve this problem
I think its reqiure to do the focusing adjustent or you can try to clear all camera setting from menu option four. clear both settings and try to take picture and check out of focus problem.
Dec 29, 2009 | Canon Digital Rebel XTi 10.1MP Digital SLR...
I have managed to put a lock on my memory card in my camera... (it is on protection mode and dont know how to get it off as i want to delete all the pictures on the card. I have the old pentex optio wpi...
If your pictures are on the SD card in your camera, many of the sd cards have a small micro switch on one edge that will lock your card... you may want to pull it out of the camera and make sure that the physical lock isn't set..
Dec 02, 2009 | Cameras
Wont recognize gtco digitizer on start up
First reset digitizer and make sure you hear four beeps and only four beeps.
Check the cables from the Quikruler to the interface module, make sure they are in good condition, no cuts, breaks missing pins on connector.
Check cables from interface module to digitizer. A good way to check for an intermittent problem is to bend the cable at different points and check the display on the Quikruler to see if has reset.
Select S01 on the superset code with your stylus or cursor. You get get four sucess tones (beeps).
If none of this works check the firmware version on the digitizer, some J2.0 firmware may become corrupted. When the firmware becomes corrupted, you will hear three(3) medium tones on power-up.
If this is happening it will have to be serviced by GTCO.
Feb 06, 2009 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
My camera will not immediately take a picture.
The beep and no shutter action is usually because the auto focus is not focused. If you are using a zoom lens try backing up or unzooming a little.
Dec 20, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
My ES510 SELF CLEANING OVEN WITH CREMIC COOKTOP SHOWING ME LOCK SINE AND IT STOPING ALL THE ELEMENTS NOT WORKINF
One of the buttons on the keypad should have a little picture of a lock under or on it. Press and hold it until the unit beeps. That should unlock the rest of the keypad.
Nov 02, 2008 | Kitchen Ranges
Digital Camera
Beep signals should be mentioned in the manual, perhaps on the more comprehensive manual in the PDF file on the CD. Each set of beeps have a meaning. Check out the Canon tech support team.
Jun 02, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Baby Gear Logo
205 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
