Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
My Hp device it doesnot display anything on its screen when I power it on instead showing the sign lighty of speaker, wifi and so on that its powered on , what is the problem?
    New Friend:
    Problem Solver:
  • 12 Answers
It sounds like a power problem.
First check power lead is correctly plugged in. If going directly into a wall socket check the fuse in the plug and if necessary replace. How long has this been happening. Is it a recent occurrence?
Posted on Mar 28, 2015
Testimonial: "I have done all the way still my device its not displaying but it only showing the signlighty that its powered on what should I do?"
Hp compaq 6735b getting on but wont go to display
Hi Apextado,
I see you are having problems getting your notebook to load properly. Start by trying a Hard Reset. I have attached a YouTube Video that will show you how.
If that doesn't work then you can try connecting it to an external monitor to if this just an issue with the screen. If you still can't see anything then you will need to have someone take a look at the laptop.
You can contact HP regarding a repair by filling out the Contact HP Form link below to start the process.
h22207 www2 hp com
Thank you,
BHK6
I work on behalf of HP
Jun 15, 2015 | HP Compaq 6735b Notebook
What is the question mark mean on my screen
"?" on the right of the screen is about helpful instructions.
When you touch the ? , the printer display should show up some helpful instructions.
If the printer does not respond to press the ?, then try the below steps.
> Remove all the ink cartridges
> while the printer is ON, uplug the power cord from back of the printer.
> wait for 60 seconds. Plug in the power cord to the printer.
> Install ink cartridges when prompted.
Feb 25, 2015 | HEWLETT-PACKARD Envy 5530 built-in WiFi HP...
I have dell d630 it turn on but not display anything what is the problem
If the unit powers up and it seems to work except for the screen, hook a external monitor to the video output usually on the back, if picture is present! the laptop has issues. But if both screens show the same symptom the problem is in the video graphics card.
Apr 08, 2012 | Dell Latitude D630 Intel Core 2 Duo T7250...
How to care my hp dv5 battery? buy the hp dv5 battery from http://www.batteryfast.com/hp/pavilion-dv5.htm
For long life battery:
-Don't play computer games, music or DVD movies - Multimedia activities drain laptop batteries.
-Disconnect all external device like PC Card modems, Firewire, USB devices and optical drives. Use the notebook touchpad instead of an external mouse.
-Adjust your screen brightness - Dimming your display saves battery power.
-Tweak Windows Power Options - Choose a Laptop power scheme that turns off the notebook monitor and hard disk after 10 minutes of inactivity.
-Decrease or mute the Laptop Speaker Volume.
-Programs that are run from a CD or DVD can be copied to and run from the hard drive, which typically consumes less power than an optical drive.
Mar 19, 2012 | Computers & Internet
No sound and video
Video issue:-
Assuming the system power comes up, does the monitor power come on? Most monitors have a status LED on the front bezel that should show green, orange, or blinking if the monitor is powered on. You can hear CRT monitors power on with a gentle sound, though I can't describe it beyond saying it's the sound of a CRT tube warming up. Make sure the monitor is plugged into a good outlet by testing the outlet with a lamp or any other device that will prove beyond a doubt that the outlet is good. Make sure that the power cord is either permanently attached at the monitor end or that it is seated fully in the socket, since partial cord insertion is the most common failure for monitors with detachable cords.
LCD displays don't make any sound when you turn them on, but they don't have a simple power cord, either. Older LCD monitors are usually powered by an external transformer, which in turn is powered from a regular AC outlet. If the LCD display doesn't show any signs of life, make sure that the cords into and out of the transformer are fully seated. Some transformers are equipped with a status LED to show when they are operating. The power connection to the LCD display is often awkward to inspect, recessed into the back of the display. The important thing is to make sure it is started correctly, then seated all the way.
Sound issue:-
No Sound From all speakers
  • Check that the speakers are powered on.
  • Check that the speakers are connected to the correct ports on the PC. This is particularly important If the customer has both integrated sound and a sound card.
  • If the speakers have a volume control button - ensure that this is turned up.
  • Check that the Windows Audio service is running. If this is not running then many of the subsequent troubleshooting steps will not work. Go to Start->Run and type services.msc. Double cliick on Windows Audio. Select Start if possible and check that the Startup Type is Automatic. Click OK.
  • If the speakers are digital speakers then try forcing the sound card to use digital. Go to Start->Control Panel->Sound and Audio Devices.. On the Volume tab, click the Advanced button in the Device Volume section. In the Volume Control window, below the Play Control Volume slider, click Advanced. If this does not show select Advanced Controls from the Options menu. Select Digital Output Only
  • If possible try an external audio source like a Walkman, CD, or MP3 player (connect the speakers to the headphone jack)
  • Check that the volume control in Windows isn't muted or turned too low. See the screen shots below. Go to Start->Control Panel and double click on Sounds and Audio Devices.
Aug 06, 2010 | Computers & Internet
Before i used to play games on my ps3 with de normal cable and everything went fine but recently i started using the hdmi cable but it doesnot display de menu and it directly plays the game and when i got...
when you turn on the ps3 from the back and then you hit the power button in the front hold that front power button until it beeps at you and then it will work
Sep 22, 2009 | Video Game Consoles & Games
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
124 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
