Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
My tv it's turn not turn on or off from remote ...and when turn on from switch it's on and only 10 seconded and turn off .. I try many time and same problems
The light on switch on still flash when press any key on remote control
    Top Expert:
  • Panasonic Master
  • 74,383 Answers
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Apr 02, 2015
    Master:
  • 552 Answers
Change the batteries
How do I reset the remote key
Try this it worked for my s60 and recently on my C30
S/V 90
Procedure
1. Sit in the vehicle with all doors closed.
2. Turn the ignition key on and off five times (not to start position, but the on position) and on the fifth time leave in the on position.
3. Press the remote lock/unlock button several times (if there is a dashboard mounted LED it should light for 2 seconds and then it should flash for 10 seconds) to synchronise the remote to the control unit. Repeat this for additional remotes.
4. Switch off the ignition and test the remotes. A maximum of 4 remotes can be programmed.
S/V90 (Alternative Method)
Procedure
1. Close all the doors, the bonnet and the boot.
2. Switch the ignition on and off 5 times within 10 seconds, and leave the ignition on the fifth time.
3. Press one of the two buttons on each remote control.
Note: The first remote control has to be programmed within 15 seconds. The rest must be programmed a maximum of 10 seconds apart from each other.
4. Switch off the ignition and test the remote controls.
If you are unsure how to program your remote controls, please contact your Volvo dealer.
Nov 06, 2013 | 2004 Volvo XC90
I have a 00 petrol ford focus but the fob key does not work anymore. I saw a programming explanation for a 02 diesel focus and I am wondering if there is such a solution for my car? Thank you.
OBTAIN ALL REMOTE TRANSMITTER. TRY THIS PROCEDURE.FASTEN SEAT BELTS AND CLOSE ALL DOORS.TURN IGNITION SWITCH FROM OFF TO ON 4 TIMES WITHIN 6 SECONDS.SWITCH IGNITION OFF,ACOUSTIC SIGNAL WILL SOUND AND SYSTEM WARNING LAMP WILL ILLUMINATE INDICATES CORRECT PROGRAMMING.WITH IN 10 SECONDS.PRESS AND HOLD ANY REMOTE TRANSMITTER BUTTON. WAIT FOR ACOUSTIC SIGNAL AND SYSTEM WARNING LAMP TO FLASH INDICATES CORRECT PROGRAMMING. TO PROGRAM ANOTHER REMOTE TRANSMITTER, REPEAT ABOVE PROCEDURE WITHIN 10 SECONDS.TO EXIT PROGRAMMING MODE,TURN IGNITION SWITCH TO CRANK OR WAIT 10 SECONDS. IF THIS PROCEDURE FAILS YOUR IGNITION KEY WORN OR IGNITION SWITCH RING COIL BAD.
Mar 15, 2011 | Ford Focus Cars & Trucks
Ns-20lcd in locked mode will not unkock with a remote which I ordered. I there a master reset somewhere?
Insignia will tell you that you MUST have original remote to unlock. You press and hold Display button for 5 or 10 seconds. My problem is Best Buy tried to repair mine 3 times and one of those times replaced a board inside and original remote will note work and they will make no attempt to help me figure out what is inside. Mine has been locked for over a year. Locked by accident with universal remove.
1. Locate second power switch on back hidden below curve, left side if facing front of TV.
2. Turn TV on using this power switch while holding in MENU button on right side of TV.
3. This is reset the Lock feature!!
Feb 01, 2010 | Insignia Televison & Video
TV screen turned on for only 10-15 secs then self turn off, followed soon after by the tv power another 10-15 seconds later. if i try this a few times screen wont light up at all.Is it the TV Lamp?
1) Can be dust do a good clean
2)Check for the fuse and change it if needed.
3) Capacitor needs to be changed, you'll have to findout which one.
Hope it helps, good luck
May 19, 2009 | LG RU-52SZ51D 52" Rear Projection...
How to program the keyless entry for my 1996 Acura TL.
Hi, Stacie,
here's the instructions for a 97 TL - I hope they're the same.
Note:
Entering the programming mode cancels all learned keyless remotes, so
none of the previously programmed remotes will work. You must reprogram
all of the keyless remotes once you are in the programming mode.
You must complete each step within 4 seconds of the previous step to keep
the system from exiting the programming mode. You must program remotes
within 10 seconds of each other
1. Turn ignition switch to ON (II)
2. Within 4 seconds press the LOCK or UNOCK button on one of the remotes.
(An unprogrammed remote can be used for this step.)
3. Within 4 seconds turn ignition switch to LOCK (0) position
4. Within 4 seconds turn the ignition switch to ON (II)
5. Repeat steps 2, 3 and 4 two more times using the same keyless remote
used in step 2
6. Within 4 seconds press the LOCK or UNLOCK button on the same remote.
Make sure the power door locks cycle to confirm you are in programming
mode.
7. Within 10 seconds press the LOCK or UNLOCK button on same remote.
8. Within 10 seconds press the LOCK or UNLOCK button on all other
remotes you want to program. Make sure door locks cycle after you push
each remote button to confirm system has accepted the remote.
9. Turn the igniton switch to LOCK (0) to exit programming mode.
10. Test remote(s)
Hope this helps :)
John
Mar 26, 2009 | 1998 Acura TL
My remote will not work and the tv menu is on the screen and goes through all the diffrent setting options automatically without stopping. TV buttons will not control the menu. Unable to make any setting...
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of time.it will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
Jan 17, 2009 | Toshiba 36A43 36" TV
Keyless remote
Note:
all of the keyless remotes once you are in the programming mode. You must complete each step within 4 seconds of the previous step to keep
used in step 2
mode.
10. Test remote(s)
Dec 24, 2008 | 1998 Acura TL
Directv remote
1) Use 2 new AA batteries in RC32 remote control;
2) Slide mode switch to "TV";
3) Press and hold the MUTE and SELECT keys at the same
time until the green light under the selected switch
position flashes twice, then release both keys.
4) Enter 9-9-1-1.
5) Press PWR button on TV.
6) Point the remote at the TV and press CHAN+. Repeatedly press CHAN+ until the TV turns off. Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7) Use the CHAN- key to step back a code.
8) When the TV turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key. If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the TV remote control.
9) To verify the code, slide the MODE switch to the appropriate position.
10) Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
11) Enter 9-9-0. (The green light under the selected
switch position flashes twice.)
12) To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down in the TV owner manual.
13) Press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
To control TV volume from Directv RC32:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Feb 11, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Menu keeps popping up
Hi, heres your fix, replace all of the front control board tact switches, part number is 23344443 & have a Merry Christmas, BMW Rider
Aug 24, 2007 | Toshiba 32A43 32" TV
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
56 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
