Hello i need urgent help my vaillant heater igniter push button is broken how can i ignite the heater.please let me know asap.thanks!
    Top Expert:
  • Heating & Co... Master
  • 52,135 Answers
Sounds like you need to call a serviceman .
Posted on Mar 28, 2015
  • 19 Answers
SOURCE: Reddy Heater RLP 30 ignites but won't stay on.
Sounds like a bad thermocouple.
Posted on Mar 05, 2008
SOURCE: Pool Heater
You can light the pilot with a B.B.Q. lighter.
Nottoohandy. Backwash you filter, make sure it's really clean. If that doesn't work it could be the pressure switch. You can by-pass the switch with a piece of wire to see if it fires up. If it does, it's the switch. There is a picture of the switch in the manual.
C
Posted on May 26, 2008
tbugger
  • 232 Answers
SOURCE: All-Pro SPC-85 Utility Heater
Another source for heater parts is www.reddyparts.com .
Posted on Sep 26, 2008
SOURCE: Lars Lite 2 pool heater will not ignite
The easiest way to troubleshoot any heater, is to call the manufacturer. Their techs will walk you through each possible problem and solution until you find the answer.
Posted on Oct 03, 2008
SOURCE: Rinnai burner goes out when ignition button is released
The thermocouple [s] require replacement, or in my experience try servicing the unit first. There is an injector for the main pilot and a secondary injector for the flame thrower ignition. Both of these are prone to blocking due to dust and can be enough to shut the unit down. Although usually this is thermocouple related as you are manually keeping the unit running when you hold down the button, if the tcouple is broken it wont send enough millivolts to hold the magnetic valve open when you release the button.
Cheers
Posted on May 31, 2009
Have a richmond 6G40-36F1 hot water heater had to turn off gas for another issue, now igniter doesnt spark and pilot wont light
Not to sound silly, but are you pushing the igniter button down hard enough so it snaps? If so, your igniter is no good. Try to light the water heater the old fashioned way by using a match. I would use fireplace matches since they are long enough to reach the pilot light point.
May 27, 2016 | Water Water Heaters
Ignition continuous spark
I am not familiar with this model, but in general when it says to push the button it will start the sparking sequence to lite the pilot or burner once it lites and proves flame then the sparking should quit. Something must of broken and is keeping the spark staying on. It should not be sparking all the time. Hope this helps.
Jan 30, 2014 | Heating & Cooling
My Bradford White Defender M-I-30T6FBN doesn't show igniter button on instructions
1) Copy following links to identify gas control valve and read ignition procedure, and access service manual for your product:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Honeywell gas control used on recent Bradford White gas water heaters has red knob that rotates to pilot. Press and hold red knob. Then push red igniter button until status light changes.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 11, 2013 | Bradford White Bradford MI30T6FBN-337 30...
I have an old flueless rinnai gas heater and the safety valve which is used to ignite the heater has disappeared. There is just a hole where there should be a push button safety valve. Where can I get...
Joel, have you looked inside the heater's cabinet, to see if it's fallen inside? For it to disappear, someone would have had to dismantle the heater cabinet and disconnect the ignitor's wiring. Or if you're speaking of the Gas Control Valve (the knob says OFF, PILOT, ON) they would have had to do the same thing. If it is the Gas Control Valve, I would recommend that you just scrap the old heater and buy a new one. As the Control Valves are pretty expensive and who ever removed it, may have taken other critical parts with it.
If it's just the Igniter button and wiring, they're pretty inexpensive to replace. Assuming the the Piezo Igniter (it generates the spark) next to the pilot is still intact. As a matter of fact, you could probably replace it with a gas grill igniter button, if it will fit the existing hole.
Hope I was able to help you solve the problem or at least, steer you in the right direction. Please let me know. Thanks.
May 06, 2011 | Rinnai Vent-Free Gas Heater: Blower For...
Cozy Heater not igniting and heating
Sounds like to me that the pilot ignition is not lighting pilot lite. You have to be careful when jumping out the stat that you jump the right wires.It must be an automatic Ignitor, or push button.I would change the module out. That should take care of the problem. Look at the schematics so you know what to look for. Please let me know, Sincerely, Shastalaker7
Nov 07, 2009 | Heating & Cooling
Boiler won't fire even though the pilot is lit
Check if the ignition plug works. Upon putting your boiler on, a spark will normally trigger the
the firing. Then, check the ignition transformer if it works. Check the secondary voltage which is between 15000 to 20000 volts to trigger the ignition plug and the boiler to fire. If no spark,
have your ignition transformer replaced to make it work.
Sep 21, 2009 | Heating & Cooling
Boiler light wont ignite
more likely the thermal coupling is u/s get new one fitted
Dec 02, 2008 | Water Heaters
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
